Question about Casio G-Shock Watch GA-201-1A
Ho do I adjust the time on this watch? - Casio G-Shock Watch GA-201-1A
Setting day/date on AIIZ watches
hi guys im having a watch which is being gifted to me and its logo contains the symbol "AIIZ" but i cant find that brand on internet
ho to find that watches cost
andits dtails
Jan 20, 2012 | Watches
Ho do i set date and time on pulsar tech gear wristwatch?
you can set the date of your watch by pulling the crown on its middle position and turn it until it reaches the exact date, remember there are three position of the crown, first the normal position, the middle and the out position. push the crown when you done. i hope this will help you.
Sep 25, 2011 | Pulsar Tech Gear PUA115 Wrist Watch
How to set time on my Casio Lw-200 Kids watch Its a digital watch
Thank you for contacting FixYA.<br /> <div style="BORDER-BOTTOM: medium none; TEXT-ALIGN: left; BORDER-LEFT: medium none; BACKGROUND-COLOR: transparent; COLOR: #000000; OVERFLOW: hidden; BORDER-TOP: medium none; BORDER-RIGHT: medium none; TEXT-DECORATION: none"> <li id="jsArticleStep1" itxtvisited="1"> Examine your watch. Attempt to find its "Mode" button; nearly every digital watch has one. The various modes might include "Date," "Alarm" and "Stopwatch" among others. Repeatedly press "Mode" to cycle through the modes available on your watch until you have it in the mode that displays the current time.<br /></li></div> <li id="jsArticleStep2" itxtvisited="1"> 2 Locate the button that allows you to adjust the settings on your watch; this button could be labeled "Set" or "Adjust." Once you've found this button, press it in and hold it. After a few moments, the time display should begin to flash.<br /></li> <li id="jsArticleStep3" itxtvisited="1"> 3 Select either minutes or hours as the aspect of the time you'd like to adjust. Press the "Mode" key to cycle through your options; each element should begin to flash as it's selected.<br /></li> <li id="jsArticleStep4" itxtvisited="1"> 4 Press a button to adjust the time element you've selected; the button for doing this will vary from watch to watch. If there are up and down arrows on your watch, use them to increase or decrease the number. A button labeled as another function could serve this purpose too; trying pressing the various buttons on your watch to discover the correct one to adjust the time.<br /></li> <li id="jsArticleStep5" itxtvisited="1"> 5 Move on to the next element you want to adjust, such as minutes or the date, by pressing the "Mode" display.<br /></li> <li id="jsArticleStep6" itxtvisited="1"> 6 Press the "Set" button to finalize the new time on your watch. You'll know that the time has been set when the numbers stop flashing.<br /></li> <br /> For more Casio info go to:<br /> http://www.casio.com/support/<br />Best regards.
Aug 24, 2010 | Casio LW200-1AV Wrist Watch
Ho to set time & date on armitron watch
Copy "www.armitron.com/watch_instructions.asp" into your search engine
and you will see a list of illustrations of watches and associated
instructions.
Mar 09, 2010 | Watches
Kennet Cole Mens Watch Model A126-08 KC1494 How to adjust time
I have a Kennet Cole Mens Watch Model A126-05 KC1296 and I'd liked to know
How to adjust time
Jan 16, 2010 | Kenneth Cole Watches
How to adjust the band on a GW800D Tough Solar
By finding a spring loaded rod in the clasp (that is in the set of three holes in the clasp) moving it to the last position. However it was still loose, so by finding the spring loaded rods that hold the links of the band together, pushing them down in the direction of the arrows and removing enough links to fit.
Aug 29, 2009 | Casio GW800D 1V G Shock Atomic Solar Watch
Ho do I charge my Citizen Eco Drive Ladies EW8622-53A watch for the first time?
Hi leave under a strong light for a few hours, normal wearing should then be sufficient.
If only worn intermittently leave out in the light, do not put in draw or anywhere daylight can not get to the face of the watch.
Nov 29, 2008 | Watches
Adjust time on casio telememo 30 watch
how to adjust time on casio telememo watch
Oct 26, 2008 | Watches
Aquaswiss Trax watch band adjustment
VSNDESIGNS SAYS:
You should first try to adjust the band at the Clasp first. The clasp has three holes that you could easily move your band up or down into. If you need to remove one or more of the links, try the following.
http://www.fixya.com/support/t315141-adjust_band_aquaswiss_trax_watch
http://www.rgmarchitect.com
Feb 09, 2008 | Watches
Casio G-Shock Watch GA-201-1A Logo
63 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
