Question about HP Computers & Internet
My monitor display keeps randomly flashing light to dark
My computer says both the monitor and graphics card are functioning normally
  • 1 more comment
  • seacreeks May 12, 2009
    my problem is that the screen dims and then brightens with no rhyme or reason. It just flickers back and forth back and forth.
    as I said the computer tells me that the monitor and video card are functioning
  • seacreeks May 14, 2009
    Thank you very much. I will try your suggestions and see what happens. Makes sense.
  • Ben Wabnick
    Ben Wabnick May 11, 2010
    is there a way to disable messages on your monitor, so of them have that option.
  • HP Master
  • 2,404 Answers
Don't always go by what diagnostics tell you because all it basically checks for is to see if it recognizes the devices. My advice would be to hook up a different known good working monitor to the computer and see if still goes dim on you.
If a different monitor is going dim on you intermittenly then you know for sure at that point its not the monitor and it would have to be the video card.
Try that and let me know how that goes. Keep in mind that video cards sometimes go bad and they go bad by overheating.
Monitors can go bad cause of bad capacitors which is why im suggesting don't always go by what the computer is telling you.
Posted on May 12, 2009
One of the two monitors will cease displaying screen image and begin rotating between a BLACK/WHITE/GRAY/Primary Color Bars every other second following a few minutes after start up. Have tried Restar
It might be the input from the graphics card. Try swapping the two monitors' feeds to see if the problem is with the monitor or the card. The monitor seems to be going into a screensaver mode since there's no signal. The flashing light could mean there's a power supply problem, or no signal.
Oct 15, 2017 | DoubleSight Displays Computers & Internet
My emx-mcp61p-avl has power but no display no beep. video card is new and compatible with my motherboard. RAM is new also.
Just because the ram and video card is new does not mean they work. But since you say it has power, I'm assuming it boots up all the way except the screen is not displaying.
If this is a laptop try the steps below.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
If it is a desktop try the steps below.
Try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor shows the display, then your original monitor is bad. If the Borrowed monitor does and same as your original monitor and does not show a display then your video card has an issue.
May 30, 2012 | Computers & Internet
Dark sgreen
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 25, 2012 | Dell Latitude C610 Notebook
Dark screen
May 23, 2012 | Computers & Internet
Can i install graphics card in asus k53f laptop
Umm, better let a repair shop do that. How do you know your video card is bad? Have you tested with an external monitor?
May 14, 2012 | ASUS Computers & Internet
No Graphics
May 06, 2012 | Sony VAIO Digital Studio PCV-RS220 PC...
Hp laptop dark display
May 05, 2012 | Computers & Internet
Screen dark
Have you tried to brighten it by the keys on the keyboard? Most times you have to Press and Hold the FN function key located at the lower left portion of the keyboard then hit the key that brightens the display.
If that does not work then try the steps below.
Apr 30, 2012 | Computers & Internet
I have video issue with my hp pavillion dv6000.
If you have the Nvidia Graphics Video Card in your dv6000 then you have a well known and documented manufacturer's defect talked about all over the internet. The Nvidia Graphics Video card will have to be reflowed, which requires taking the laptop apart.
Mar 31, 2012 | Computers & Internet
Computers & Internet Logo
572 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
