Question about Yamaha 2006 VK Professional
How to change battery in Yamaha VK Pro 2006 model
Can't start my 2008 yamaha 540 was cold that day ran out gas put gas. Didn't start
Try lots of gas line antifreeze and change the fuel filter. Spark plugs should be dry, you may have plugged filter or water in the gas or both
Jan 28, 2015 | Yamaha 2005 VK 540 III Base
2007 vk professional running hot,engine light on,codes 21,84 on
I have the book but I cant find the codes.
So find out if your rad fan is coming on. If it does then pull out your thermostat and place it in a pot of water and see at what temp it opens at. The open temp should be stamped on the thermostat.
If it is stuck closed or opening to slow, replace stat.
Mar 15, 2014 | Yamaha 2006 VK Professional
Where do you add gear oil on a 2006 yamaha vk pro
There should be a dip stick on the chain case remove it and add oil there. until it is full on the shight glass.
Hope this helps.
Feb 15, 2014 | Yamaha 2006 VK Professional
Engine missing
Take it to Dealer.
Feb 14, 2014 | Yamaha Winter Sports
Need to install a "black" battery cable on 2006 650cc vstar
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
How to Change the Battery on Yamaha VStar 650 eHow
Yamaha 650 Star Needs New Battery
98 00 Yamaha XV650 Star Service Manual XVS650 Moto Data Project
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2003/LIT-11626-16-05_22.pdf
Feb 07, 2014 | 2006 Yamaha V Star Classic
How to adjust gear chain on Yamaha VK pro
Locate chain tension bolt.
Loosen locknut.
With 2 fingers tighten the lock bolt until it is tight.(not crazy tight)
Then back off the lock bolt 1/4 of a turn.
Hold bolt and tighten lock nut.
You are done now.
Dec 29, 2013 | Yamaha 2006 VK Professional
No spark on my yz 125 2006 model
check change spark plug. check ht lead and cap. check earth to engine from battery
Feb 17, 2013 | 2006 Yamaha yZ 125
2006 yamaha yz 450f oil change
Hi, Keith for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere zero $ you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Oil Change Procedure for 06 09 Model YZ450
How to do an Oil change on Yamaha WR450F or yz450f mod 2008 5QJ8H
YAMAHA YZ450F Owner Service Manual
http://www.yamaha-motor.com/assets/service/manuals/2007/lit-11626-20-13_yfz450_1285.pdf
May 21, 2012 | 2006 Yamaha YZ 450F 50th Anniversary
2006 Yamaha Stratoliner replace the battery
Hi, Joe9200 for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Roadliner Stratoliner battery replacement
how to put new battery in 2008 yamaha roadliner
Yamaha XV19SW Service Manual
Yamaha ROADLINER XV19SW Owner Manual
May 02, 2010 | 2006 Yamaha Stratoliner
Yamaha 2006 VK Professional Logo
105 people viewed this question
Top Yamaha Winter Sports Experts
Arnie Burke
Arnie Burke
Mike
Are you a Yamaha Winter Sport Expert? Answer questions, earn points and help others
