Question about Carrier 38CKC030 Air Conditioner
Carrier AC Compressor Fan will not turn on. Contactor will not engage. I have 24 Volts on both Blue and Brown on coil contacts? But if I push in the contactor switch it engages and comes on.
  • rottweilerjo May 13, 2009
    Did. I bought a new one and same thing.
  • 252 Answers
Bad contactor - replace
Posted on May 07, 2009
  • HANK MCNEIL May 13, 2009
    If you have 24v at the coil and the contacts are not closing you have a bad contactor. If the new one did the same it is bad too.
Compressor want come on
Here is what to do . Pull out or turn off Electrical disconnect behind unit . Carefully remove panel covering controls in unit . Note most units have a flat panel with a few screws, but some GE units have a welded metal box on top of unit which needs to be removed. After exposing controls. replace or turn on disconnect. Then take a plastic handled screwdriver and push in on center of contactor (boxlike part with a lot of wires hooked ) If the compressor now comes on release contactor , and check for 24 Volts AC at base of contactor where thermostat (small wires that run on outside of black refrigerant line ) with thermostat on and calling for cool you should measure 24 to 28 volts . If voltage is present replace contactor after disconnecting from power. If no voltage go inside , remove cover from thermostat, and check for 24 volts between red ( R) and yellow (Y ) terminals on thermostat , If voltage is present , replace thermostat , no voltage check voltage in heater / air handler if you have voltage at air handler , replace thermostat wire from heater to thermostat / if no voltage check for blown fuse in heater , this should be either an inline fuse or an automotive type fuse plugged into circuit board (with power to heater disconnected check broken wire or black mark in fuse when held up to light. If fuse good turn on power to heater and check for 230v to one side of transformer, if you get voltage to Primary (incoming side ) of transformer, check output side of transformer for 24 - 28 volts. If transformer shows input but no output replace transformer after turning power off. If you heard a buzzing or grinding noise , when pushing in contactor , but compressor didn't start look at run capacitor (this is round or oval shaped object with wires going to contactor and compressor ) Looking at area where wires plug this should be a flat surface , if it looks domed shaped or bulging out , it is blown and needs replaced , use same mfd rating and 440 Volts to be on safe side. / If there was no noise from compressor when contactor was pushed in , put your hand on top of compressor (black object in center of unit ) If hot , allow to cool for at least three hours with power to unit turned off and retest . If compressor comes on after cooling , check for bad fan motor in outside unit (it may make a squealing or wining noise and stop runing for a while , also check for / clean outdoor coils
Hope this helps .
Thanks,
Alex
Oct 04, 2014 | Carrier Comfort 3.0 Ton 13 Seer Ac Only...
Carrier puron 38txa a/c compressor will not turn on
Make sure there is power at the compressor, but first at the contactor (being supplied to contactor ). Power being supplied to contacter (line voltage) ?
Yes, then close contactor manually and if it works then check for 24 volts at the contactor coil. Find 24 volts, then you need a contactor.
No supply (line voltage), then check breaker
Breaker on, then check run capacitor and if good check high and low pressure protection.High pressure = trips on high head pressure (manual reset) then clean condenser coil.
Low pressure trips on low charge (auto reset on restored charge)
Sep 03, 2013 | Heating & Cooling
Ruud compressor relay not working a/c
Hello,im assumimg you are referring to the contactor coil on the oudoor unit. First you must verify if the coil is receiving 24 volts from the thermostat at the coil terminals, if not there is a problem with the low voltage circuit, possibly a a open thermostat wire or a fuse blown on the indoor control board. If ther is 24 volts at the contactor coil and it does not engages then the contactor coil must be replaced
May 24, 2012 | Ruud UAMB Air Conditioner
Compressor on Ruud Unit UAMA-042JAZ and its fan won't run. Electric comany said low voltage circuitboard problem. Suggested replacing the fuse on the circuitboard. I could not find a fuse, where...
