Question about Singer 7444 Mechanical Sewing Machine
What size bobbins do i need for 9005 - Singer 7444 Mechanical Sewing Machine
Need Bobbin size for Janome Jemsilver model 662
There are three sizes (classes) of bobbin that most machines use. If you have the old bobbin and can measure it this link will help you determine which class you need.
What Size Bobbin
Jul 19, 2014 | Janome Sewing Machines
Singer 9005
Turn off your machine, lift your pressor foot, take a ripper and cut away the extra threads, after all that has been removed you should be able to lift your needle up and out of your fabric. At that point you should be able to remove the fabric also. Check your bobbin case also. Remove it and wind a new bobbin .
Mar 05, 2014 | Sewing Machines
My bobbin doesnt spin in my singer 9005 and i need to know how to thread it so i can finally start sewing??
They have a free instruction manual download on singer website
On the homepage at the bottom look for instruction manual & click on it
It will take you to a page where there's a box put in the model number 9005
Then click search
The second one is a free download
Aug 24, 2011 | Sewing Machines
How do I insert the bobbin case in a Singer 9005 machine?
http://www.singerco.com/accessories/manuals.html
go to the above link, type in 9005 into the box, download the manual. use ctrl+f to open the find command, type in bobbin, go to section on bobbin.
May 03, 2011 | Singer 7444 Mechanical Sewing Machine
I have a Singer 9005, and the top thread doesn't seem to be catching the bobbin thread. I have rethreaded according to manual, worked with the tension, changed the needle. No better. What could this...
you might try holding the top thread tail 3-4 inches to the left side of the machine & turn the hand wheel manually on the right side of machine & slowly put the needle down & see if it will pick up the bobbin thread that way
Sep 21, 2010 | Singer Sewing Machines
How to replace the bobbin case in a singer sewing machine model 9005
If you go here and search for 9005, you can find a free downloadable instruction manual.
Jun 29, 2010 | Singer 7444 Mechanical Sewing Machine
I am using a Singer Model 9005 and I need help adjusting the tension. How do I do that?
Top tension about 4 or 5 and you should only just be able to pull the bottom thread through with slight resistence, if it is too tight undo the screw on the bobbin case a quarter of a turn at a time anti clockwise anjd test and keep doing that until you get it right
Apr 07, 2010 | Sewing Machines
Singer 7444 Mechanical Sewing Machine Logo
16 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
