Question about Hobart D300-6036 Mixer
Hobart mixer model D 330 with 3 wires disconnected
Mixer was being moved to a different building and in the process the top cover was knocked off and several wires were disconnected. There is no schematic to refer to. I am an electrical engineer and have spent most of my life repairing industrial machinery and have never seen a motor with wiring as unique as this. It is a 2 capacitor single phase 240 volt motor. I am in need of a schematic for this machine.
  • 718 Answers
You can go to the www.hobartcorp.com website and register to download a parts manual.
You may be able to get the wire attachments from that.
Click on the operator and service manuals link. You will have to register.
Posted on May 08, 2009
HOW DO I MANUALLY LOWER BOWL IF MIXER WILL NOT START?
Trina you might be better off to contact Hobart or an authorised Hobart service agent about this. The lack of answers probably indicates resident hobart experts are absent.
May 06, 2015 | Hobart 140 qt Mixer Model V-1401 Used Mint...
Hobart A 200 Mixer
There are four possibilities to look at here. Assuming your mixer has a normal capacitor start motor (older a200's used a different style motor), possibilities are, in order of likelihood:
Motor start capacitor
Start switch (electronic or mechanical)
Burned wiring
Motor start winding
The start capacitor is located at the rear of the mixer. Remove the rear cover (4 screws) and pull the cover towards you. Disconnect one wire from the capacitor and test with any multimeter.
The start switch, if electronic, is able to be tested, but not very easily. Once you've eliminated the other possibilities, it's time to replace the (electronic) start switch. If the motor has a mechanical start switch, it's easy to test: Remove the two wires at the rear of the motor and test for continuity with the motor stationary. A multimeter should show near zero ohms for a good mechanical start switch.
Burned wiring should be easy to spot with some careful inspection around the motor, capacitor, and start switch.
Start winding: Look closely at the stator (stationary part of the motor). If some of the copper windings look significantly darker in color than the others, it's likely the start windings were overheated (the start windings are the thinner copper wires - if you look closely, approximately half of the wires are thinner than the other half). Look for a wiring diagram behind the power switch and determine which wires leading to the start switch and/or capacitor are for the start windings and test for continuity across the start winding. You should read a fairly small value such as 5 - 15 ohms. Values significantly outside this range could indicate a partially open or partially shorted start winding.
Jun 09, 2010 | Hobart A200 Stand Mixer
Wiring diagram for a Hobart D340 40qt mixer
i read in the manual that the wiring diagram is located on the inside of the top cover. check it out..
good luck
Oct 08, 2009 | Hobart D340-6009 Mixer
Need a wire diagram for a hobart p660 mixer
the elec. schamatic for the p-660 should be inside the top cover of the mixer, that mixer was specifically built for s'barros pizzerias
Sep 03, 2009 | Hobart P660 Stand Mixer
When turned on there is a slight knocking noise
Did the noise just start?Whats the model,ml or spec number on the data plate?
Apr 01, 2009 | Hobart D300 Stand Mixer
Service parts list of hobart mixer a120
There is a website called onesharpstore.com that specializes in food processing appliance parts. I saw the hobart model 1812 listed there just today (03/07/09). They even have a number you can call direct. 772-770-4383.
Jan 20, 2009 | Hobart D300 Stand Mixer
Hobart model a200t not working propery. Just hums when turned on
take top front cover off see if motor is spinning when turned on? hum can come when motor is running or transmision jammed or motor has issue like capsitor bad or start switch inside motor bad.
Jan 03, 2009 | Hobart A200 Stand Mixer
Is their a reset button for a L800 HOBART? Hit start sparks flew.
Yes,
DISCONNECT POWER
if you remove the top cover, you will find an overload group with a green and a red button on top, next to the contactor . One is test, the other is reset. On the side of the overload are two thumb wheels, one is auto/ manual, set this to auto, the other is -15%,0, +15%. If you are running very heavy batches and you want to push your motor harder, move it to +15, but it's not recommended. If it was set to manual, when it trips and cools down, it will not reset untill you press the reset button, in auto, once cool you an restart the mixer.
Nov 30, 2008 | Kenwood KM400 / KM410 Chef Classic Stand...
Hobart A200 transmission issues
does not sound good it need to be torn down and checked from here thats more then can be figured out sorry
Nov 26, 2008 | Hobart A200 Stand Mixer
Hobart L-800 Mixer is rotating in the wrong direction
Take the top cover off.Trace the plug going into the top,there will be 4 wires,leave the green wire alone.Unplug the mixer and any 2 wires reverse them that should do the trick.
Aug 29, 2008 | Food Mixers
Hobart D300-6036 Mixer Logo
304 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
