Question about Lands Phones
Ihave no display on my handset. My model is KX-TG5672. I have three handsets and display is good on two.
  • icare66 May 07, 2009
    no display on handset
  • 526 Answers
I am assuming that everything but the display is working on the handset, if nothing works, I will have to say that you have a bad battery or charging unit, otherwise,
if its not the contract setting,
LCD contrast
(Display contrast)
feature code 01
Level 1–6 (default is <3>), then you have a bad lcd screen.
Those do not get fixed. You will need to call panasonic and see if you can do an out of warranty exchange if its out of warranty.
Unfortunately, those are the only possibilities.
thanks adi
Posted on May 07, 2009
  • adi May 07, 2009
    here is the part # for the LCD display
    L5DCBYY00003
    you can order it from panasonic.
    to order from panasonic
    go to
    www.pstc.panasonic.com
  • 19,396 Answers
Unplug base from power and remove battery from the handset.
then put back the battery, place the handset on the base, and reconnect power.
If the hadset display is still blank, then the handset is faulty.
In that case contact Panasonic ringing the number listed on the owners manual to get a replacement handset.
Don,t forget to leave feedback.
thanks.
  • Ginko
    Ginko May 07, 2009
    No display on handset is either fixed by resetting the phone, as I told you (unplugging), or it is a faulty handset, in that case you usually replace the handset, unless you want to take it apart, tet voltages on LCD ribbon cable and components on pcb.
    Regards.
Would like to know if I can get a replacement phone model kxtg5632anasonic
You should be able to find it on ebay
http://www.ebay.com/itm/Panasonic-KX-TGA560-kx-tg5632-Accessory-handset-kx-tga560b-KX-TG5673-KX-TG5672-/390677723382
Oct 21, 2013 | HP Pavilion dv6000z Notebook
Manual for Panasonic Handset KX-TGA560B
For the KX-TG5672, you should press and hold the Intercom button until the charge indicator flashes. Then press the button to assign the handset # 1, 2 or 3 (keypad 1, 2 or 3). Then press OK on the handset and wait for the handset to beep. These steps must be done within a minute from when the charge indicator flashes. It's best to have the base and the handset close together when you register the handset.
Panasonic has the manual for the TX-TGA560 available here: http://service.us.panasonic.com/OPERMANPDF/KXTGA560-MULTI.PDF . (This manual covers both the KX-TGA560B and KX-TGA560M.) The manual for the KX-TG5672 is available here: http://service.us.panasonic.com/OPERMANPDF/KXTG5671S.pdf .
If you still have a problem, try removing the battery from the handset and disconnecting the power cord from the base (from the wall and the base itself). Wait a few minutes and then reconnect the power cord and the battery for the handset. (Make sure that the base has power and the adapter is warm.) Then try registering again.
I hope this helps.
Jan 03, 2012 | Computers & Internet
My phone display's No link to base. Reconnect main bas AC adapter. It is plugged in what now?
I had this problem, and I fixed it by re-registering the phone to the base. Here are the directions for how to do that from the manual:
Registering a handset to the
base unit
The supplied handset and base unit are
pre-registered. If for some reason the
handset is not registered to the base
unit, re-register the handset.
1 Handset:
{MENU}
2 {V}/{^}: "Initial setting"
{OK}
3 {V}/{^}: "Registration"
{OK}
4 {V}/{^}: "HS registration"
{OK}
5 Base unit:
- KX-TG4011 series:
Press and hold {LOCATOR} for
about 5 seconds. (No registration
tone)
- KX-TG4021/KX-TG4071 series:
about 5 seconds until the
registration tone sounds.
If all registered handsets start
ringing, press the same button to
stop. Then repeat this step.
The next step must be completed
within 90 seconds.
6 Handset:
Press {OK}, then wait until a long
beep sounds.
Note:
While registering, "Base in
registering mode" is displayed on
all registered handsets.
When you purchase an additional
handset, refer to the additional
handset's installation manual for
registration.
See http://service.us.panasonic.com/OPERMANPDF/KXTG4011-MUL.PDF (page 22)
Dec 06, 2011 | Panasonic KX-TG1033S Cordless Phone
How can i do two way on panasonic 5.8ghz
These directions are for the KX-TG5451, KX-TG5452 and KX-TG5453.
If you want to use the intercom feature, you need to know the handset number for the unit you want to contact. The base is zero. The handset number is set when you register the handsets. So to communicate with the base, press Intercom on the handset followed 0. The base will ring until someone presses Call to answer it (or one minute whichever comes first). (Alternatively, you can use the up/down arrows to select H1, H2, H3 or Base. Then press the right arrow key.)
To communicate between two handsets, press Intercom and then 2 (from handset 1 or 3 to connect with handset 2). Again the handset will ring for one minute or until the person with handset 2 answers. (To answer, they can press the phone, speaker or intercom button.)
If someone at the base wants to use the intercom, they need to press Select until the appropriate handset number is displayed. Then press Call.
To transfer a call, press Intercom and then select the desired handset. When the intercom message is picked up, indicate that a call is being transferred and press Off at the handset or base that initially answered the call.
For a conference call, initiate the call then press Intercom and select the handset to join the conversation. Once that person picks up, then press Conf. (I believe that Conf is a softkey so check the display.) This is only possible with the handset. (Another handset can join the conference by pressing the phone or speaker button on that unit.)
The manual for the KXTG5453 is available here: http://service.us.panasonic.com/OPERMANPDF/KXTG5451S.PDF .
If you have a different model of the Panasonic 5.8 GHz phone, please add a comment with the model number and I'll try to give the directions for that unit.
I hope this helps.
Aug 11, 2011 | Panasonic KX-TG5453PK 5.8 GHz DSS Cordless...
I am looking for the KX-TG5672 manual, I have lost mine thanks. I can't find that choice in the manual list
It's a Pana trick :-) They group the 5671/5672/5673 together as it only differs in the number of handsets that come with the cordless kit. http://www.barclayent.com/manuals/Panasonic%20KX-TG5671.PDF
Carl
May 07, 2011 | Panasonic KX-TG2740 Cordless Phone
Display screen shows "Will return soon" Would like
You need to cancel absent message on your phone. The method depends on which Panasonic phone system your phone is connected to. Following are the methods for three different Panasonic phone systems. Once you cancel absent message, your screen should return to date and time, if not then press * until it does.
KX-TA624 Phone System
Press intercom button, dial 750#, lift handset then return handset to cradle to end.
KX-TA1232 Phone System
Press intercom button, dial 7500, lift hanset then return hansdset to cradle to end.
KX-TDA100 or KX-TDA200 Phone Systems
Press intercom button, dial *7500, lift handset then return handset to cradle to end.
Jan 27, 2011 | Panasonic KX-T7633 Corded Phone
Own model KX-TG6031CM. Handset display is lit up
need access code to retrieve messages for kx-tg6031cm panasonic phone
Jan 23, 2010 | Panasonic Lands Phones
Cannot turn off audio caller ID
Try the manual:
http://service.us.panasonic.com/OPERMANPDF/KXTG5671S.PDF
On page 35 it lists how to turn off talking cid for both the handset (90) and base (0*40).
Carl
Feb 28, 2009 | Panasonic KX-TG5672 Twin Cordless Phone
Re-registering the Handset is not working
The solution is this - unplug the base unit then plug it back in. After that it worked fine.
Jun 22, 2008 | Panasonic KX-TG2356 Cordless Phone
Lands Phones Logo
171 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
