Question about Whirlpool Duet GHW9150P Front Load Washer
Will model # lab2700lqo pedestal fit my whirlpool washer model # WFW86HEBW
5 Suggested Answers
  • 619 Answers
SOURCE: Whirlpool Duet GHW9150P, Screws for Pedestals
You can go near hardware if nothing stock you may go to washing machine junk shop you can select any part as you wish.
Posted on Jan 05, 2008
jsrock516
  • 5911 Answers
SOURCE: Drops of water inside pedestal of washer.
Sounds like you have a leak around the door bellow somewhere, or your drain pump. The bellow is the rubber gray boot the seals around the wash tub and door. You will need to remove the bottom panel under the door to be sure. Remove the screws under the bottom edge of the panel. Once removed, the panel will drop down, then off. Inspect the washer with a load running. If the bellow leaks, a tell tale sign will be moisture showing up on the concrete counter weight in the front of the washer. Double check your drain pump and hoses as well. The pump is located directly under the wash tub in the front of the washer. The water tends to pool in the cabinet before it leaks out and drops into the pedestal drawer. If the bellow is leaking, make sure inspect it for rips and tears. You may just have a banding clamp that is loose. If the pump is leaking, make sure the clean out trap is on correctly and snug.
PS If you just purchased this washer and are experiencing problems already, this repair is covered under the one year limited warranty. Inspecting for a leak is not going to void the warranty. However, removing any major parts may. Just do an inspection to see if it is something obvious. If you suspect a part failure, get in touch with the retailer. If this was purchased from S**rs, they usually have a 30 day satisfaction guarantee. If you are not happy with the appliance, they should take it back.
Please let me know if you need further assistance.
Posted on Jun 01, 2008
  • 12 Answers
SOURCE: washer vibrates and walks across the floor
Theres a few things you can do to stop it from walking.
but the best way i know is to use washer anchors.
Whirlpool part# 155P3 $22.95
Im going to assume that you have eaither the wfw8300 or wfw8400
the main differences is the suspention system in them. the 8300 uses a 5 point system that work but really you should only use the washer on solid flooring like concrete. the 8400 uses a 6 point with better shocks.
if you have this washer on a main floor with basment underneith it you might want to check the floor. grab a glass of water when it starts to shake and walk and put it on the floor, if the water is jumping then the floor is the problem.
eaither way the anchor kit i have listed above will stop your issues with it moving and walking.
Posted on Feb 07, 2009
  • 82 Answers
SOURCE: How can I remove the Whirlpool Duet washer pedestal drawer?
there should be a clip on the top or bottom if not pull it out as far as it will go grab it on both sides and pull sharpley towards you DO NOT GRAB THE FRONT IT WILL BREAK
Posted on Jun 29, 2009
Just purchased a LG 8500HSA Mega Front Load Washer Special Order! What is the Pedestal Model Number?
Please check your model number. 8500HSA does not cross to anything on LG.COM.
Universal pedestals are for sale at Sears, Home Depot, Lowers, and Best Buy. The pedestal and machine will bolt together, that is, a bolt will run upward from the pedestal into threaded bolt holes in the bottom of the washer. If you can measure the distance from bolt hole to bolt hole on the bottom of the washer, you can check to see if the universal pedestal fits before you buy it.
Several months ago I took my front loaders off the pedestals. The pedestals were kind of nice for handling the clothes but about 40% of the time I spilled either detergent, bleach, or softener because the pedestal put the drawer too high for me.
Apr 18, 2015 | LG Washing Machines
Will LAB2700LQo pedestal fit my Kenmore model 110-47532602 or 1108752601
Even though the Sears brand is made by Whirlpool, the 110 series is an exclusive line. IT is not likely to fit. You will have to measure the base and mounting holes on the pedestal and the machine.
Jun 27, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Why will the washing machine door not unlock?
Sounds like you have a broken door lock, or a wire harness is loose or disconnected. Also make sure the door seal is not out of place.
May 01, 2014 | Whirlpool Duet Steam 4.1 Cu. Ft. Front...
How do you lower the height on a LG washer and pedestal? It's too high by 1" to fit under my wall cabinets.
The pedistal has 4 leveling legs on the bottom of it you can adjust to a certain point. You may have to take the lefts off completely and if it still doesn't fit, you unfortunately didn't measure properly.
Mar 16, 2013 | LG WDP4W 14 inch Pedestal White
How do you install whirlpool duet pedestal
Make sure that you get the pedestal designed for your washer. The white pedestal for the GHW9400P would be LAB2700MQ. (There are slight differences in the pedestals for different series washers. The holes in the base of the washer will not line up with the holes in the pedestal for a mismatched combination.)
First if your washer has been installed, uninstall it. You need to turn off the water. Then disconnect the power cord and (carefully) the fill hoses. Loosen the hoses first and then completely remove them. Drain the hoses into a bucket. Disconnect the drain hose from the back of the washer. Use pliers to squeeze the clamp to get the drain hose loose.
Pull the washer away from the wall. Cover the area behind the washer with cardboard and tip the washer onto its back (on the cardboard).
Pull out the drawer of the pedestal. Next snap the spacers into the holes on the top of the pedestal. (These are part of the hardware kit in the drawer of the pedestal.) Remove the shipping spacers from the front of the pedestal (behind the drawer). Remove the Philips head screw from the drawer slides and pull the drawer completely out (save the screws). Push the slides back into the pedestal.
Look at the washer and remove the feet if present. Partially install two of the hex head screws from the pedestal installation kit in the bottom holes of the washer. (These are at the center back of the washer if it is standing up.) Leave the screws about 3/8" from the bottom of the washer. Move the pedestal over to the washer and slide the keyhole openings of the pedestal over the two partially installed screws. Position the pedestal against the top of the washer and insert the remaining two hex head screws. Do not tighten completely.
Align the pedestal with the base of the washer on all sides. When it is lined up, tighten the 4 screws by reaching through the drawer opening of the pedestal. Bring the washer and pedestal back upright. Reinstall the washer (remove the packaging if this was a new install). Level (front to back and side to side) the washer using the pedestal feet (again reach through the drawer opening). Make sure that all 4 feet touch the floor. Tighten all 4 locknuts.
Pull out the drawer slides and reinstall the drawer. Reinstall the Philips screws. Close the drawer.
For pictures of the install, go to the Whirlpool support site http://www.whirlpool.com/owner_center . Search for your pedestal and get the installation manual. The direct link for the LAB2700MQ0 install is http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208537141.pdf .
I hope this helps.
Aug 04, 2011 | Whirlpool GHW9400 Duet Washer
Attaching the pedestals to the washer/dryer
You will have to find away to remove the adjustable feet, not an easy job, I would call Sears Appliance Service
Jul 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Pedestal for Samsung washer & dryer, will other brands fit too?
Just bought a red Samsung washer/dryer, looking for pedestals, but don't want to buy $200.00 ea., any suggestions
May 07, 2010 | Samsung WE356A5W Washer/Dryer Laundry...
Whirlpool pedestal w/ Kenmore Elite HE3 washer
no - the base is a different size.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 19, 2009 | Kenmore 15.5 in. Pedestal
I just wanted to know what pedastals will fit with the kenmore washer 48102
BEFORE U BUY PEDESTALS PLZ GIVE THEM MODEL NUMBER AND THEY WILL LET YOU KNOW WHAT WILL FIT THANK YOU
Nov 28, 2008 | Kenmore Elite 45986 Front Load Washer
Jan 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
54 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
