Question about Miele Vacuums
Miele hs10 power switch won't stay on
When I press the switch it comes on but won't stay on
Why won't my Miele 8310 vacuum switch on?
The problem could be a restriction in the brush roll somewhere. Remove the brush roll and clean it and the nozzle housing. It could be an electronic problem which is much harder to diagnose.
Apr 10, 2016 | Miele Vacuums
Machine won't stay on
Either the on off switch or thermostat is faulty . have them tested and replaced.
Aug 03, 2015 | Miele HM21-100 Commercial 40" Wide...
Miele hover the lead seems to be stuck and wont go in when the button is pressed
Usually. Pull the cord a bit further out, gently , if it will come out more, then press button. If it wont come out more, it needs to go to a Miele agent to be fixed
Jul 18, 2014 | Miele Vacuums
When i push the power button and let go it turns off and won't stay on. what might be the problem.
Sorry to hear you're having difficulties with your DC27. In case you haven't already tried this, make sure you press down firmly on the power switch when turning the cleaner on. If the switch still won't stay down, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Aug 20, 2011 | Dyson DC27 Bagless Upright Vacuum
I have a miele S712 (2 yrs old worked fine yesterday) - I had been doing some diy work inside and had the vac on just to reduce some of the dust in the air - after a while the vacuum fizzled out. I...
you have got dust in the micro switch and it is not latching on, if you look at this and clean it, that will solve your problem, however blowing the motir has probably wrecked the motor bearings.
Jun 02, 2011 | Miele Vacuums
Miele vacuum powerhead
My power head failed due to the handle switch. It comes apart with the Phillips screw under the vacuum kill slider. Check for continuity across the switch contact solder points.
Mar 01, 2010 | Miele S251i Plus Bagged Canister Vacuum
Reset light is on.
set big Cat to stay on porch. (Smile)
Dec 07, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Miele white star canister vacuum - won't turn on, but isn't clogged
Miele white star canister vacuum - won't turn on,...
I have the above canister vac, which after my son tried to vac the stairs, it rolled down the stairs on him, but still worked, after turned off/on. Then after turned off maybe 10-15 mins., stopped working when we tried the switch. My father in law is our fix it guy, but still having a problem with the switch. Is there a wiring guide we could look at?
Thank you!
ALevy
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
You can try to call the factory for the Miele S251i schematics / wiring diagram @ the phone number and website listed below or I put a few pieces of information listed below that might help.
1. The vacuum cleaner switches off automatically
A temperature limiter switches the vacuum cleaner off automatically if it gets too hot. Some models have a warning light (triangle) which comes on to indicate that it has overheated. Allow the appliance to cool down for approx. 30 mins. and remove any blockages to the air path.
2. The "Change dustbag" indicator stays on even when a new bag has been inserted
To ensure the dustbag change indicator gives a correct reading, lift the floor nozzle or power head off the floor slightly to prevent the vacuum created in the suction tube from influencing the reading.
3. The exhaust filter indicator is red
Change the exhaust filter and then press "Reset" to switch off the indicator light.
http://miele.com 1-800-999-1360 Customer Care
Toll-Free Contact Information
For a repair order, please contact us at our toll-free number (800) 999-1360, Monday through Friday from 8:00am to 8:00pm, Eastern Standard Time (EST).
www.AVACcorp.com 1-800-328-9430
Apr 18, 2008 | Miele S251i Plus Bagged Canister Vacuum
Miele Solarus Canister Vacuum stopped working
I am an amateur and novice.
Tracked My Miele problem to a bad connection at the outlet plug.
i think the constant slapping of the plug against the housing during rewind prob disconnected the wires inside the plug? Replaced plug
Apr 14, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Vacuums Logo
73 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
