Question about Vizio P2 42 in. HD-Ready Plasma Television
Yellow tinted picture
When I turned on the TV it flashed then went blank for a few seconds. When the picture appeared it was yellow. I tried leaving unplugged for hours, checked inputs...etc.. to no avail. The picture clarity is still excellent. You can also differentiate red colored items for some reason. How much does it typically cost to repair? Thanks, Starrman
  • 87 Answers
Depending on the manufacture of your set there may not be anyone to service it.  Some manufactureres require you to ship the set to them for service.  The serial number will give you the inormation you need.  If the serial number is all digits the set is made by Akai and most parts are available from Fox International.  If the serial number is alpha numeric you need to call VIZIO OR V,INC. WEB SITE HTTP://VINC.COM. 1-888-849-8900. DECISION 1 IS THE DISPATCH COMPANY FOR THIS PRODUCT.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Posted on Oct 23, 2007
SOURCE:
Toshiba 46 inch regza yellow light blinks and picture wont come on but I have full audio
Most likely the power supply board needs to be replaced. It could also be the T-con board or less likely the display itself.
If you don't know what you're doing, DON'T OPEN THE TV UP TO FIX IT, THERE ARE HAZARDOUS VOLTAGES ON THE POWER SUPPLY BOARD, EVEN WEEKS AFTER THE TV IS UNPLUGGED!
If you don't know how to do it yourself, find some local Electronic repair shops, get quotes, try to find reviews on the shops.
Sep 21, 2016 | Toshiba Televison & Video
Panasonic rear projection tv has a yellow tint, and it just turned off by itself while the indicator light flashed yellow. What's wrong with it.
The yellow tint can be caused by a faulty lens where the filters are burnt out. Normally this happens when the blue filter burns you get a yellow picture on the screen.
Unfortunately, this can be expensive to repair.
Oct 23, 2012 | Televison & Video
No picture on screen
Is the TV under warranty? If it is don't muck around, contact them straight away as you have a electronic problem with your screen.
Before that make sure the yellow chord is in the visual port and red and white into sound. 2) If thats all good try an experiment, as you know the sound is good, use one of the sound cables to replace the yellow. Is there a picture now? If so replace chord, if not make contact to exchange for warranty.
Sep 02, 2012 | X2Gen MV32T8 32 in. LCD Television
My tv screen when on turns yellow then after a while it will switch back to normal colors what can be wrong with it....
Televisions covered: all Projection with yellow picture, but not Projection TVs with a yellowish tint surrounding objects in a nearly normal picture.
Yellow = red + green
normal picture = red + blue + green (RGB). See illustration.
Fig. 1 Additive color mixing in an RGB monitor, or RGB Projection TV.
The circuitry powering your blue output, or the blue light engine itself is starting to fail.
Operating Theory:
The lamp module shines a bright light into the optical unit; there are a series of lens and baffles, and at the top of the light engine, a lens puts the picture into a mirror which is reflected onto the screen; All video and color is processed thru the light engine. Blue most commonly fails first, leaving a yellow picture.
Dec 26, 2011 | Mitsubishi WS-55805 55" Rear Projection...
Picture has a yellow tint, was fine when I tuned it off yesterday but when I turned it on today it has a yellow tint that can't be corrected with the color settings PLEASE HELP
i have same problem.. a yellowish tent appearing on my tv.. when i switched it off before it was good.. but when i started it one day.. it was yellow.. wat to do?
Feb 27, 2010 | Sanyo Televison & Video
I have a philips dlp 55pl9773 has one red flashing led on the front when i do a hard reset tv boots up lamps lites led goes from flashing yellow to green for about ten seconds and then back to red flashing...
MY philips tv model number 55PL9773/17 WAS TURNING OFF THE SCREEN AND LEAVING THE AUDIO ON FOR ONE MINUTE. THEN THE YELLOW LIGHT STAYED ON. THEN THE LIGHT TURNED OFF. thEN I TURNED ON WITH THE REMOTE AND THE YELLOW LIGHT TURNED ON AND A FEW SECONDS LATER CHANGED TO THE GREEN LIGHT AND THE TV TURNED ON. AFTER A FEW MINUTES, BETWEEN 10 AND 30 IT DID THE SAME THING. NOW IT IS OFF WITH A BLINKING RED LIGHT PERMANENTLY ON. TO TURN IT OFF I HAVE TO UNPLUG IT FROM THE WALL. I REPLACE THE LAMP A FEW WEEKS AGO AND IT IS FINE.
Dec 01, 2009 | Philips 55PL9773 55" Rear Projection...
Yellow tint on right half of hdtv screen
The would be due to a faulty inverter that controls how much power is give to the display at a time so when these go out you will see this tint or black. So you can replace the inverter or bring it into a shop and have it replaced.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Jul 13, 2009 | Samsung LN-T4661F 46 in. LCD HDTV
Yellowish tint; lines through pictures
CCD going BAD call Samsung they will do it FREE of charge as it is a known problem after some time the pics will be total BLACK and BLANK pls call them and ask them about BAD CCD
Pls RATE ME WELL !
May 30, 2009 | Samsung i85 Digital Camera
ViewSonic VE710b 17 inch yellowed photograph look
Check and make sure that there is no speaker, power supply or UPS around your monitor.
Mar 16, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
Picture has green tint on startup
Jar-Head, bad news, the picture tube has a mild short in the green cathode, tech can come out and try to restore it but it`s usually a futile attempt on sony tubes, sorry to be the bearer of bad news, BMW Rider
Jan 14, 2008 | Sony KV-32S26 32" TV
Vizio P2 42 in. HD-Ready Plasma Television Logo
182 people viewed this question
Top Vizio Televison & Video Experts
Tony Nguyen
Tony Nguyen
Steve Allison
Steve Allison
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
