Question about Hampton Bay 54 In. Flemish Pewter Ceiling Fan with Heater
FAN MAKES A FLUTTER NOISE - Hampton Bay 54 In. Flemish Pewter Ceiling Fan with Heater
Have a hunter 52" insignia
Diane, usually, that's an indication that one or more of the fan blade irons are loose, where they attach to the fan's motor. Unfortunately, you're going to need a tall ladder and a Phillips Head Screw Driver to reach and tighten the screws. You'll have to check each fan blade iron one at a time, to find the one(s) that are loose.
Good luck. I hope this helps you solve the problem.
Jul 09, 2011 | Hunter Heating & Cooling
Makes a buzzing noise,no cooling
buzzing noise is prob/ the evap fan . ck that both evap fan and cond fan re working .. . and clean the coils underneath .. .mm
Jul 04, 2010 | Frigidaire FRT21P5A Top Freezer...
Cuts off makes noise
Sound like the dryer bearing or rollers are out. This would make it very hard for the dryer to start and run. You must pull the dryer drum out to access the parts. I'm sure you will see the problem right away once it is apart.
Apr 01, 2010 | Whirlpool LER5636P Electric Dryer
R.kerr
Fan some times makes ratteling noise when it is old and dusty. If you know how to open it remove the fan put some oil in the bearing of fan give external supply to fan and run it for 5 mins. clean the ventilation behind fan if noise goes by oil it is good or replace the fan.
Nov 12, 2009 | Microwave Ovens
New crosley CR249-GR "wow and flutter"
I see your message isn't new anymore but Crosley does have a website with warranty and support info:
Crosley Radio
Jul 14, 2009 | Crosley CR248 Turntable
Noise of fan
Clean the fan with compressed air, and a q-tip.
If it still makes noise, replace the fan. They're cheap.
Jun 17, 2009 | Intel D915GAG Socket 775 Motherboard -...
Fan flutter noise with air conditioning on
I WENT TO THE VW DEALER...HAPPENED TO PASS BY. THE PROBLEM WAS SOLVED WHICH WAS FLUTTERING SOUND FROM THE AIR CONDITIONING FAN.
IT WAS COMING, I WAS TOLD, FROM THE MECHANISM THAT ADJUST THE TEMPERATURE, AND NOT THE FAN
THANKS FOR THE FOLLOW UP
Sep 08, 2008 | 2000 Volkswagen Golf
Low level noise causing sub flutter
the ground may not be coming from your stereo it should be coming from a loose wire under the hood. Do u have the factory radio? that might be it if u do
Sep 09, 2007 | Car Audio & Video
Hampton Bay 54 In. Flemish Pewter Ceiling Fan with Heater Logo
27 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
