My maxent TV has no picture and no sound
TV has no sound and no picture
  • 19,396 Answers
If an LCD TV has sound but no picture do the following:
Use the source button to ensure that source is not set to the wrong input.
Try unplugging power cord for ten minutes, to ensure it is not a setting problem.
Check all the video cables at the back of TV.
Check Light /Color settings.
If problem persist and does not depend on external receiver or settings, then it is likely an internal fault.
If it has sound but no picture then one of the following parts is faulty, and must be tested and replaced:
The inverter is the high voltage board that provides variable power to the backlight lamp. This is the most common. When inverter is faulty you can get no picture, or a very dim picture that can only be seen by pointing a torch light with a 45 degree angle on the LCD surface from very near distance.
The inverter must be tested by reading voltages with a multimeter.
The LCD ribbon cable/LCD display and connectors.
This is quite uncommon, but happens. If the TV had been hit or moved the LCD cable may have slipped out, or the LCD connector may be damaged.
The LCD controller board.
This is the board that controls the video signal, it is difficult to test, as there is need to read determined values on IC pins. To test this board you need to purchase a service manual and follow the troubleshooting diagrams on service manual.
Input/Output Signal boards.
This are the boards where you connect the video and audio cables, if a signal board is defective, then you may get no picture on particular inputs located on faulty board.
If under warranty contact the manufacturer ringing the number on the user manual.
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
Posted on May 07, 2009
My tv is not working
NO PICTURE BLACK IMAGEN,ONLY SOUND.MAXENT 50 PLASMA
Feb 21, 2013 | Maxent MX-50X3 50 in. HD-Ready Plasma...
I have a 42" Maxent plasma TV about 7 years old.
Is it 7 years old? Marvelous. Exciting. the lifetime of Maxent televisions are 6 moths the most!!!
You're lucky.
May 12, 2017 | Maxent MX-42VM10 42 in. HD-Ready Plasma...
Hi, Maxent P420142x3. Screen picture has gone....
my maxent p420142x3 i have sound but no picture any answers
May 19, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
No picture/no sound.
there is a problem with the heat curcuits leading to the tube
send it into a pro
May 15, 2010 | Maxent MX-42HPM20 42 in. Plasma HDTV
Maxent plasma tv no picture or sound
Check and replace that board. Just visit the site linked here. Y Sustain board faults and symptoms of plasma display is given in details. http://electronicshelponline.blogspot.com/
Apr 07, 2017 | Maxent MX-42XM11 Television
I have a maxent MX42VM11 which has a picture but no sound?
if you go into the menu of the TV go to the sound setup and select then goto speaker select and select internal speakers (Note: The menus may not be may not be 100% like the ones described here but the menus are mostly alike for most TVs.) or on the back of the TV there is a switch or button that has a selection for either internal or satalite select internal and you should get sound after you turn the TV back on. (Note: the switch on the back could be labled different)
Jan 06, 2010 | Maxent MX-42VM10 42 in. HD-Ready Plasma...
Picture problem with Maxent Plasma MX-42HPM20
Very common problem on these sets caused by bad surface mount caps. Check on ebay for a repair kit it's the only place I know where one exists.
Feb 23, 2009 | Maxent MX-42HPM20 42 in. Plasma HDTV
Need assistance on how to repair a plasma tv with no picture but sound
This site is BOGUS.
Invites you to post problems and "Ask an Expert" then wants you to pay a fee or you are SOL. Won't recommend and Won't be back
Jun 29, 2008 | Maxent MX-42VM 42 in. Plasma HDTV
Dropped tv
um your a ******** duh did u think it would work after that use your head buy a new one
Jun 22, 2008 | Maxent MX-42HPM20 42 in. Plasma HDTV
No picture only everythings working fine
I would suggest to do a search a on YSUS board. Your TV needs one of them to be fix.
May 02, 2008 | Maxent MX42X3 42 in. HD-Ready Plasma...
Televison & Video Logo
427 people viewed this question
Top Televison & Video Experts
Electro Med Services...
