Question about Watches
Can't reset stopwatch to zero? Zodiac seadragon z02209
2 Suggested Answers
escapement
  • 2334 Answers
SOURCE: How do I zero-out the minute hand of the stopwatch?
Try this: pull out crown to the first click, then push and hold button at 2 o'clock. When the hand is adjusted to the desired time, push the crown back in.
If thi do not work, do the same using the button at 4 o'clock.
Rate me, please.
Posted on Mar 26, 2009
Stopwatch second hand not reseting to zero ar 0532
PULL THE CROWN OUT TO SECOND POSITION THEN PRESS THE START BUTTON TILL IT GETS TO ZERO THEN PUSH CROWN BACK IN
Sep 13, 2013 | Giorgio Armani Emporio Armani Sport Ar0532...
Stopwatch
You need to calibrate it. In normal time mode, pull the crown out all the way and then use the pushers to step it back to the zero position. When finished, push the crown back in. You can also calibrate the sub-dails in a similar fashion.
Mar 31, 2008 | Navy Seal Luminox Watch
How to stop stopwatch on revo rv1006 watch changed the battery but need to stop the stopwatch
Push the upper button once. The stopwatch hand will freeze. Push the bottom button. Stopwatch hand should move to ZERO position. Rate me, please.
Jun 24, 2010 | Watches
Stop watch will not reset to zero
pull the crown full out reset all hands set time set alarm or second time if you wish and press the crown back.
Dec 01, 2009 | Seiko Coutura Chronograph Watch
I have a seiko chronograph sports 150 watch; had the battery changed a few day ago and just noticed that the second hand & stopwatch hands are not 'centered'. is ther a way to reset this ? cheers
As jimmyguru said.
1. Pull the crown to the second position (all the way out)
2. Push and hold the reset button and allow the chronograph hand to rotate near the 12 o'clock position.
3. Release the reset button.
4. Repeatedly push and release the reset button to find tune the hand position until it is right at 12 o'clock.
5. Push the crown back in.
Nov 05, 2009 | Seiko SNA553 Alarm Chronograph
Resetting stopwatch dials - Armani AR5331
When you reset the big seconds hand to zero, the hour and the minute hand are not engaged in this function, so, there is no fault with the watch movement.
Do as follows:
1) pull out crown and set the hour and minute hands at 6 o'clock (they must be lined perfectly in opposite directions)
2) push the crown in half way back (not completely)
3) push and hold the button at 2 o'clock (set the big seconds hand to zero) and release it when done
4) when big seconds hand is zeroed push the crown back in
5) pull the crown out again and set desired time
6) push the crown back in.
If all actions described do not work, you will have to visit your nearest watch repair shop and ask to refit chronograph hand as in this case it is out of balance (not pointed at exact mark).
Rate me, please.
Apr 03, 2009 | Watches
Festina Dashboard watch - Adjusting the hand of the stopwatch
Your watch has quartz movement and stopwatch adjustment by one step (one full second) only. That means you will not be able to adjust stopwatch hand by using pushers on your watch as each push of the pusher will advance stopwatch hand for the full second, not the fifth or the tenth of the second, and the hand will stay slightly off anyway.
This happenened because the IC (integrated circuit) in your watch miscalculated the teeth count on chronograph wheel and stopped one or two teeth past or under the zero point. It doesn't happen very often, but in your case it did and the only solution is to find your nearest watch repair shop and ask for resetting stopwatch hand to zero.
This procedure needs partial disassembling of the watch and quite a great skill as the stopwatch hand must be removed and then refitted with great accuracy. All this needs to be done by very specialized tools as well.
I think this is the only solution of your problem unless you can live with that and just leave it as it is.
Do not forget to rate, please.
Feb 09, 2009 | Festina Dashboard 6719/3 Watch for Men
Tag Heuer Link, stopwatch seconds hand stops 2 seconds before 12
Pull crown out to position 2 [in between unscrewed (1) and pulled all the way out (3)].  Tap Button B (bottom) to reset by step back to zero.
Incidentally, Button A works Hours register in same manner for position 2.  You can similarly reset second and 1/10th with Buttons A and B, respectively, while in position 3.  Cheers!
Jul 25, 2008 | Tag Heuer Link Automatic Chronometer...
Pull the crown to first position (where you set the date) then adjust the dials with buttons.
uhrmacher
Jan 10, 2008 | Giorgio Armani Classic AR5326 Wrist Watch
Reset Stopwatch Hands on CL1111 ?
Try setting the crown to position 2 - i.e. the position normally used to adjust the date.  Then use the top and bottom stopwatch buttons to adjust the minute hand and 1/10th hand respectively.
Oct 18, 2007 | Tag Heuer Aquaracer Quartz Chronograph...
Watches Logo
41 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
