Question about Bissell 8910 ProHeat Clear View Upright Vacuum
Mysterious metal piece under vacuum motor?
I was removing the motor in order to service it, and there was this small (about 2 inches long) and bent thin metal piece under the motor. Now that I'm trying to put everything back together, I can't quite figure out how to orient that piece in order to make it fit!! Anyone have any clue about this mysterious metal piece?
The vacuum is a Bissell Healthy Home.
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fdgf
Posted on Sep 30, 2010
Eureka boss pro
go to a vacuum store and get help puting iy back together.
Oct 27, 2013 | Eureka 411A Upright Vacuum
The TechDrive Pedal on my Kirby G6 fell out of the back of my vacuum cleaner. I removed the screws from the metal plate one the bottom to try to see if something had come a loose. Can you send me a diagram...
This requires removal of the transmission assembly and replacement of the pedal assembly - it cannot be repaired. The handle and upper motor shell must be remove to access the transmission assemby. There are two screws in front, and two under the plastic switch plate.
Jan 18, 2011 | Kirby G6 Bagged Upright Vacuum
NEED TO CHANGE A BELT
First you need to remove the metal cover to expose the brush roll assembly. Push up the plastic cover connected to the foot pedal to expose the motor shaft. Remove the brush roll assembly and simply hook the belt on the motor shaft first then pull back the brush roll and push the brush roll back to the slot. There's a small piece of plastic on the left hand side of the brush roll. This piece would go in after the brush is set in the slot. Finally, replace the metal cover.
Jun 23, 2010 | Sharp Twin Energy EC-12TWT4 Bagged Upright...
When I took the base cover off the vacuum to clean the roller, a metal piece that is bent in half, as well as a white plastic stick piece came flying out. I think it might have to do with holding the...
They go in the slot beside the right wheel. Metal spring first, (the open ends facing away from front of vacuum base. The white nylon piece lays parallel and directly on top of the metal spring, round edge up, and aligned with the open ends of the metal springs.
Aug 09, 2009 | Eureka 411A Upright Vacuum
Formed metal wire inside handle
this bent metal wire goes right at the surface in a grove where the two pieces of the handle go together where your fingers grip it. I think it is to discharge static electricity.
Mar 27, 2009 | Oreck XL Ultra Bagged Upright Vacuum
E series
The clear lenses on either side of the top part of the E-series Rainbow are removable. If you look at the each lens you will see two sections on the top edge of each lens that looks like this |___| |___| about 1 1/2 inches in from each end. Put a small screwdriver in the middle of each one of these (I used 2 screwdrivers at once) and pry out. The clips will come undone and you can remove the lens this way, exposing the screws which hold the motor cover on. On my E-2, there were 4 screws under here, and once I removed them, the top came right off.
Nov 30, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Proheat pump key
No; the new pump has a metal pulley which is more durable then red plastic pulley. be sure to place a 3/4 thick x 10 inch long (small shelf works) piece of wood under housing before removing top.
Jun 07, 2008 | Bissell 7901-1 ProHeat Scotchgard Upright...
Central vac toast?
Most of these motors, the fan cover is just pressed on, but getting off isn't easy and you don't want to bent it up. Maybe using a flatblade try to knock it off from the edge of it may loosen it enough to pull it off.
Mar 18, 2008 | Vacuums
Bissell 8910 ProHeat Clear View Upright Vacuum Logo
73 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
