Standby light keeps blinking. tv wont turn on
Kp53xbr45 standby light keeps blinking. tv doesnt turn on or nothing. the light just keeps blinking for a good 2 mins and then just stops.
I have a Sony TV and it want come on. You press the power button and the green light blinks 6 times then the red light will blink right after. Is there a way I can fix it myself?
Posted on Jul 30, 2011
  • 19,396 Answers
If the TV goes off completely, then is usually a faulty power board.
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
Posted on May 07, 2009
Samsung TV not turning ON. My email address is prk Please help... Much appreciated.
Its power supply I will tell you how to fix you need to get few things first
Jan 29, 2016 | Samsung Televison & Video
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
Tv does not come up standby light keeps blinking
It seems there is no information in the manual here http://www.finluxdirect.com/content/ebiz/shop/resources/pdf/46S8030-T.pdf
So you may want to attempt to talk to their support. They have free on line chat here Finlux Direct Help Centre
Good Luck
Apr 10, 2014 | Finlux 46S8070-T 46" LED TV 1920x1080, 100...
My tv wont turn on by power button or remote. white light keep blinking.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 14, 2013 | Sharp AQUOS LC-60LE632U 60-inch 1080p LED...
My LG 37LG50 TV wont turn on ?
Are you certain the replacement power supply is good? A defective main board or power supply can cause this problem.
May 04, 2013 | LG 37LG50 37 in. LCD HDTV
My sony trinitron tv wont turn on and standby light keeps blinking
Hi
Blinking of standby light in Sony sets are fault indication. The number of blinks occurs at one instance must be counted. With that bumber I can reach to the fault section inside its circuit; sometimes to the exact fault point too. Just turn OFF the set, and turn it ON, and count the number of blinks at a time [do this atleast 3times and make it sure]; and inform me by Fixya. OK.
Jul 07, 2011 | Televison & Video
Can't get my Panasonic LCD out of Standby.
I only have two solutions. Either, turn the tv on from the tv. or try checking the tv connection. If that doesnt work maybe the remote is out of battery.
Sep 14, 2009 | Televison & Video
The screen won't turn on. The tv just clicks and
The power board ic coverter it dead.
U need to replace the power board.
U can go the web and buy this board changes
or get the tv repair man replace part and labor $575.
Aug 13, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Tv wont turn
The blinking red light at the the front of the television is the "Diagnostic STANDBY/TIMER LED".
This little red light will blink 2, 4, or 5 times and then stay off for three-seconds. And blink again for 2, 4, or 5 times. This cycle repeats. The most common diagnostic code is the 4-blink code.
When the red LED blinks 4-times, it means one of two possible causes:
1) +13V is not supplied on the A-board. Or, 2) IC502 is faulty.
It is best to take this television set to a repair facility and ask that the +13V power supply be repaired.
The copper tracks and integrated circuit pads are very thin and delicate on the KV-24FV12 circuit board, and will easily lift off of the circuit board, if the incorrect desoldering tool is used. Unless one has a good quality PACE vacuum desoldering unit, one should not attempt to repair the television.
Aug 17, 2008 | Sony KV-24FV12 24" TV
Televison & Video Logo
704 people viewed this question
Top Televison & Video Experts
Electro Med Services...
