Question about Arrow ET200 Electric Brad Nail Gun
Electric nail gun won't work consistently - Arrow ET200 Electric Brad Nail Gun
How do I load the stapler?
No you don't. We answer most things here.
If the stapler is like any of these
http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Abostitch%20staple%20gun
You push the back in slightly to unlatch it and then drop it down a bit and the staple pusher comes out completely.
Jan 28, 2016 | Heavy Duty Stanley Bostich Heavy-duty...
Arrow fastener 2 in. brad nail gun has stopped shooting nails
make sure nails are loaded into the gun straight and correctly
Mar 26, 2013 | Arrow Fastener 2" Red Electric Brad Nail...
My 601 won't shoot any spikes it just leaves a 1/4 '' indent were nail should be?
If you're getting an indent in the wood from the driver, the gun is working properly. If the gun isn't driving fasteners/nails it's because the nail isn't under the driver when it's activated. Several things could cause this: Having the wrong angle nails in your gun. There is something in the feed path of the nails preventing them from feeding fully into the nose piece. The feed shoe is jambed or feed shoe spring is broken.
Feb 18, 2013 | Senco & Frame Pro 601 Framing Nailer
Need help loading staples in my Stanley electric staple/nail gun
there should be a button / lever at the rear press it and it should open so as to insert the staples
Apr 05, 2010 | Stanley Staple/Nail Gun Elec
Arrow ET200 nail gun only put nails in 1/8 of inch.
This electric nail gun does not have much power. Try shorter nails and softer wood. You need a pneumatic nail or staple gun for medium or heavy work. I have both a nailer and stapler and neither are very good.
Jul 23, 2009 | Arrow ET200 Electric Brad Nail Gun
How many tools will operate at same time
I think you'll have to look at your specs on your nail guns and see what the demand is . Whether measured in cfpm or psi, your compressor will tell you the max output of each of those. Then you divide the maximum sustained output of the compressor,, lets say it is 60 psi. Let's say the guns require 10 psi, 60 divided by 10 is 6 = 6 nail guns. This is completely hypothetical as I have no idea what your nail guns require, only you know what kind of guns you have.If you need to run more guns than the compressor can push air for, you'll have to invest in another compressor, maybe even one larger to handle the guns running wide open consistent nailing. Nothing a drywaller hates more is than for all the cursed clip nails not being drove in all the way, lol, and that's what will happen with insufficient air supply.
Matt
Nov 18, 2008 | Hitachi EC12 Portable Electric 2hp Air...
Delicate problem
Yes, because there is less risk of splitting the wood grain when using a nail gun than when using a hammer, nail guns are especially useful in delicate projects such as the application of indoor trimming. A nail gun sets the nail in one motion, reducing the chance of slips and bumps that can ruin delicate woods. Most models also include a rubber safety nose to protect the wood from friction.
Aug 27, 2008 | Arrow No. ET100 Electric Heavy Duty Nail...
Nail Guns Safety problem
Professional-grade varieties are automatic, and fire a nail directly upon pulling the trigger. A semi-automatic nail gun is more appropriate for beginners, since it requires a two step process: pull the trigger and then tap the barrel against the wood. This safety feature protects the user from accidentally firing a nail gun and injuring himself or others.
Aug 27, 2008 | Arrow No.ETF50PBN Extra Heavy Duty...
Nail Guns Types
The real different between nail gun's models are the sort of power supply they use. A nail gun can be powered by compressed air, electricity or batteries, or electromagnetism. Some small guns are powered by butane, a fuel that causes a small explosive charge to drive the nail into the wood. The most common type of nail gun is the pneumatic nailer, which works with compressed air.
Aug 27, 2008 | Stanley Pneu Roof Stapler
Arrow ET200 Electric Brad Nail Gun Logo
65 people viewed this question
Top Arrow Tools & Hardware - Others Experts
JOHN LAPIER
Paul Sikkema
Paul Sikkema
Are you an Arrow Tool and Hardware - Other Expert? Answer questions, earn points and help others
