Question about Nikon Super Coolscan 5000 ED Film Scanner
Film strip is stuck, can't find a way to remove the adapter to remove the film, how do I do that.
Come to me I will remove that.
Posted on Jul 31, 2009
Nikon coolscan 5000ed, film stuck, will not eject
If you switch off the scanner you should then be able to remove the grey film holder, even though the film strip will still be inside. Then, press the small button above the film entry slit to open the front of the holder. Pull up the top cover, ease the bright metal holder strip forward then lift the metal flap that holds down the film strip. At this point you should be able to remove the film strip. Re=assemble and try again.
Good luck.
May 18, 2014 | Nikon CoolScan V ED Film Scanner
Error message 5100 on Canon MX300 printer
If the ink cartridges are stuck you can manually slide them back to their default position and check for paper or junk which may have slipped down the paper chute and is blocking the ink cartridges.
Remove the blockage
Reset Printer
Done
I just had this problem and it was easy to fix.
If this not help, buy another printer! Cheaper than service...
Oct 22, 2009 | Canon MX300 Office All-In-One Printer
Is there anything I can do if the inner mechanism is jammed and wont turn/advance the film/allow any pictures to be taken? I took one shot, and then it wouldn't advance- the button on the bottom is stuck...
well i get whats the problem,,, the film is jaming your camera you realy need to pull the film out the only way to do this is to life the center crank handel and turn it and hope it strips the little frame drive holes in the film first before the camera strips?
the problem is caused by the film jamming in the case if you have fully wound it on that is???whate ever that film has got to come out first to get your camera working again ,,,,good luck
Oct 20, 2009 | Mamiya 35mm f/3.5 Lens 645
Sharp AL 1631 Grayscale Copier Placement of Shutter Film strip
you may have removed the toner receiver strip.you have to removed the drum from the assembly.you can remedy that with .5 inch masking tape.
Jun 09, 2009 | Sharp AL 1631 Copier
Lide 600 film scanner. How does one secure the transparency in the scanner? I can find no slots, grooves, channels in which to slide them.
The scanner comes with a film adapter unit that holds the 35mm film strip. It compensates for the fhinness of the film strip.
You'll have to contact Canon support if you need to purchase one or make a mask using thick paper or a tranparency sheet and attach your film strip with drafting tape (it does not stick aggressively and removes easily.
You might also check with a local scanner repair shop for a used adapter.
Wish the solution was easier.
Apr 27, 2009 | Canon CanoScan LiDE 60 Flatbed Scanner
SA-21will not pull film strip into chamber
Put the film in after it is powered up. The unit needs to run through a power-up and calibrate cycle first. Once powered up, the until will feed the film in once it reaches a certain point into the machine.
The unit is supposed to kick the film back out when you close down the scanning software. If your film ever gets stuck try this to get it out. DO NOT force the SA-21 out of the machine with film stuck in it.
Aug 13, 2008 | Nikon COOLSCAN IV ED LS40
Narrow straight line runs across all scanned images
by shutterup
I solved my problem.
It's pretty personal, but I hope it can help others.
First: I might have created the problem myself because I slightly adapted the slide-mount.
Why?: Some time ago I had some unwilling films the automatic! film-mount wouldn't swallow, so I had to use the manually operated slide mount.
I adapted a slide housing a bit, so it could take and transport film.
To be short: In the end, there was transparent, (but also reflective) material inside the Coolscan V housing, close to the slide.
I removed it.
Second, I turned the scanner 45 degrees, and gave it a calculated whack on the side. (like you did with your tele in the 6ties, but a bit more carefull )
Don't know which one did the trick, or both. I can send a sample.
Mar 29, 2008 | Nikon CoolScan V ED Film Scanner
Scanning 110 negatives
You should be able to do about 12 at a time using the 35mm film strip film guide. What Kind of trouble are you having?
Mar 09, 2008 | Canon CanoScan 8600F Flatbed Scanner
COLORED SLIDES
do you have the optional film adapter? The optional Film Adapter (B81317) lets you scan negative film strips and slides
Jan 11, 2008 | Epson Expression 10000XL- Photo Scanner...
Coolscan ed 4000
The scanner has a lock which locks the film adapter into the scanner when film is inserted. You probably still have film in the adapter from the last time you used it. If the adapter is pulled to remove it, the connector can become disconnected, which prevents the film from coming out, but the latch is still engaged. With the scanner off, push in the adapter to mate the internal connector. Turn the scanner on then off, the film should eject. Once the film is ejected, the adapter should be able to be removed. Refer to your manual for reference to this problem, I have experienced once before. Once you figure it out, you will not forget, I guarantee.
Aug 15, 2007 | Nikon Super Coolscan 4000 ED Film Scanner...
Open Questions:
See all Nikon Super Coolscan 5000 ED Film Scanner Questions
Nikon Super Coolscan 5000 ED Film Scanner Logo
247 people viewed this question
Top Nikon Office Equipment & Supplies Experts
Doberman
Jerry Greenberg
Jerry Greenberg
Ric Donato
Are you a Nikon Office Equipment and Supply Expert? Answer questions, earn points and help others
