Question about AO Smith Pool & Spa
Is there a reset button on the pump do to a power outage?
2 Suggested Answers
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: had a power outage does not turn on is there a reset
    Hello - I understand the unit has previously experienced a power outage, however have you try unplugging the unit or flipping the household breaker off? Wait approximately ten minutes; is there power to the unit? I suggest touching each button individually on keypad, do any lights turn on or does the display change? If any proves to be ineffective, I would recommend contacting a professional to move forward accurately because it can possibly have a defective keypad.
    Posted on Nov 05, 2012
    Model RB215LABP reset temperature display after power outage
    Samsung Blinking Dash/Line Error Code List - Parts Dr
    https://partsdr.com/blog/samsung-blinking-dashline-error-code-list/
    Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
    Samsung Refrigerator Troubleshooting Self Diagnostics ...
    www.appliancerepairlesson.com/.../samsung-refrigerator-troubleshooting...
    Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
    Error Codes / Messages / Blinking
    Dec 22, 2015 | Samsung Refrigerators
    Kitchenaid dishwasher kuds30ixssa has pump running but have no lights on control panel with door closed.
    Did you have a power outage recently? They are notorious for damaging circuit boards--usually about 3-4 weeks after the power interruption strange things will either start happening or *not* happening with appliances due to damaged computer chips on the boards starting to fail. Your symptoms indicate either a blown user interface(push button panel) or a defective main control board(board with the brains on it) or both!
    Aug 11, 2015 | KitchenAid Dishwashers
    Ffu14f5hwn how to reset control after power outage
    Good Afternoon Friend,
    I understand that you are trying to reset the controls on your Frigidaire freezer, model# FFU14F5HWN, after having a power failure. To reset the control after a power outage, all you will need to do is press the "Alarm Reset" button. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your freezer status has changed successfully. Hope this is helpful.
    -Best Regards-
    WP
    May 16, 2014 | Frigidaire Freezers
    Reset after power outage
    some of these had resets others reset after you unplug it for about 20 minutes and replug it in. some older models you had to hold in the power button for 5 to 10 seconds.
    Apr 23, 2014 | Pioneer VSX-11 Receiver
    RS261MDBP/XAA one blinking light after power outage
    on my samsung RS261BPMD, You have to hold the power saver and lighting button down at the same time for 5 seconds to reset
    Dec 08, 2013 | Refrigerators
    Had a power outage does not turn on is there a reset
    Nov 04, 2012 | Frigidaire 24 in. PLD2850 Built-in...
    Intermatic ej500 fuse
    Why did fuse blow?
    Is timer under-rated for load on line?
    Do wire size and breaker size match?
    EJ500 is rated incandescent-only with maximum 500 watts, with temp range from 32 to 104 F, maximum distance 100' from load, and timer has 1 year warranty against defects.
    http://waterheatertimer.org/Intermatic-timers-and-manuals.html
    http://waterheatertimer.org/Color-codewire.html
    Try resetting timer.
    This will delete both programs and current time settings.
    Hold down on-off button, and press and release reset button.
    Keep holding on-off button until display changes, and 12:00 is flashing.
    If timer will not reset, try changing battery.
    Simple power outages, and blown fuses can cause power surge that will knock out timers. This is a common problem, and resetting timer can usually solve problem.
    Timers like outdoor power pack, and analog plug-in timers do not have reset button and can easily fail after ordinary power outage.
    Jul 29, 2012 | Intermatic EJ500C - Indoor Digital Wall...
    My Oaisis II hot tub stays at 103 and now it's dropped down to 68 degrees for the past 3 days? Could there be a problem with my heater element? Or is there a sequence of resetting the temp buttons on top...
    Information on the care of your product and troubleshooting is available here:
    http://www.oasisleisure.ca/customer_care/SpaCare.html
    Did you have a recent power outage? It is necessary to reset the temperature after a power outage.
    Check the temperature setting on your hot tub; if it has defaulted do to a power outage reset to the desired temperature. If it is still set at your desired setting and is operating at 68 degrees then there is a problem that is preventing the tub from reaching the set temperature.
    Some possible causes and actions are:
    Pull filter (see if light comes on) / Replace filter
    Knife valves not fully open / Open knife valves
    Pressure switch cut of calibration / Adjust pressure switch
    Faulty Pressure Switch / Replace pressure switch
    Air leak, check pump suction line / Tighten pump union
    Heating element corroded / Replace element
    Faulty control panel / Replace panel
    Find the Manual for you specifc model for more explansyion on Troubeshootig.
    Feb 06, 2011 | Home
    Resetting my refrigerator
    It is possible that there is no reset button.
    Power outages or spikes usually affect the compressor which provides the refridgeration. It is possible that it may have got damaged. The spike is where the power have gone off but come back on too quickly causing. Spikes usually affect motors, pumps and compressors.
    Sep 14, 2008 | Kenmore 53642 / 53644 Side by Side...
    Pool & Spa Logo
    13 people viewed this question
    Top AO Smith Pool & Spa Experts
    Jay Finke
    Jay Finke
    Steve
    Larry Maranto
    Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
