Hi, Its clear that there is some problem with the other persons webcam settings and there is no problem from your side. Tell them to reinstall the logitech webcam driver software and skype software once. after reinstalling their skype, for the first time when they log in, they will be shown with a wizard which is used to configure their mic, speaker and webcam. Tell them to provide correct configurations in that wizard. This should fix the problem and you can enjoy webcam chat with them.
Welcome to FixYa,
Dear User,
Please look at Skype / Tools / Options / Video Settings / Webcam Settings, and see if there is a box for "Low Light Boost". If there is, and it is checked, un-check it and try your video call again.... Still Same Uninstall Cam Driver Download Driver From Here[select your OS and Download] Install Driver Still Same Let me Know Which is your Skype Version...? Thanks for Contacting FixYA...
Yes, I have a Logitech WEBcam (not the same model) and I use Skype.
After you installed Skype then :- To test if the Logitech QuickCam is functioning, check the USB cable; make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video. If this works then the fault is with the Skype configuration. Sometimes the WEBcam settings drop off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select the Logitech QuickCam Also check the Audio Settings for the Microphone THEN click on Save. Avoid connecting the WEBcam to an USB hub.
You can try to configure it. But first I would recommend you to download the latest version of skype. Link is :(www.skype.com/download/) While configuring be sure to use the following setting: 1.Start skype. 2.In the navigation pane of the Skype Options window, click Video Settings. 3.Adjust quality of picture in 'Settings 4.Check the correct webcam is shown as default Click Save Test your webcam by making a Skype test call. If you need further help you can log onto: (http://support.skype.com)
The advantage of having a logitech webcam is the support you have. I just launched my logitech toolbar and clicked on the lowest panel to see what help you have with your webcam in Skype - check this out
If you have problems when you use your Logitech device in Skype, you may have to
configure the audio and video setting in Skype. To do this, follow these steps:
Start Skype.
On the Tools menu, click Options.
In the navigation pane of the Skype Options window, click Audio Settings.
Select your Logitech device as the default microphone. (if it has a built-in mic) For example, select Logitech Communicate STX.
Select your Logitech device as the default Webcam. For example, select. Logitech Communicate STX
Click Save.
Test Logitech by making a Skype test call.
For more information
about how to configure Skype Messenger, please visit the following Skype Web
site:
There maybe a patch available with a later driver Go to Device Manager, Expand 'Imaging' folder and right click on your webcam text. 'Update driver' and use internet option.
Check your webcam is set to default in Skype
Start Skype.
Select your logitech device as the default microphone. For example, select Logitech + model#.( if it has mic )
Select your Logitech device as the default Webcam. For example, select Logitech + model #
Click Save.
Failing that check if you have the latest version of Skype
