Question about Bissell ProHeat Pet Upright Deep Cleaner, Purple, 89104
Automix piston installation - Bissell ProHeat Pet Upright Deep Cleaner, Purple, 89104
3 Suggested Answers
SOURCE: How to put automix piston back in place of a Bissell Power Steame
Called the Bissell Power Steamer customer service number and the CSR explained how to turn the water control knob counterclockwise 260 degrees until the automix piston grabbed hold. Worked like a charm. Thank you Bissell company.
Posted on Jun 19, 2009
heatman101
  • 43501 Answers
SOURCE: Automix knob and piston problem.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
45we
Posted on Sep 30, 2010
My bissell proheat pro tech 7920 does not use any shampoo although I have cleaned the bottle and valve
It may be the valve in the base of the machine, not the valve in the bottle. Flush well with clean water. Sometimes the jets get a little clogged up - especially if you don't use bissell solution - or if they get dirt in them. I cleaned them and mine worked again.
Feb 27, 2010 | Bissell 7920 ProHeat Pro-Tech Upright...
Jun 18, 2009 | Bissell 1697-7 Powersteamer Pro Deluxe...
heatman101
45we
Jan 05, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
The solution in my smart mix will not mix with water and the button just keeps going round and clicks and will not stop on either water or solution.
The smart mix knob is connected to a piston that slides up and down into the automix assembly. This piston has come off of the smartmix knob and left the unit on water only setting. Sometimes the smart mix knob breaks on the bottom side letting loose the piston.
This can be a difficult repair. You have to unscrew the flow indicator window and remove the fan and screen(pay attention to how they come out, most people want to put the pointed end of the white screen down. It goes up.) Place a piece of 2X4, a book, something underneath the machine, between the rear wheels. This will lift the wheels into the air, and keep everything in place when you remove the hood. Take the 6 screws out that hold the hood and lens. As you remove the hood try to do it slowly and pay special attention to any hoses that might try to pull off with it. If you don't get those hoses back into the right place, the machine will not work. The piston will probably be stuck into the automix assembly when you get the hood off. It is a three inch black cylinder with an O ring on it. If you hold the hood upside down and place the cornered side of the piston into the corner of the housing between the knob and the solution chamber, you should be able to hook the winding on the knob with the piston and then turn the knob to screw the piston down into the windings. It won't lock into place, but hold it there well enough to put the machine back together correctly.
If you feel like you're forcing something when putting the hood back on, you probably are, so stop and check to make sure all the hoses are where they are supposed to be.
Good Luck
Nov 25, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Bissell 7901 proheat solution wont mix
Good Luck
MOD 1699-f reassemble cleaner fluid mix switch
This is one of the most difficult machines to work on, but I can help you to reassemble the the "Automix Assembly." There is a black piston with an O ring on it that has to be put in place before the hood is put back on. This part will actually set inside the windings on the smart mix knob, before the hood is placed on the machine, and as you place it on the machine, the piston will have to slide down in the hole on the automix. Getting the piston into the windings can be a little tricky. You might have to play with it a bit and it doesn't lock into place. It just sits in there loosely, just enought to hold it in place while you put the unit back together. It's hard to describe how to place the piston in the windings of the knob, but I'll give it a try. Hold the hood upside down and place the squared corner of the piston into the squared corner of the hood between the knob and where the solution tank would sit on the opposite side. Now you can turn the know and screw the piston down into positon and the hood is ready to install.
Hit: put a book or peice of 2X4 under the unit between the rear wheels to lift the wheels off the work surface and help line everything up. If the hood doesn't feel like it is seating into place correctly, something is wrong. Very important on this machine: if even one hose is slightly out of place it with not pump. If it doesn't pump alway check the attachments to see if they pump. It they don't, then you might have a clogged heater.
Good Luck
Nov 20, 2008 | Bissell 1699 ProHeat Clear View Upright...
I THINK THE SMART MIX PISTON IS INSTALLEDS WRONG
it has the rubber seal and the container releases fluid when it depressed.... bipolar lol..
fill it with hot water and prime the machine.. don't use soap just try lear the lines.. always run hot water through your machine to clear the lines before storage.. and to maintain prime
Oct 16, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Bissel 7920 Diverter Valve Install
With the top cover off, turn it over, put the knob in the water only setting, the piston will fit in the slot (only one way), turn the knob some so it will stay on. Put the cover back on, but just before you push it down, turn the knob to the water only setting again, then push the top cover all of the way down. Turn the knob, you can feel if it is in the chamber or not. If not, it won't turn or be hard to turn.
Sep 16, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Will not spray water or cleaner
When you put the top back on, the smart mix vale should be on the clear water setting. Make sure that the piston is on the smart mix know under the top.
Jan 02, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
No water out bottom..
Pump may be bad, also the cap for the flow indictor may be leaking air. Does the automix vale knob turn easily? If it turns real hard, then piston that the knob works may be jammed. Ckeck the seals on the bottom of both tanks to make sure they are on the tank and not sitting in the holes.
Oct 04, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissell ProHeat Pet Upright Deep Cleaner, Purple, 89104 Logo
61 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
