Question about Mitsubishi VS-5043 50" Rear Projection Television
Can't get the colors to align with eachother
I can't get the three colors red, green and blue to align with each other. How can I re position the guns so all three crosses are on each other? It is a Mitsubishi vs-5043.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 453 Answers
Bad convergence ic , stk392-110
Posted on May 08, 2009
54cm CRT tv tube green
CRT color television have three color "guns"; red, green, and blue. This is where the term RGB comes from when discussing computer CRTs. If you are getting only green, something is preventing the red and blue guns from working.
Aug 08, 2016 | Televison & Video
The picture screen is green and red.
It sounds like one of the three color guns has failed and based on the fact that you have red and green that would leave the blue gun as the culprit.
Feb 16, 2016 | Mitsubishi WS-65807 65" Rear Projection...
The screen is green and the tint option in the menu cannot be adjusted.
This symptom usually indicates CRT failure. Projection TV's, especially older types use 3 CRT "guns" to project the image on the screen. One is Cyan or Red, one is Green and one is Blue. If the Red and Blue become weak or do not project, the Green gun overpowers the output of the other two. These three "guns" are aligned exactly on top of each other so when all three are correctly functioning, the correct colors are projected on the screen.
Oct 04, 2015 | Televison & Video
I thought i might need a lamp for my mitsubishi tv--model VS 60607 when my tv is fuzzy when turned on.should i simply replace the lamp or is there something else i should try? thank you!
This TV is a rear projection television and does not have a lamp. It has three CRT color guns (Red, Blue, and Green). You have a convergence issue (the red, blue and green color guns aren't aligned properly) and it doesn't sound like a very big one. You should be able to adjust this through the CONVERGENCE Menu in ADVANCED SETTINGS.
More details can be found in your manual, here. The model number isn't exactly the same but I'm sure the process is identical or really close. The other option would be a bad IC (integrated circuit) for the convergence control. This is unlikely unless your picture looks something like this: captainhawk1_15.jpg
May 29, 2011 | Mitsubishi VS-60607 TV
It a green color with red and blue shadowing behide
The three guns need to be refocused or the screen is slightly out of position.
Feb 10, 2010 | Philips 55PP9401 55" Rear Projection...
No Red color at all. The convergence feature does not work either. Lots of green and blue RCA Model D52W59
Red color gun has failed, which will make the picture over saturated with the other two colors(blue,green) the bad news is the three color guns need to be replace in a set(all at the same time) because if you only replace the red it will over saturate the older blue, green guns then your picture will be mostly red.Unfortunently in most cases it's not worth the investment, better off to purchase a new tv. Good luck !
Nov 28, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
My comp. moniter has lost it's green color,HELP!
Try tapping on the side of it see if it comes back on. At the back of the tube is three electron guns, which are red, blue, and green. Each color is driven by a circuit. I dont't know if you want to do this. Open the monitor, and check if the all three guns are lit up, more than likely one is out. If there is a small adjustment you can turn each one then put them back to the same position. Thats all you can really do. Other than that it is an elestronic technician job.
Jun 30, 2009 | LG Studioworks 700S 17" CRT Monitor
Colors shadowing eachother, adj convergence, but will not save.
Sounds like your convergence IC chips have failed. You can buy the parts from various suppliers or you can just get a complete repair kit from www.TvRepairKits.com
Mar 15, 2009 | Philips 46PP9302 46" Rear Projection...
All color guns out of alignment
Needs convergence amps replaced. Sometimes resistors burn and need to be replaced. This repair requires soldering/desoldering equip. and a trained eye, but usually can be done for 175.00-325.00 at a reputable service center. Good luck, Russmann.
Nov 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Center adjust on Red gun is not aligning with B&G vert.
frist set blue and green than set red itwill shoew yu single chakall will be focous in single line than than gun will be allign horizontal if it will correct if itisnot comming than cathode problem.
Oct 06, 2007 | Sony VPH D50HTU Multimedia Projector
Televison & Video Logo
232 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
