Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My Whirlpool Cabrio just started leaking badly from the bottom I would presume. It is only about two years old. I took the back cover off but cant seem to find where it could be coming from. I put a mirror underneath but do not see any broken hoses any advice
  • 460 Answers
Your washer may be still under waranty.
this leacks may be for the water hose conections or the water pump.
You will find out if you see water running or droping (when the water begins or is trow away)
hope this information helps you
Posted on May 07, 2009
I have a Cabrio platinum top loader (not glass) & dark clothes come out with white powdery residue no matter how little he detergent I use and clothes come out really wrinkled
Aha! the problem i'll guess your model number is wtw8200ywo-you have a very bad washing machine-i'm sorry-it does what you say darks are covered withresidue and clothes are very wrinkled-if you are not happy with these issues take it back and get another brand of washer-I have a maytag-maytag was bought by whirlpool-I've had problems with this machine only a year and a half old so probably not a good choice either-Research before you buy and let me know who you come out-cheers Denny
Oct 22, 2013 | Whirlpool Cabrio WTW6600SBT Top Load...
My cabrio washer is leaking badly
Call the whirlpool factory and tell them you are calling about a recall, they replaced my motherboard for free to keep me as a satisfied customer. Doesn't hurt to give it a try.
Jul 29, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio washer is giving an F 51 Code
The "F51" error code is common problem with the Cabrio. This is an RPS sensor error. The sensor is mounted along the motor windings under the washer and detects the rotation spin speed. The sensors on these units can go bad, causing the error code, and it has been a frequent problem. I would recommend you contact Whirlpool first (due to the unit only being a year old) and see if there is a recall or upgrade on this part. I believe there is. The repair would then be covered by the manufacturer. If I give you the steps to access and/or replace the sensor at this point, you may be voiding any existing warranty you may still have. Some components carry a longer warranty than your normal one year limited warranty from the manufacturer. Something you may consider.
If you have further questions, please let me know. I hope this helps you in some way.
Jun 11, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Cabrio drains water onto floor.
I took the back cover off of the machine and found that the drain pump had a hole in it. The hole was caused by a coin that had made it's way down to the drain pump. The replacement pump cost $90.00 and was very easy to put in. If you google the words cabrio tear down you will come across a web site that has a video that shows you how to take the pump out. I have not had any leaks since. Keep the coins out of the washer, remeber to check your pockets to avoid paying out cash.
Jun 09, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio Washer- When draining, water leaks out of hole
probably rubber hose from tub to pump broke, access from back or bottom, (cabrios are open bottom) pump in rear. there is a recent bulletin about tub ring not channeling water from dispenser completely into tub
Mar 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
it is the bearing, call 1800-905-9505 and ask for a service smart agreement cost about 200 and it will cover your washer for 1 year parts and labor and the machine will get fixed
Feb 14, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Push start button on control panel - machine does not start
only 2 things can cause this.
1 the control is set to lock out mode. just hold the lock button for 5 seconds and it should go back to normal mode.
or 2 the controls user interface has an internal failure. its the part that has the switches and tells the computer what to do. either way call whirlpool and see if its still covered by their warranty.
of yeah and the 3rd thing is you have no power to unit. make sure the outlet is good by trying something else in the same outlet, like a light or hairdryer.
Jan 05, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio Leaks Water
Good luck. Mine did the same and they sent their technicians out to fix the problem. A&E comes out and replaces the tub ring. They told me the washer is now made with the tub ring in place. When he opened the washer up I noticed I now have rust inside my washer. I have spent a month trying to get Whirlpool to replace my washer but they will only replace parts. A&E came out to replace the tub ring and now my door creaks and my washer does not go back together correctly. Hopefully you can justreturn the washer to where you got it. Read other reviews on line. It sounds like this washer is a lemon. Sorry!
Aug 28, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
517 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
