LG F1222TD washing machine
- Pressing the buttons to change the spin and temperature and sometimes the start button operate intermittently. Machine 5 years old. Is this a known fault and is there a quick fix.
Noggin
  • 944 Answers
SOURCE: ge washing machine model wip4013srw how to fix the problem
Unidentified buzzing noise in top loader machines is often due to a jammed or seized drain pump, especially if the pump has its own motor - sometimes just opening the front of the pump (usually under a panel at the base of the front, possibly behind a small - 3-4 inch - panel to one side or other) will clear it. behind the pump cover will be a sealed plug or similar, usually needs a half turn to undo. small pieces of wood or plastic sometimes are the cause, and may be "floating" on the drum side of the drain pump so may not be visible immediately. Make sure the machine is unplugged and check with your fingers to see if the pump blades rotate freely - they will have some resistance, but should not feel like you are pressing against something solid. If you still have the manual for the machine, somewhere you would expect to find detailed instructions for a user to clear the pump - it is not usually a difficult or complicated job however some machines have a very different drain system. You may have a certain amount of water comes out over the floor - this is normal. On an optimistic note, many of these machines are still functioning after more than five years with no problems, so it is likely to be minor. If you suspect the electronic control to be the reason for the problem, it may just be that it will not continue a cycle without properly draining, even if the drum appears to be draining adequately - check the drain pump. The pulley attached with string is slightly unusual - perhaps this is as a result of an old bodged repair and needs to be resecured - without more detail or a photo this is hard to say. Best solution for that would be if you could find a similar machine, possibly in a second-hand shop and ask to look at the base to see if there is anything obviously different with your machine.
Posted on Feb 17, 2007
Bob Gemmell
  • 209 Answers
SOURCE: Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
Posted on Sep 13, 2007
SOURCE: bosch washing machine flashing red lights
all lights are flashing on bosch classixx express no thinh working no water intake door is locked what is the problem and can i do it myself
Posted on Jan 07, 2010
blueextc3221
  • 15935 Answers
SOURCE: OE fault displayed on spin cycle LG 1019BD 10KG WASHING MACHINE
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
LG themselves have some information on this error code..
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 13, 2010
SOURCE: how to use thomson washing machine tx 708
I misplaced the manual of my Thomson TX829, please can you advise where I can obtain a new copy.
Posted on Dec 05, 2010
How do unlock the washing machine IQ300
Do not open the washer door by force while it is operating (high-temperature washing, drying, or spinning). Within 5 minutes as you start a wash, it is possible to add/remove laundry items. Simply do the following: Step 1: Press the Start/Pause button to unlock the door
Mar 25, 2016 | Washing Machines
My lg wd-80134t does not spin
Try pressing the "Temp" and "Option" buttons simultaneously for 3 seconds, check if the machine will start, if not unplug the mains supply for a couple of minutes, replug and check whether all the buttons are working and that it will start.
Jun 04, 2015 | LG Washing Machines
Washer won't start - sometimes
Jason, take a look at this link and follow the steps very carefully. Were insulated golves. How to Fix an LG Front load washer machine that wont spin
Feb 28, 2014 | Frigidaire Washing Machines
Washer repeats entire cycle - does not stop at end of spin cycle.
It is possible that presence of moisture within the START button can trigger the cycle to continue as it keep the processor to continue the wash cycle,Hence you must remove the panel and board after disconnecting the wiring harness and use a hair dryer to warm off any presence of moisture on the panel and board. Do it with time to ensure there is no moisture within the panel.
I think this must solve the issue. Repeat the work many times as sometimes moisture and dirt together might form a conductive bond to trigger as a pressed on switch. If possible open panel to clean switch pad.
Jan 23, 2013 | Kenmore 2.1 cu. ft. Compact Portable...
My fisher and paykel top loading q washing machine won't start. It beeps and lights 5 and 8 come on. Any ideas what the issue might be?
That is fault code 9 machine not sized
9. (00001000) Size Switch Error
The Display size switch setting does not match that which is stored in memory.
Action GW Machines: Reselect the size of the machine by using the SIZE SETTING
MODE.
To set the size switch, turn the power on at the power point and off at
the console. Press and hold Wash Temperature Setting Up then
press Power. SmartDrive will give 4 short beeps and the pattern of
LEDs will change.
One of the following buttons needs to be pushed to lock the size into
memory.
• Press Wash Temperature Setting Up, the Cold LED is on for 5.5kg
(560mm wide).
• Press Water Level Up, the Low Water LED is on for 6.5kg / 7.0kg
(600mm wide).
517790C
35
• Press Spin Speed Up, the Spin Hold LED is on for 7.5 / 8.0kg
(650mm wide).
• Press Power to confirm the setting and also exit this mode.
Action IW Machines: To access Size Setting Mode, push and hold the Fabric Care button
and then press the Power button to enter Size Setting mode. Select
the correct size on the display by pushing the Adjust button to
highlight the correct size. Size setting is then achieved by pressing
the Power button. Powering off will set the size into the memory.
Note: Fault code 9 will only be logged into the memory of IW machines. GW and MW
machines can display this fault but it will not be recorded.
Aug 13, 2012 | Fisher and Paykel Washing Machines
Lg front loading washer flasing LE and stops midcycle
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
OVER SUDDSING
Jun 16, 2012 | LG WM-2277HW Front Load Washer
How do i change the language on my washing
Press and hold the drying,delay start/temp select buttons altogether for 5 sec untill you hear a beep, then release all 3. press the dely start button to scroll through the available languages then select your chosen language by pressing the drying button once.
Apr 07, 2010 | Hotpoint Ultima WD72 Front Load...
Reducing the noise when the washing machine is on spin cycle
Nothing is wrong w/ the unit. It must be solid on the floor with no movement in the feet relative to the flooring or it will rock when spinning. Floor is simply not solid enough. Use slower spin speed to alleviate issue or relocate it. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 28, 2008 | LG Washing Machines
LG Washing Machine All-in-One
Some magic happened today!
I got the thing (wd-12331ad) to dry without having to run a wash first!
Also, I seemed to get it to do a spin only run...
The way to get it to dry :
(for a set time - I've not managed to get any of the auto-dry settings to work)
from machine being off:
> press the power button.
> press the "Dry" button 'til "Time" lights up
>>> press "Dry" again to get the desired duration
> press the spin button 'til the spin speed shows blank/ the RPM light goes out.
> press "Start/Pause"
It will then dry for the number of minutes specified!
Not perfect, I know but that's serious progress from where I was before; having to re-run a wash cycle to get it to dry anything...
Something to note:
- The machine worryingly sounds like it's starting to fill with water when you start the "Just Dry" program which scared me at first. BUT it stops after a second or so (I think it's just cleaning out the detergent tray so it doesn't bake any leftover powder)
For "spin only" from machine being off:
>>> if you press "Start/Pause" now you get a 13 minute 1200 spin cycle
>>> press the spin button again and then "Start/Pause", it seems to drain itself for 1 minute
>>> pressing spin repeatedly, cycles through the spin speeds.
Things I don't know:
- I don't know if you can combine spin and heat.
- I don't know whether the auto-dry programs are available
- I don't know what other programs are available from the "Dry"/"Spin" buttons
...So if anyone does any experimenting, please let us know the results, you never know, we might end up with a half way useful set of instructions! I'm starting to think the machine's not half as bad as it seems when following the manual alone.
Hope that helps.
Will
Jan 03, 2008 | LG WD-12126RD Front Load Washer / Dryer
Washing Machines Logo
Top Washing Machines Experts
