Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Third bulb out in 3 years
First two Proj. bulbs on 55 grand Wega were replaced under warranty. now I have to pay for third that just exploded last night. Has Sony got an answwer for this problem?
  • hatesony Dec 14, 2007
    We think we solved the problem with a battery back-up unit. Seems when powerline fails, fan doesn't get a chance to cool down the bulb and it melts for a failure a day or so later.
    We traced one powerline failure to the last bulb and perhaps my own accidental unplugging the set prior to that.
    So far so good. I accidentally unplugged the set and the battery back-up worked. The salesmen should include battery back-up in every sale and I informed him as such. Thanks for you observation.
    Would've responded sooner but my Mail threw it into junk.
    Genius:
  • 1,139 Answers
I would suggest you getting the shop to look at your cooling fan, assembly or the current surge suppressor connected to the bulb filiments.
Posted on Nov 15, 2007
SOURCE:
After replacimg bulb tv still flashing red
we bought our Sony Wega in 2006 - we changed the bulb twice both times they exploded; we threw this tv out one month ago - sorry but its literally GARBAGE! within the first year the optical block went, then the replacement under my extended warranty that optical block was defective-within a month all the purple hues started showing up again - warranty over - never will I purchase a 4,000 tv nor any sony products ever again! the only good product I ever liked of sony was the Walkman!
Jun 28, 2014 | Sony Grand WEGA KDF-42WE655 42" Rear...
My Sony Wega KDF-55XS955 TV keeps getting a blank screen every 4-5 minutes. I've been told I need to replace a bulb; however, cannot figure out where to locate the bad bulb. Any assistance would be...
julian1390,
That could certainly be your problem. If the unit has not had the lamp changed in the last 3 years it ceratinly would not hurt to do that. Even if this is not the problem you will have a replacement lamp for the time in future when the lamp does go. I have a tip at http://www.fixya.com/support/r4168009-change_lamp_in_dlp_projection_tv which will help you do this.
Thanks for using FixYa and for the great rating.
hardrocko
Jun 16, 2011 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv bulb comes on for about a minute then goes off and keeps cycling on and off.
This is symptom of weak lamp in tv that need to be replaced.
If lamp has not been replaced in last 2-3 years, replace it to fix the tv issue. Lamp replacement procedure is easy and written in user manual.
Jul 10, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Pink line at top after bulb replacement
If you have a pink shadow (meaning you can still see the picture in it) the light engine (projector part of tv) where the bulb goes is failing. you have to replace projector. contact Sony quick as it might still be under extended warranty. They had class action lawsuit and extended warranty on many models becuase of this problem but they expire soon. Good luck.
Apr 07, 2010 | Sony Grand WEGA KDF-55XS955 55" Rear...
Sony wega 70 in new bulb lasted 8 hours now
hello.+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Oct 21, 2009 | Sony Grand WEGA KDF-60XS955 60" Rear...
No video but there is audio after replacing bulb
NAKE SURE YOUR FRONT COVER THAT GOES OVER THE LIGHT IS'NT ON TO TIGHT ALSO CHECK THE 2 SCREWS THAT MOUNT THE LAMP COVER MAKE SURE THERE NOT TO TIGHT AND THAT THERE BOTH SCREWED IN THE SAME AMOUNT AND ALSO CHECK THE FAN ON THE BACK OF YOUR T.V. AND CLEAN IT IF NEEDED
Mar 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Bottom right side of screen (about 4 inches high) has blue tint
I had the same problem with my 4 yr old Sony KDF60WF655 rear projection set, and I was fortunate to buy a 4 year extended warranty - because it was the "Optic Block", ($1300. -not incl labor), that was replaced to fix the problem. That part contains all new LCDs, & multiple Lens & some electronics. I had already got a new bulb (under warranty) a few weeks earlier, that I had not yet installed so the service guy did replace that as well. (This happened 3 weeks before my warranty ended).
He told me that he replaces hundreds of Sony Optic Blocks every year and that many Sony Rear Projection sets have automatic FACTORY extended warranties (up to 10 years), because of some known problems with the blue LCD panels. You might want to contact a SONY office & see if your set is covered.
ALSO - The tech checked my Service Codes & showed me the TV had been running for 10051 hours in about 4 years - on the Original bulb! He was quite surprised because he said the bulbs usually last about 5000 - 7000 hours. He also said it's good to replace them BEFORE they go bad, because they can sometimes burn out the amplifier that powers the bulb, (which is a seperate piece that attaches to the outside of the Optic Block). My TV is like new now.
Dec 25, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
OUr Sony Grand Wega KDF-60XS955 has a blue corner
I had the same problem with my 4 yr old Sony KDF60WF655 rear projection set, and I was fortunate to buy a 4 year extended warranty - because it was the $1300. (not incl labor), Optic Block that was replaced to fix the problem. That part contains all new LCDs, & Lens & some electronics. I had already got a new bulb (under warranty) a few weeks earlier, that I had not yet installed so the service guy did replace that as well. (This happened 3 weeks before my warranty ended)
He told me that he replaces hundreds of Sony Optic Blocks every year and that many Sony Rear Projection sets have FACTORY extended warranties because of some known problems with the blue LCD panels.
Dec 23, 2008 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony tv KDF55WF655
same problem... tv turns on and off repeadly while the green light flashes. seems as if the tv keeps restarting. please help.
Dec 13, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
60 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
