Question about Emerilware FR7009001 Deep Fryer
Holes in my deep fryer can i use jb weld - Emerilware FR7009001 Deep Fryer
How do you fix a hole in the gas tank
quick temp. fix would be jb weld for small holes i had a enduro motorcycle that had a broken pit **** at the bottom of tank and jb weld worked for me
May 23, 2012 | 2001 Chevrolet Impala
Hole in gas tank
get a tube of J.B. Weld, drain the tank, give it a couple hours for the hole to dry, apply enough J.B. Weld to cover the hole. (you have to be very quick with the J.B. Weld or else itset up before you can get it where you need it. dries in 3-5 mins.)
Jul 31, 2011 | 2003 Pontiac Grand Prix
The chain has snapped and hit the left side crank case and put a hole in it about the size of a 10p. Do you think I could cover this with something and if so can you reccomend anything as the cost of a new...
If you're sure the piece that got punched out is gone and not inside the engine waiting to ruin your day even further then you could in theory get by with good old jb weld.
Remove the cover and totally degrease the thing inside and out. While it's off look for any bits loose inside the cover. Find yourself a bit of steel mesh (window screen) big enough to cover the hole plus a bit. Put the screen over the hole and use a sharpy to mark it's edges. remove the screen and take a drill with a small bit ( < 1/8"). Pop a few holes in the area of coverage of the screen and around the hole. These holes give the jb weld more grip as it will flow into the holes and harden. The holes need not go thru but if a few do its good.
Take a small file and roughen the surface around the hole so the jb weld will have something to grab onto. degrease the area again.......now smear some jb around the hole from the outside and set your screen into the jb weld....add some more jb over the screen. Use a wet finger to smooth out the jb weld (if you add over this then don't forget to clean and roughen again).
Look inside the cover and smooth out any jb that came thru to the inside. Of course you have roughened inside the case so any jb inside will adhere nicely.
Once the jb has fully set you should be good to go....monitor your repair for any leaking. Also look closely for any cracks radiating away from the hole and make sure your repair covers them as well.
Cheers!
Take care.
Dec 08, 2010 | 2000 kawasaki KMX 125
Tank leaking oil
You didn't say how old is the deep fryer. There are 3 ways to do this job. A. take out the old tank and weld it ( most likely this is a very unreliable because when you start welding a spot, you may find another one somewhere else, and it never ends, and the welding shop will not give you any warranty for their welding too. ) and it is not cheap on labour alone. B. Replace the old tank from Imperial , They give you 90 days warranty on replacement parts. Please check out the labour first. C. This is the best way replace the whole unit with a new one they give you 1 year part & labour warranty. This is cheap compare with trying to repair the old one. You should shop around before you decided what to do. Good luck hope this can help.
Sep 24, 2010 | Imperial IFS50OP Deep Fryer
My deep fryer is leaking oil,how to fix it
Replacing the tank isn't cost effective. I am the only one I know that repairs fryer tanks. Most cannot be repaired(welded) successfully. If you got 8 years out of it..that's not bad. Time for a new one.
Tom
May 13, 2010 | Cecilware FMP40 Deep Fryer
Dean gas deep fryer burner on high will not respond to temp set
The thermostat is likely welded shut. You'll have to change it out.
Feb 25, 2009 | Dean SR14E Deep Fryer
Hole in radiator
You can try yourself with JB Weld or take to a Radiator Shop and have it Repaired.
Jan 21, 2009 | 2001 Nissan Altima
Burner Welds
You have your burners misaligned with the tubes. Re-align the burners and the welds will hold up fine.
SuperTech1
Mar 26, 2008 | Pitco Frialator SG14 Deep Fryer
Emerilware FR7009001 Deep Fryer Logo
80 people viewed this question
Top Emerilware Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Emerilware Kitchen Appliances - Other Expert? Answer questions, earn points and help others