The units has what you call a contactor which is actually a relay but it does not look like a relay. You can get a none conducting material to depress it. and the compressor should run and the fan. Be very careful since that contactor has exposed parts and it has 220 volts running through it. That contactor coils is energized by low voltage current usually around 12 to 24 volts and it is supplied by a small transformer near the evaporator in the attic. There is a contact and when the contactor is energized magnetic field pulls it in so the contact on the 220 volts touches and the AC unit runs. Another word of caution, do not turn the unit manually one after another. this may damaged the compressor. Wait a few minutes each time you manually push the contactor to see the problem. Good luck.
May 28, 2011 | Ruud UBHC Air Conditioner
Ac unit clicks outside but nothing engages fan or compressor on unit furnace still runs for heat setting and fan still blows but ac will not engage just hear a clicking was running for three days this...
Have you check the outside breaker? If its ok then you got a problem in your electrical system inside the unit probably the contactor is not engaging this is where the 24 volts from the thermostat calls for the 240 volts to run the condenser fan and compressor. Be careful checking this out because of the high voltage.
Jul 09, 2010 | Carrier 38CKC048 Air Conditioner
Turned unit on for first time, it will not kick on
does the indoor fan blow? If it does you are getting the 24 volts from the thermostat to the ouside contactor need to check your contactor in the oustide unit this is what kicks on the compressor it take the 24 volts and goes to 230 volts to run the compressor and condensor fan. check your schematic for the placement of the contactor.
Jun 04, 2010 | Carrier 38CKC030 Air Conditioner
Ac not working
The buzzing sound, along with the fan motor not running, usually indicates low voltage to the contactor and the contactor is not engaging or closing the points and it usually buzzes when this happens.
You first need to check and see if you are getting 24 volts to the contactor coil. You should at least have 21 volts, if not check for loose or dirty connections, if none, check the voltage at the transformer to see if you're getting 24 volts there.
Jun 04, 2010 | Heating & Cooling
Carrier central unit outdoor unit will not activate .i have replaced the voltage transformer inside , and the positive contact in the outdoor unit . my local ac man told me that i may have a problem with...
Hi, I would say to check for high voltage at the outdoor unit. You will have 24 volts from transformer on the secondary side of it, and high voltage on the primary side of the unit. @4volts are for all of the controls on the unit, contactor coil, all of the safetys, pressure switches high and low Ect. On a call for cooling, the stat sends power to the contactor coils, 24 volts to energize it and close the contacts and in turn starts the fan and compressor. Make sure you have high voltage at the unit. If not, check the main breaker, or the box mounted at the unit. Most will have 2 fuses in them that are behind a plastic cover. You can ohm them or just replace if your not sure. If you have power. If this is a split system central unit, check at the contactor for high voltage. If you have it, and it will not come on, you have to see if you are getting 24 volts to the contactor coil to pull in. If it does not, the problem is in the indoor unit unless this is a all in one outdoor unit. Please let me no, give me the details please.
Sincerely,
Shastalaker7
Apr 16, 2010 | Heating & Cooling
Have a Ruud AC unit the problem I have after installing a new condenser fan motor when I throw the circuit breaker the unit will not turn on but when I push the contacts on the contactor in manualy the fan...
The contactor engages from low voltage power from the thermostat as does the outside condensing unit. You may have blown the low voltage transformer or have a loose thermostat wire. Check line voltage(220 volts) to the transformer. Check load voltage(24 volts) from the transformer. If no voltage out,replace the transformer. If you have voltage out(24) check the thermostat wires and the thermostat. If you have a digital thermostat there is a 5 minute delay in the thermostat after power is restored before it activates.
Oct 08, 2009 | Ruud Central System Air Conditioner
My ac unit does not have power to the thermostat. There is 200 volts going into the transformer and 24 volts going out. There is 24 volts on the back side of a terminal with thermostat wire running to the...
Please exercise due caution in checking voltages in live circuits!
24 volts sourced by the transformer, through the thermostat, then through the contactor (turns on power to compressor/fan) and returns to the transformer, If the thermostat is closed (calling for cool) you will see no voltage across it, but instead the contactor should be energized. Please note, 200 volts seems odd, you should have between 215 and 235. It sounds more like the contactor relay coil may be open. Is the contactor/transformer one piece?
May 15, 2009 | Heating & Cooling
Carrier 38CKC030 Air Conditioner Logo
1,659 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
