Question about Microsoft Excel 2007 Home and Student Edition for PC
Writing a formula for a sumif problem
I need to create a formula to calculate the total time spent on calls by each operator 1-4 I am working with excel.I would applreciate any help I can email you the worksheet if needed. my email is suzyqsims06@yahoo.com. Thanks for the help Brenda
  • Gerald Russell
    Gerald Russell May 11, 2010
    can we assume the operators are recording their start and end times of calls? if not, how are you getting this information?
    you can email me your worksheet so far at jerry@jerry-russell.com
  • mailani May 11, 2010
    Have you been able to resolve your sumif formula?
  • 78 Answers
Brenda,
Your problem is not so much the formula but the cells that contain the hours for each call. Since they contain the text “hrs” (for example “2.25hrs”) this turns the whole cell to text, not numeric, which will always add up to zero in Excel. So do two things:
- Change the cells in column H (Time Spent) to numeric (2.25 instead of 2.25hrs) – you might want to change the column header to Time Spent In Hrs just to b clear
- Use this formula =SUMIF(E8:E26, 1, H8:H26)
For the formula change the middle number to correspond to the operator ID – for example for operator 2 change the formula to =SUMIF(E8:E26, 2, H8:H26)
This should do it.
BTW, sent you a similar email about this.
Posted on May 08, 2009
  • 72 Answers
If your operators' time is listed in cells B2 through B5, for example, the formula to calculate the total time would be:
=SUM(B2:B5)
Let me know if this is not what you're looking for. Thanks!
Posted on May 19, 2009
How to calculate the percentage using the excel
Hide All
Percentages are calculated by using the following equation:
amount/total = percentage
Where percentage is in decimal format.
What do you want to do?
Calculate the amount if you know the total and percentage For example, if you purchase a computer for $800 and there is an 8.9% sales tax, how much do you have to pay for the sales tax? In this example, you want to find 8.9% of 800.
Example The example may be easier to understand if you copy it to a blank worksheet.
  1. Create a blank workbook or worksheet.
  2. Select the example in the Help topic. Note Do not select the row or column headers.
    Selecting an example from Help
  3. Press CTRL+C.
  4. In the worksheet, select cell A1, and press CTRL+V.
  5. To switch between viewing the results and viewing the formulas that return the results, press CTRL+` (grave accent), or on the Formulas tab, in the Formula Auditing group, click the Show Formulas button.
1 2 A B Purchase price Sales tax (in decimal form) 800 0.089 Formula Description (Result) =A2*B2 Multiplies 800 by 0.089 to find the amount of sales tax to pay ($71.20) Note To convert a number in percentage format to a decimal, divide it by 100. For example, the sales tax in this example (8.9) divided by 100 is .089.
Calculate the percentage if you know the total and amount For example, if you score 42 points correctly out of 50, what is the percentage of correct answers?
  3. Press CTRL+C.
Simple way Amount/Total*100
Apr 30, 2011 | Computers & Internet
Using sumifs formula accross multiple sheets
Here is the syntax: =SUMIF(Sheet2!A1:A3,"> 1", Sheet2!B1:B3)
This says if the cells A1 through A3 in worksheet "Sheet2" are greater than 1 then return the values from worksheet "Sheet2" cells B1 through B3.
Change the worksheet name Sheet2 to your worksheet name and change the cell references to the ones you need.
Apr 17, 2009 | Computers & Internet
Sumif function....
Use the following formula as an array formula, you need to hit "Shift+Ctrl+Enter" after entering the formula. Lets say you have the Name in column "B", the Age in column "C" and the amount paid in column "D". Here is the formula.
=SUM((B2:B7="Abhilash")*(C2:C7>0)*(D2:D7))
It will calculate the amount paid if the name =Abhilash" and the Agr is greater than zero.
Apr 11, 2009 | Microsoft Works 8.0 for PC
FORMULA NEEDED FAST
Yes you can create the formula outside the cell or you can create it one time and copy it down to the other cells. That way it will populate once it is used.
The formula should be Base Rate * .05 to get the result then add the result back to the base rate.
Dec 18, 2008 | Microsoft Excel for PC
SUMIF formula
One in general should not use Find & Replace.
I would recommend always creating the first formula manually by selecting the cells. This will avoid common errors like extra spaces.
May 11, 2008 | Microsoft Excel for PC
Display calculation result in a previous cell
Look into the =SUMIF function, it sounds like this may be what you are looking for.
Hope this helps!
Apr 09, 2008 | Microsoft Excel for PC
I need to Have a timer created in excel
Hi, I was looking to create a timmer. with stop and start option on excel.I have found the anser withyahoo group answers, that was help full and free, i got the VB macro programee. if you still can help me , here is the query,
I need a timer with stop and start option,
when i click on the star button i want the present time coming up on a cell(any cell) and when i click on the stop, i need to get the presen tme on the other cell, i need to clculate the time spent between the 2times.
i also need the time geting accumalated in the different sheet to calculate, how many times i have clicked and the difference.
Thank you for you any help you provide.
Regards
Rochboy
Apr 03, 2008 | Microsoft Access 2000 (077-01277) for PC
Using if and then to add values to a cell
Try using the SUMIF function for one condition or multiple conditions. Use the SUMIF worksheet function to create a total value for one range based on a value in another range. For example, for every cell in the rage B5:B25 that contains the value "Northwind", the following formula calculates the total for the corresponding cells in the range F5:F25. Formula:
=sumif(B5:B25,"Northwind",F5:F25)
Here are SUMIF functions for multiple conditions.
=sum(if((B5:B25="Northwind")*(C5:C25="Western"),F5:F25))
=sum(if((B5:B25="Northwind")+(C5:C25="Western"),F5:F25))
=sum(if(B5:B25="Northwind",IF(C5:C25="Western"),1,0)))
Also check your help for SUMIF functions.
If this helps you, Please rate me. Thanks, Patty
Dec 09, 2007 | Computers & Internet
Excel argument
If I understand correctly, you want to figure the normal wages at 40 hours and less. If there is more then 40 hours, calculate the normal 40 hours, then calculate the hours overtime (time and a half) and add them to get a total.
B5 columns are filled with this:
=IF(A5>$B$1,($B$2*$B$1)+((A5-$B$1)*($B$3)),A5*$B$2)
NOTE: The $ sign doesn't refer to money, it refers to an absolute reference so when copying a formula, the cell references with a $ sign are fixed and don't adjust according to the relative position to where it's being pasted.
Please rate as FixYa! or ask please clarify. ThankYa!
Oct 22, 2007 | Microsoft Excel 2003 (06503995)
EXCEL FORMULA
try using the formula "sumif". It allows you to sum by category/name. Good luck! D.
Sep 12, 2007 | Microsoft Office Standard for PC
Microsoft Excel 2007 Home and Student Edition for PC Logo
387 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
