Adobe could not open URLLink(1).acsm - Computers & Internet
Adobe Illustrator file
Hello Philip.
Try a special program Illustrator Fix Toolbox https://www.fixtoolbox.com/illustratorfix.html
If it couldn't aid you:
1) Open the preferences file and look for the entry named "enableContentRecovery", change the value from 0 to 1. This turns on the feature.
2) Launch Illustrator and choose "File>Open". Select the file from which you wish to recover the roundtrip information.
3) Click "OK" .
Aug 13, 2016 | Adobe Computers & Internet
Convert ACSM to EPUB
You just have to install the ACSM Reader Adobe Digital Editions to open acsm with ePub.
http://www.epubor.com/convert-acsm-to-epub.html
Jan 01, 2014 | Coby Electronics Corporation Coby Kyros...
Trouble downloading digital books using overdrive media console. Error: invalid root file. .acsm
Update your Adobe flash player software to the latest version:
http://get.adobe.com/flashplayer/
If that doesn't fix it you might have some viruses and malware.
Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.
Download, Install and Run Malwarebytes Anti-Malware:
http://majorgeeks.com/download.php?det=5756
When Installing choose the non-pro version.
Download, Unzip, Install and Run TDSSKiller:
http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.html
Download, Install and Run Super Anti-Spyware:
http://majorgeeks.com/SUPERAntiSpyware_d5116.html
If you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:
http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.html
Make sure to select ALL of the "threat categories" when you install or configure Avira...
You should be in pretty good shape if you run and install all of these programs...
Jun 29, 2012 | HP Computers & Internet
I cannot find were the acsm is on a 2008 bmw 528xi
Hello roni1love,
If I remember correctly, I think it is behind the glove box in the electronics carrier. With the introduction of the ASCM the Byteflight Bus was eliminated and diagnosis and coding takes place through the K-CAN-Bus. It will be labeled on the control unit itself.
Jun 22, 2011 | BMW 528 Cars & Trucks
Can't open a pdf file. I've have downloaded the new version 9 Unistaled and restalled it still does't work.
Here are the easy steps to get the latest Adobe Reader so that you can open .pdf files.
step 1: follow this 2 steps in removing adobe on your computer:
after removing adobe go to next step
Step 1. go to Adobe site
6897331.jpg click on the Adobe reader which is encirled
then follow the next 2 steps to install adobe reader on your computer:
after the installation, ou can now open .pdf file with no problem.
Thank you for using Fixya. Your high recommendation is higly appreciated.
Sep 19, 2010 | Adobe Computers & Internet
I have problem opening adobe pdf files. I have adobe 9 and 9.3 but does not open adobe files. It asks for adobe 4 and 7 or 8. I tried to download adobe 4,7 or 8. It says I have that version on my computer....
try the steps below:
1. Right-Click on the PDF file.
2. Select Properties
3. On the General tab,
3.1. Check the Opens with: if its set to Adobe Reader
If not, click the Change button and select Adobe Reader
If the same thing happens, Uninstall all Adobe Reader installed on your computer. It is an indication that the installation is corrupted that's why it is not being detected.
I suggest that you can try to use Foxit PDF Reader instead which for me I find very convenient in opening PDF files.
Please let me know if the following has been helpful.
Aug 20, 2010 | Adobe Computers & Internet
What program should i use to open files they dont open with internet explorer
A file is usually open by the computer only when the associated program is installed in the system. The associated program recognize the file extension and open it.
For Example :A notepad file will be open by Notepad editor untill and unless you cange it to open with other program.
Microsoft Word can open a notepad file too.
Files usually you will find or will downloaded from internet are usually .exe, .rar, .zip, mp3, .avi, pdf etc.
I recommended, you installed these few softwares
1. Adobe Flash player.
http://fpdownload.adobe.com/get/flashplayer/current/install_flash_player.exe
2. Adobe Reader.
http://ardownload.adobe.com/pub/adobe/reader/win/9.x/9.2/enu/AdbeRdr920_en_US.exe
3.Jave runtime
http://fs4.filehippo.com/2222/75ce054974f24f4ca18bf8c0be7bc18f/jre-6u17-windows-i586-s.exe
4. Winrar
http://www.rarlab.com/rar/wrar391.exe
Don't if you are not sure of the application to open a file.Download
"Irfanview".below is the link
http://fileforum.betanews.com/sendfile/1099412658/1/1262777908.514057fe0774684918afa85f23fdb31b3a1511ce/irfanview_plugins_425_setup.exe
It will open almost any files.
That's it.
Jan 06, 2010 | Toshiba Satellite Pro L300 Notebook
I have a windows vista and can't open adobe digital
have you purchased your adobe digital editions? it should be comes with the serial key, if none request where you bought it, they should give you the keys.
See also if your adobe is compatible with your vista versiojn
Nov 14, 2009 | Microsoft Windows Vista Home Premium with...
Adobe reader error message
In Internet Explorer, when you click on a link to a pdf file,
you get the error message “Adobe Reader could not open ‘filename.fdf’ because it is either not a supported file type or because the file has been corrupted.”
This error is due to an issue with Adobe Acrobat viewing PDF files in a web browser.
Try the following:
1. Open Internet Explorer, go to Tools -> Internet Options and on the General tab to erase all temporary files, cookies and history data.
2. Under Internet Explorer -> Tools -> Internet Options, on the General tab click on Settings and make sure you select the option “Automatically” for checking for newer versions of the stored pages. Then attempt to open the PDC file again.
3. If solutions 1 and 2 do not work then uninstall Adobe Acrobat, then reinstall it again.
It seems that Acrobat 6 is more prone to this error so upgrading to Acrobat 7 may solve the problem.
All d best.
Any furthur help feel free to ask me again i will be more than happy to assist you.
Dec 22, 2008 | Adobe Acrobat 7.0 for PC
Computers & Internet Logo
11 people viewed this question
David Payne
David Payne
