Question about RoadPro AC/DC Power Inverter 2000/5000w
Ac fault light comes on my inverter when i turn it on
2 Suggested Answers
  • 3 Answers
SOURCE: roadpro rppi-1500w inverter fault light no AC output?
you have a burned resistor near the corner
Posted on May 29, 2010
What is the cause of the red fault light coming on whenever I turn on my Powertech Inverter mi-5112. I have no power from the unit when the DC source is 2 x 105 A/Hr batteries, showing 13.3 volts.
Remove any load that you might have on the inverter. Turn the inverter on and if this still happens, then the inverter needs repair/replacement. Also watch the battery voltage. If it drops more than 0.2 volts, then the batteries are likely discharged or defective.
Jul 08, 2015 | Inverter Electronics - Others
Xantrex power inverter 1750
The 14 AWG Positive wire should be connected to one side of a 30 A relay (typical fog lamp relay available at most automotive stores). The relay's other 30 A contact should be connected to the battery positive post via a 10 AWG (up to 6 ft/2 m)
Sep 07, 2008 | Xantrex Technology Xantrex Xpower 1750...
The inverter turns on and fans run for approximately 5 seconds and quit and the yellow led near the switch stays on but no115 volts AC output however the 5 volt DC works, any suggestions?
well the yellow light indicates a fault, the 5 volt USB is independent of the invert-er function, you kneed your unit serviced or possibly you have a low voltage cutout or high voltage protect ,check you manual for led fault indicator descriptions, battery voltages should be between 10.9 volts and 13.8 volts this can cause a fault if outside this range.
best regards Falco
Nov 03, 2013 | Black & Decker Electronics - Others
Inverter will not switch to invert when the ac power is turned off
I am assuming that no fault lights are showing on the remote panel, but if they are, then those indicate a problem, e.g. overtemp, or AC overload. If the former, allow the unit to cool down and/or provide more ventilation, and if the latter, reduce the AC load by turning things off. The inverter must be in "standby" mode (green inverter light slowly flashing) for the inverter function to come on automatically when the incoming AC is shut off. Also, the battery bank voltage must be between 10V and 15V for a 12V system, the inline battery fuse must not be blown, and the unit's pop-up breaker (on the right front of the box) must not be tripped.
Sep 24, 2010 | Xantrex Technology Heart Freedom 30...
After I hook up the power inverter to the battery, the AC product does not operate and/or the red FAULT light comes on.
It would depend on what type of AC product you'r trying t operate. While your load maybe only 1,000 watts, the starting inrush current may be too much for your inverter. Try turning inverter on, and see if it powers up. Try pluggin in something very small. Another possibility is the 12V circuit you're plugging the unit into isn't large enough to carry the current, and the incoming voltage is dropping too low for the unit to operate. A 1000 watt inverter is too large to plug into your cigeratte lighter unless you're only operating a very small load. Usually they are connected right to the battery. If you do this be sure to fuse it there , and run large enough wire to the inverter. You should probably have about a #4-#6 copper wire for such a large inverter.
Jul 12, 2010 | Black & Decker 1000w Power Inverter
I have 1750w mobile power inverter turn on light comes on then the falt light come on right away.
Like most Cheap square wave inverters, the mosfets can not take the inrush current.
Usually if the fault light comes on and there is NO voltage at the output, FIRST check the on board fuse, then check for any tell-tale burn spots, or areas where the components have heated up or burned.....if you get this far and all appears clear, then it is time to check the fets.
I would not reccomend any Motomaster Eliminator inverter other than the more costly sine wave unit....or stay with a 1kw unit and do not overload it.
It\s best to run as much as you can at 12vdc or higher...like 24vds. AC is nothing but problems.
Apr 10, 2010 | Eliminator MotoMaster Mobile Power...
RoadPro AC/DC Power Inverter 2000/5000w Logo
Top RoadPro Electronics - Others Experts
Craig Butler
Craig Butler
Are you a RoadPro Electronics - Other Expert? Answer questions, earn points and help others
