Question about Philco 841205 Turntable
Philco 841.205 TurnTable spring and plastic armature pulled off HELP
Philco 841.205: My Father pulled the phono arm over to the right to start it up but the unit was off and the time. When this happened we heard a small click, and the phono arm no longer turns the unti on or off. I took the 3 screws out from the turn table and detached the turntable from unit. Here it what I found: There was a white plastic, 45degree shaped, armature hanging on a long metal pin that connected it to the on/off switch for Truntable. On the Phono arm was another plastic piece with a small return spring hanging off of it. Nothing looks broken, its just that this long pin and plastic armature SOMEHOW fit together with the return spring to keep ridged tension on the long metal pin but HOW. I have tried all configurations and can not get the return spring to stay connected and work. If I could see picture of this I could put it back together or maybe a manual. I am stumped HELP!! Thanks, Tony
  • Tony7883 Oct 10, 2007
    upon closer inspection, it looks like the white plastic 45 degree armature piece seemed to have wear marks which matched the point of the set-screw which is on the white plastic base of the bottom of the phono-arm. When those wear marks were lined up, that lead me to see a small jagged edge left on the main white plastic base of the phono-arm. When I married the 45 degree piece up with the plastic on the base of the phono-arm, it appeared to be a good match.
    SO NOW my question is. Does anyone know if this 45 degree plastic piece is supposed to be molded or gluded to the plastic base piece of the phono-arm? Again..if anyone has a picture of the mechanical pieces and connectors (return spring,set-screw, & plastic connectors) of this turntable arm that would be great.
    Thanks again
    Tony
I have the answer to your problem but after typing it for 15 minutes I could not get it sent because the send code wasn't right and I lost everything. Email me at lberzan@sbcglobal.net and I will try again. I have pictures
Larry
Posted on Feb 08, 2009
Well it turned out that that 45 degree plastic piece DID or WAS attached to the main post. It snapped off. I super glued it back on and to each side of that very flimzy broken plastic I cut two very small pieces of wood (using popsicle sticks) and super glued THOSE to either side of the broken armature piece. Once dried I re-attached the spring and it worksd like a charm.
Posted on Oct 25, 2007
With phono, I only get sound from one speaker, but no problem with tuner. Any ideas?
You can start to troubleshoot the issue.
Change the phono plugs reversing right/left. Does the working speaker change? If yes, problem is in turntable or cartridge. If no, problem is in your receiver.
If the problem is in the turntable or cartridge, pull the cartridge off. Is it directly plugged into the arm, or does it have 4 wires on it? If wires, swap right/left. Change in speaker? No? Problem in turntable wires. Yes? Replace cartridge.
If it's plugged directly into the arm, clean the connections with a pencil eraser (gently). Fixed? No? Try connecting turntable to a different receiver, comment.
What we're trying to do is to isolate where the problem is, so you know what to replace or fix.
Oct 02, 2015 | Audio Players & Recorders
The turntable on my philco cd cassette and turntable unit does not turn. how to i access the belt, etc. to see whats wrong?
I had a similar issue with my Crosley turntable that I recently picked up... and after digging up the manual online all I had to do was lift up on the tone arm and move it to the right (past the holding mechanism) until it clicked, and voila, the turntable started spinning again.
I hope this helps!
Sep 18, 2010 | Philco (R) Classic Turntable CD Shelf...
How do you get the turntable to start turning? We just got a Philco turntable and can't find a switch to get the turntable to turn. We got it used so don't have the instruction manual.
A lot of turntables start moving when the arm is moved to the record start. The turntable should move when you move the arm to the edge of the platter, even with no record. If it doesn't, listen to see if the motor spins. Then lift up the platter matt to see if the belt has slipped off.
May 06, 2010 | Philco (R) 841.205 CD Shelf System
I have a Philco Classic ... the turntable did not work. I pulled the arm back, as suggested, and it worked! But it really drags when I try to play an LP. What now?
what do you mean it drags? I noticed if you don't pull the arm back far enough,it will turn on,but the arm will drag foward scratching your record. Try pulling it bacl ALL the way and then it should give you no problems.
Sep 29, 2009 | Philco (R) Classic Turntable CD Shelf...
How to turn on turntable on Philco Turntable CD Player
Just pull the arm back a little bit, the turntable should then start.
Apr 20, 2009 | Philco (R) Classic Turntable CD Shelf...
I have Philco 841.169 model and when I press the phono button so I can play an LP, it keeps showing the word "LINE" what does this mean and how I can start my turntable?
about 3% of the time the 'brains' get scrambled, try unplugging it from the wall for a few minutes, sometimes this will 'fix' it.
if so, a power surge from your power company might have got it confused, if the problem continues try a surge protector power strip.
Dec 20, 2008 | Philco 841.169 Turntable
Turntable does not rotate when switched 'on'.
K, I'm not familiar with that particular stereo unit but there were a lot of stereos from years gone past that used a turntable made by BSR. When you activate the switch to start the turntable listen closely to the record platter for a hum or possibly the sound of a motor turning (they're quite quiet). Is the switch lever you pull rectangular made of black plastic, you pull it towards you one click to start the record and pull it one step further (spring loaded) to make the tone arm lift from the record automatically? Just want to make sure I'm talking about the right turntable before we continue.
Oct 10, 2008 | Audio Players & Recorders
Philco suitcase turntable / cd belt drive
Place the rubber band around the turntable and put a paper clip, bent up behind the rubber band. Start the turntable on it's spindle and you will be able to view that drive spindle on the right side, slowly pull the rubber band with the paperclip and drop over the drive spindle. remove paperclip and push turntable down seating it and replace the lock snap.
Jan 27, 2008 | Philco (R) Suitcase CD Shelf System
Hoe do operate the turn table
Lift the arm off the stand and manually move it to the center of the player. You should hear a click and the turntable will begin spinning. To turn it off move the arm to the outside until you hear a click.
Nov 13, 2007 | Philco (R) 841.205 CD Shelf System
Philco 841205 Turntable Logo
619 people viewed this question
Top Philco Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steven Wander
Steven Wander
Are you a Philco Audio Player and Recorder Expert? Answer questions, earn points and help others
