Question about Danby DDR4009EE Dehumidifier
Danby DDR4009EE green light flashes but can not turn uni on
I have a danby dehumidifier...when I turn it on the fan goes on, but the actual dehumidier does not...the light about the first button does not light up. What Can i do?
It's probably in the wrong mode. This could be from a number of causes including you have not emptied the water chamber.
Aug 13, 2014 | Danby Dehumidifiers
I have misplaced my operating instructions for my Danby dehumidifier model DDR 3008 EE. When I plug it in, turn it on, it runs for maybe a minute then the red full water tank lights up and it quits. The...
The model number you listed did not reveal anything. However, the link below is a link to a Danby model, that had a model number closest to yous. Most of the units have the same parts and function. Click n the literature tab and the Owners Manual will come up.
http://www.danby.com/product/DDR30E/12
Hope this helps you. Please let me know.
May 15, 2011 | Danby Dehumidifiers
Were is the filter located and how is it removed for cleaning
Access to the air intake filter can be gained by pulling out the filter holder, which is located on the right side of the unit, on the same level as the louvers on the front.
Since you model has been discontinued, I am providing a link to you Owners Manual, that you can download and print for future reference.
http://www.danby.ca/cms/uploads/products/en_manual/DDR2509%2C_3009%2C_4009EE_EFOM.pdf
Hope this helped you. Please let me know. Thanks.
May 09, 2011 | Danby DDR4009EE Dehumidifier
Flashing green light stays on, unit won't start when you press the on/off button
I believe the unit needs to me reset to the manufacturer's default settings. To do this, turn the Master ON/OFF Switch to OFF and unplug the unit from the outlet for 10 - 15 minutes. Then plug the unit back into the wall outlet and turn the Master ON/OFF Switch to ON. The green light will blink until you change the humidity setting to below what the humidity level is in your home. If you set it higher, it will not turn ON or will turn ON only for a couple of minutes.
Also, check the position of the water collection bucket, to make sure that it's installed properly and has triggered the safety device.
To help you more, I have included a link to your Owners Manual that you can download and print for future reference, if you have misplaced yours. Take good care of your unit and perform routine maintenance regularly. As Danby has discontinued (retired) your model humidifier.
http://www.danby.ca/cms/uploads/products/en_manual/DDR4007EE2.pdf
May 06, 2011 | Danby DDR4007EE Dehumidifier
P1 constantly goes on throughout the day. I do not know if I have the setting right or if the drain hose is connected properly.
First, the drain hose should not be longer than 5 feet and should be draining downward, with no kings or bends in the hose, The dehumidifier does not have a pump. It relies on gravity to drain the water.
As far as it running all day is concerned, some dehumidifiers have a "Constant" or "Continual" setting. Which means it runs constantly. Either while dehumidifying or defrosting. In addition, most Danby dehumidifier models are designed to have the fan run even when the compressor is not running. This is in order to circulate the air in the room and make the unit work more efficiently. This is a standard feature and cannot be programmed to stop.
Hope this answered you questions.
Apr 24, 2011 | Danby DDR4009EE Dehumidifier
What does p1 on the screen mean
Clean the filter and reset it.Still the problem persists, check the speed of F.M.
Dec 02, 2010 | Danby DDR4009EE Dehumidifier
All the lights are on and the dehumidifier isn't working
There are many reasons for a dehumidifier2_bing.gif to not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier2_bing.gif.
Dehumidifier is running but no water is in bucket
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Jun 06, 2010 | Danby DDR4009EE Dehumidifier
My model is DDR4009EE, after it run for a while, the display changed from RH to "P1",what does "P1" mean?
My Danby DDR657EE shows P1 periodically also. So, I called Danby.
Danby's Consumer Help Line (1-800-263-2629) is always busy. So, I called their General number: 419-425-8627. The receptionist transferred my call to their Service dept. My call was answered in 2 minutes.
The Service Rep. described the following code for my dehumidifier model (DDR657EE):
P1 = Defrosting: the unit will go into Defrost mode periodically to ensure that the parts are working at the right operating temperature. It should be in Defrost (P1) mode for only a brief period of time. If the unit is in Defrost (P1) mode continuously for a couple of hours (or more), then you should call Danby Service for further assistance.
He had no documentation of a P2 code for my model.
He also described other General Codes (applicable to most Danby Dehumidifier/Humidifier models):
E1 = Not enough water
E2 = Not draining
E3 = Water temperature too cool
E4 = Overflow Switch activated
E6 / E7 = Problem with Temperature Sensor
So, if you see P1 periodically (for brief periods), then it would be normal.
Also, here is a link to Danby's FAQ page for Dehumidifiers (which answers some common questions):
https://www.danby.com/faqs.php?cat=12
I hope that helps.
May 11, 2009 | Dehumidifiers
Damby ddr451
Check your tank. Remove it and look to be sure that there isn't any shipping foam or foreign objects in the area which may be keeping the safety switch open. If the area is clear check the switch to make sure that it is not stuck and it moves freely. If that is OK replace the tank and make sure that it is installed completely and correctly. Try it again. If it still does not work I would take it back to the store and have them check it out under the warranty. Good luck.
Jun 29, 2006 | Danby DDR451 Dehumidifier
Danby DDR4009EE Dehumidifier Logo
29 people viewed this question
Top Danby Dehumidifiers Experts
Bill Long
Colin Stickland
Colin Stickland
Gil Shultz
Are you a Danby Dehumidifier Expert? Answer questions, earn points and help others
