Question about Bosch Basket, upper - 367784
Bosch sm6p1b salt light stay on - Bosch Basket, upper - 367784
I have a Bosch dishwasher SHX68T52UC/02 that has stopped working.
Hello!
Here you can find manuals to a huge range of Bosch dishwashers.
Hope you find a solution.
https://manualsbrain.com/en/brands/bosch/dishwashers
Aug 31, 2017 | Bosch Dishwashers
Why does my low salt light stays on
might be a sensor failure id try giving it a high dose of salt water direct to the intake of system (not the entire pool)
see if light temp goes out , then ya know sensor thinks you dont have enough salt in pool
Apr 23, 2014 | Intex Salt Water Saltwater System Chlorine...
Bosch sgs45c02 salt container ful of water
the salt dispenser is always full of water, this is normal and you have no need to drain it. Just ensure you fill the dispenser with salt when the "Low Salt Light" is illuminated
Oct 03, 2012 | Bosch SGS45C02 Dishwasher
Bosch dishwasher makes noise but doesn't start
When you start a wash cycle on your Bosch dishwasher and it does not work, stay calm. It could be something simple, especially if you just installed it. Make sure the power cord is connected properly and a circuit breaker did not trip. How to Troubleshoot Bosch Dishwasher That Doesn Fill With Water
Sep 25, 2017 | Bosch Dishwashers
Bosch dishwasher rinse aid and salt lights on
Are both those reservoirs filled? Clear rinse aid may cause the light to stay on, as opposed to blue or green rinse aid.
Oct 21, 2011 | Dishwashers
The salt and rinse aid lights stay on
Top up salt and rinse aid or just ignore the lights if you use 5in1 tabs.
Apr 01, 2011 | Bosch 24 in. SGS43C12 Classixx...
My bosh classixx dishwasher is showing the light rinse acid and salt i have just got finish rinse aid and salt **** not sore were to put it in the dishwasher there is a cap saying salt is it that?
Inside the machine in base there is a large screw cap.
Undo that put DISHWASHER salt in not cooking salt.
Make sure the salt well is full of water in it before you put in the salt. Fill salt to top.
Please dont forget to vote this answer was helpful
Many thanks
Feb 14, 2011 | Bosch 24 in. SGS43C12 Classixx...
My dishwasher will not take salt the salt indicator light will not come on
i assume you have replenished the salt - you need to do this from time to time.
if you have put salt in, then undo the cap over the softener and stirr the salty water - may do the trick.
if you live in a soft water area, it does not matter anyway
Aug 05, 2008 | Bosch Dishwashers
Problems with my bosch dishwasher
there should be no salt getting into the wash cavity. if you are sure that it is leaving salty water on the items then either the salt cap is loose/damaged or the regeration system is faulty-this is an expensive fix.
Jun 12, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Basket, upper - 367784 Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
