Question about X-Acto XActo School Pro Electric Pencil Sharpener
Will not shut off when pencil is removed - X-Acto XActo School Pro Electric Pencil Sharpener
How to remove lead pencil from the sole
to start with , there is no lead in a pencil
It is graphite
so to remove graphite use a suitable cleaner
Dec 09, 2016 | Cars & Trucks
Tip
Our commode isn't leaking, yet it refills many times a day
If your commode is refilling over and over, you may have a Ghost Flushing problem. Even though there's no water on the bathroom floor, you likely still have a slow leak somewhere in the tank. To locate and identify the source of the leak fill the tank and shut off the water to the commode. Remove the tank lid and draw a pencil line along the top edge of the water line. Leave the water turned off and go back several times and redraw the pencil line at the water line. When the water stops draining see where the water level is. If the water has stopped just below the overflow tube, you likely have a siphoning problem. If the water drains to the bottom of the tank you likely have a flapper problem.<br />To correct the siphoning problem reset the the depth of the fill tube in the overflow tube. Fill the tank up, shut the water off, and recheck after some time. Repeat these steps until the water stops draining.<br />To correct the flapper problem gently lift the flapper and clean the bottom of the flapper and the flapper seat. Refill the tank, shut the water off, and recheck later. If water still leaks replace the flapper.
on Dec 28, 2010 | Plumbing
Sonny scooter, not getting fuel from gas tank
many of these has a filet in the valve / gas shut off , about the size of a pencil eraser,,,, take very little to clog it up.... valve / shut off should just unscrew after you remove the gas line's ... DON'T JUST CLEAN IT OUT .. GET A NEW FILTER FOR IT, . . .BRAKE CLEANER SPRAY WORKS GOOD FOR CLEANING LITTLE SPACES OUT .. and it dry's fast ..
May 13, 2014 | Motorcycles
How do you load a new lead?
To load more lead into the Zebra Z Grip mechanical pencil you must follow these steps:
1. Use the extra provided lead or purchase a refill package in 0.7mm size. 2. Remove the plastic cap that covers the eraser on the end of the pencil. 3. With the cap removed, gently tug the eraser out of the end. 4. When the eraser is removed, place a few pieces of lead into the open tube. 5. Insert the eraser. 6. Replace the cap on the end of the pencil. 7. Depress the end of the pencil a few times to feed the lead through the tip. 8. Write!
Mar 10, 2011 | Zebra Z Grip Mechanical Pencil, 0.7mm...
DOOR WONT SHUT
Some times the door catch closes. Get a pencil and put it in the door where the latch would catch it. pull on the handle as if you were opening it and push the pencil towards the car, this should release the catch. let me know
Randy
Nov 10, 2010 | 1997 Jeep Grand Cherokee
Shuts off immediately after I turn it on.
possibly dirty connection to the in car mount/charger and the internal battery has gone flat. Remove unit from base and inspect the terminals and clean if necessary. A pencil eraser should do the job
Oct 04, 2010 | Garmin StreetPilot c340 GPS Receiver
Picture problem
remove the batteries and clean the battery contacts in the camera with the eraser end of a common pencil. then insert the batteries again.
Feb 23, 2010 | Sanyo VPC-S880 Digital Camera
8-9 bios beeps then shuts off restarts and more beeps
There is a problem of your devices attached to your motherboard, it could be the memory. Remove the memory card and then clean the pins with an eraser of pencil and put it back. Remove the graphics card and when the system boots then probably the graphics card is doing the problem but when the problem still persist then your memory card does the problem.
Oct 25, 2009 | Computers & Internet
Dropped pencil down lint trap
if it is a top mount lint filter remove the 2 screws,then take the back off,remove the screws from the blower box,it is to your left,remove your pencil and your done-mike
May 23, 2009 | Kenmore Dryers
A pencil was dropped into the lint trap on the top of my whirlpool dryer. How can I get it out?
Unplug machine.
remove filter.
remove phillips screws on top.
remove rear cover.
Remove 4 screws holding base of filter housing.
Move housing to the side and fish out the pencil.
Dec 14, 2008 | Whirlpool LER5636P Electric Dryer
X-Acto XActo School Pro Electric Pencil Sharpener Logo
Top X-Acto Office Equipment & Supplies Experts
jasbo
jasbo
Are you a X-Acto Office Equipment and Supply Expert? Answer questions, earn points and help others
