Connect a pioneer VSX-523-k receiver to a samsung led tv model un32eh4003v
How do you connect the pioneer receiver and samsung tv so the tv audio comes out of the pioneer receiver speakers when playing in tv mode such as watching tv from an antennae. I have a Sony blue ray player and the receiver works when watching movies from the Sony blue ray player. Just can't figure out how to connect the tv for audio in standard tv antennae mode.
SOURCE: Audio Problems
See www.avforums.com/forums/onkyo-owners-forum/696423-faq-setting-up-ps3-onkyo-amp.html
This should give you the info to set up the ps3.
Posted on Jan 04, 2009
smarthome2
  • 1114 Answers
SOURCE: RX-v465
Unfortunately the RX-V463's HDMI output is version 1.2 or 1.1. In simple terms, It is useless! Not to blame yamaha or any other manufacturer but the firmware was riddled with problems; just like what you describe. There is no fix for your model for the video issue, however, the optical issue is solveable. The receiver should play 5.1- 6.1 7channel stereo etc. in optical or coaxial mode. If you have the ability to switch to coaxial, do so. it's sound is warmer anyway. Secondly, check your settings thru the receivers "GUI" or "Menu" in Manual setup for audio. Thirdly, check your samsungs "Native" resolution, chances are it will only do 720p or 1080i and; if your TV is 50" or smaller, the human eye cannot see the difference between 720p and 1080p anyway, provided you use good cables. I am a professional in the industry and still avoid using HDMI whenever possible!
Just make sure you set your BluRay and TV to the same resolution. If your choices are 720p or 1080i use 720p it's cleaner 1080i is equal to 540p, which is just a hair over std DVD video. If you still have problems and need more help, post a comment and I will help some more. Hope this helps
Posted on Jun 11, 2009
  • 82 Answers
SOURCE: While watching blue ray, the receiver loses the Signal
check the continuity of the AV Cables and check for any loose connection/dry solder in the connectors
Posted on Jul 13, 2009
  • 9 Answers
SOURCE: Surround sound for Blu Ray on older Sony receiver
Hello, it sounds to me like the receiver doesn't support the sound format being sent from the blu-ray player. This is because the blu-ray disc would have HD encoded sound such as DTS HD Master Audio or Dolby True HD. Most receivers have not been fitted with these sound formats untill quite recently. The reason for the menu sound playing correctly would be for the PCM (Pulse-code Modulation) which sends simple two channel digital sound supported by all digital receivers. It may be possible to use Dolby Pro Logic or similar formats to give a surround feel, but the only way to get true surround sound in this way would be decode the sound externally and input it through several phono cables into the multichannel input, however blu-ray sound comes in 7.1 so the receiver would need to be able to accept this to get the full effect. If it is possible, see if the blu-ray player will allow downsampling to a surround sound format that your receiver can accept such as Dolby Digital or DTS. Hope this helps.
Posted on Aug 21, 2009
dunnbiker
  • 8546 Answers
SOURCE: I have an RX-V663 audio sounds flat
Let's deal with the turntable sound first - unless it's a self-preamplified model you would have to get an external phono-specific preamp to use with this receiver. Without one you'll get microscopically weak, tinny sound from the turntable. Google "RIAA curve" to see why.
As far as the CD sound through the Blu Ray player... for one thing it is flat, as in two-dimensional stereo. Compared to genuine surround from a movie it would be a letdown.
Can you better define 'flat'?
Posted on Feb 04, 2010
Testimonial: "Thanks for working on this with me, you really dove in!"
My hdmi is on my pioneer vsx 523
The HDMI inputs are on the back upper left of the unit. the 4 on the left are INPUTS (like you connect you DVD to port 1) then you need a 2nd HDMI cable from the white 5th port going OUT to your TV HMDI port.
http://www.pioneerelectronics.com/StaticFiles/PUSA/images/Product%20images/Home/VSX-523_back.jpg
Dec 07, 2016 | Pioneer Audio Players & Recorders
I'm trying to connect my LED samsung tv to my pioneer amp M-L11 using the digital audio output. Can you tell me please if my stereo system should be able to be support my tv so that i am able to h
Pioneer Amp input is analog. if there is a headphones out
( no model for Samsung LED TV) , connect it , not using your
Fisual Digital Opitcal Toslink Cable.
If you really need to use the TV digital out you may need a Digital
to Analog converter , to be connected on Pioneer XC L11 Aux Input .
Optical is Out only for that model.
Sep 26, 2012 | Audio Players & Recorders
How can I connect an HD LCD tv to an ancient (I think 1980s) Pioneer Receiver Model VSX-305? The receiver is in great condition, and I'd rather not replace it. I have Bose speakers connected to i
I have never seen RCA to digital conversion, and if it did exist you would have to convert from digital to analog in order for this to work, the sound quality would be degraded and unreliable, plus sound level would drop.
Mar 20, 2012 | Pioneer VSX-305 Receiver
App err
PDF]VSX-D414 VSX-D514 - Pioneer
www.pioneer-latin.com/downloads/xre3077a.pdf
Increase the separation between the equipment and receiver. - Connect the .....AUDIO/VIDEO MULTI-CHANNEL RECEIVER VSX-D514. RCE. VSB. MODE.
Pioneer VSX-D514 Receiver Repair Questions,... - Fixya
www.fixya.com > Forum > Audio & Video Receivers > Pioneer
Recent Pioneer VSX-D514 Receiver questions, problems & answers. Free expert DIY tips, support, troubleshooting help & repair advice for all Audio & Video ...
app err Turns on then says amp err. - Fixya
Jan 26, 2012 | Pioneer VSX-D514 Receiver
Trying to connect a Plasma TV to this receiver which does not have HMDI
What you need to do is connect the HDMI from your source(SAT, Cable box or DVD) directly to your tv. Then, connect audio from that same source down to your pioneer receiver.
Good Luck
Jan 07, 2011 | Pioneer VSX-456 Receiver
My Pioneer VSX-919AH-K A/V receiver does not receive the audio from my Samsung 50 in. plasma tv and transfer sound into my speakers. How can I fix this?
What model Samsung TV?
Couldn't you just route all TV-related audio directly to the receiver from whatever source creates it instead of through the TV (TV's NOT being the pinnacle of audio performance). I'm sure the Pioneer will do a better job with the direct digital audio feeds than whatever the TV decides to pass on.
Mar 19, 2010 | Pioneer VSX-919AH-K A/V Receiver
I'd like to know where the vcr cable & cable wire from wall
(I own 2 VSX-D903S Units.)
There are NO optical (Toslink) or coaxial connections for Satellite or Cable-TV on this Pioneer unit.
The coaxial connector on the receiver is for connection to an external antenna for FM Tuner (radio) reception only.
Your cable line from the wall would go to your Cable Box, or a "cable-ready" TV or VCR. You would then connect the composite (YLR) or S-video output A/V (S+LR) connection to the VCR 1 input on the back of the receiver. Connect your TV L/R audio and S-video or Composite video output to the TV in connection on the Receiver. (Connect the Composite TV-out connection to a composite video-in connection on the TV.)
Dec 26, 2008 | Pioneer VSX-D903S Receiver
44 people viewed this question
 Grubhead
Grubhead
