Question about Black & Decker 7448 1/3 Sheet Orbital Finishing Sander
How to put sand paper on - Black & Decker 7448 1/3 Sheet Orbital Finishing Sander
Belt sander runs until I put pressure on it
It sounds like the sand paper itself is slipping. There should be an adjustment to tighten the pressure on the sand paper itself.
Feb 28, 2015 | Ridgid Makita 98462 9910 Belt Sander 120v...
Tip
How To Re-Wax a Wood Deck for a Trotter Treadmill
Following are instructions on how to re-wax a wood deck for a Trotter treadmill and a list of materials needed for this procedure
Materials Needed for Re-Wax
  • 1 lb. of Trotter deck wax
  • Clothes iron (never to be used on clothing again)
  • Belt sander with 120 grit sanding belt
  • Vibrating sander with 250 and 400 grit paper
Pre-Existing condition: If your wood Trotter treadmill deck is worn down through the first ply, it cannot be re-waxed.
  1. Using a belt sander and 120-grit belt, gently sand in the same direction as the grain the glazed layer off the top of the deck until you have reached porous wood. If, while sanding, the first layer of ply has been sanded off, the deck can no longer be re-waxed
  2. Using a vibrating sander with 250-grit paper, sand the entire top surface of the deck until it is smooth and soft.
  3. After sanding with the 250-grit paper, continue sanding with 400-grit paper until completely smooth.
  4. Heat the clothes iron to its maximum temperature. Put a handful of Trotter deck wax on the center surface of the deck and place the preheated iron on top of it until the wax melts.
  5. Work the wax into the deck surface by pushing the melted wax across the deck with the iron. Add more wax as needed until the entire top surface of the deck is impregnated with wax.
  6. Apply just enough wax until the wood is saturated with wax.
Do NOT leave wax pooling on the surface of the deck.
How To Re Wax Wood Trotter Treadmill Deck
on Mar 11, 2015 | Exercise & Fitness
Tip
How to Fix Foggy Tail Lights in BMW 528 car?
1) Stick the masking tape and paper around the tail light to take care of the paint. 2) Take care nothing gets rubbed on the car paint or nothing gets scratched on the car light cover and paint. 3) Do it gently without any force. 4) Take a sand paper make it wet and use the wet sand paper to sand the tail lights. 5) Do this sanding until all the dirt and fogginess is removed completely. 6) You can use heavy grit sand paper if the dirt is very hard to remove. 7) After sanding is done clean and rinse the tail light. 8) After cleaning is done ,apply a plastic material polish cream on the tail light and gently rub it till the tail lights shine. This will help.thanks.
on Mar 18, 2010 | BMW 528 Cars & Trucks
What is the gap for the fly wheel to cdi on a 4600 echo chain saw
The easy way is to put a piece of sand paper between the coil and magnet.Put it in tighten the coil and pull out the paper.
Feb 26, 2011 | Echo Garden
My printer is saying 'no paper feed' when there is clearly paper. The printer is not gripping the paper so it could print.
THe first thing to do would be to clean the pick up roller/s. If you can not reach them by hand, use a sheet of fine sand paper. put the sand paper in the paper tray so the gritty side will contact the feed roller. Then hold the paper in place while exicuting a test print. You wil get a jam, or papaer empty indicator. now do it again, and then one more time. Now remove the sand paper and use a damp thin cloth. make sure this is secured and will not be pulled into the machine. Now one more time run a test page. Now you should be good to go. If this did not solve the feed problem your feed rollers need to be replaced, or you have a paper present sensor problem. This could take some disassembly so let's try the easy stuff first.
Oct 06, 2010 | Brother MFC255CW All-in-One InkJet Printer
Tip
How to Fix Foggy Tail Lights in Avanti Convertible car?
on Mar 18, 2010 | Avanti Convertible Cars & Trucks
How do I change the sanding belt on my 7447 belt sander
To change the belt, you must release tension of the rollers by pushing the front roller straight back until you hear it click and lock in position to change paper. Remove old paper and replace with new paper. Make sure if new paper has directional arrows to install properly.
Now you must release the front roller to put tension on paper. To do this push the front roller from the side that has the adjustment screw. This will release the front roller and allow it to go back into position. Be careful as it pops back quickly and with some force.
Turn on sander and adjust centering of paper with adjustment screw found near the front and side of sander.
Aug 27, 2010 | Black & Decker 3"x21"HD Vs Belt Sander
1/4 palm Sander is not "collecting" dust even with a new sanding bag, what could be the problem?
Are you using the punch plate to put holes in the sand paper after you put on a new sheet?
If you are it could have an obstruction in the fan guide or the fan has broken fins. Both the punch plate and fan can be purchased by clicking on the below link.
http://www.ereplacementparts.com/makita-bo4552-finishing-sander-parts-c-97_103_482.html?osCsid=s71te2ssm60u2ga80vaqah9f85
Jun 23, 2010 | Makita 1/4 Sheet Finishing Sander with...
Sand paper not tight
it could be a dirt buildup in front of the yoke not allowing it to fully extend. could also be the rear roller is worn down, I would recommend going to Makitatools.com and downloading a breakdown to see how to remove the mechanism to clean . the yoke should snap when the lever is released to install the belt.
Mar 19, 2010 | Makita 9404 4'' x 24'' Belt Sander
Headlights are foggy inside how do i clean them
the fogginess is caused by oxidation on the outside. normal wear and tear.
This is what i did on my honda civic 1996- bought three sand paper 600-1500 and 2000. Bought plastic shine from autozone and some plastic gloves.
1) I cleaned it with diluted soap to get all the dirt out. Use soft cotton cloth to do this.
2) get some clean water and dip sand paper(600) and start sanding the headlight. sanding should be done in the same direction throughout. I used horizontal strokes. Don't let the sandpaper dry out.
3) clean it out with water so all the sand particles from the sanding is cleaned out.
4) start with the next grade sand paper and repeat the process till you are satisfied and the fogginess is gone.
5) clean it thoroughly with water and let it dry fully.
6) put in gloves and rub plastic shine all over the headlight and leave it to dry. Make sure it does touch the paint!! you can mask the sides to avoid that.
7) clean it with soft cotton or polishing cloth. It really works!!!
Also, stay away from direct sun while doing this. Having the hood up is helpful.
Lis
Jul 12, 2008 | 2001 Mercury Grand Marquis
Black & Decker 7448 1/3 Sheet Orbital Finishing Sander Logo
Top Black & Decker Tools & Hardware - Others Experts
Jim Goldsmith
Jim Goldsmith
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
