Question about GE DSXH47GGWW Dryer
Dryer makes a thumping sound. - GE DSXH47GGWW Dryer
  • dfkelly03 May 07, 2009
    GE Gas Dryer Model DSXH47GGWW
    There is a thumping sound for each revolution. I am guessing that the drum rollers could be the cause.
  • Mark Nichols May 11, 2010
    make and model of the dryer?
  • 351 Answers
Yes, i can get a really good price for you on them if you call me... 866-798-4375 and or visit www.partsfuze.com them rollers are currently no on there but i could put them on
Posted on May 07, 2009
  • 1314 Answers
SOURCE: constant "thumping" sound when dryer is going
you can fix it by ordering a whirlpool roller kit but its no big deal the drum sits on rubber rollers when it just sits the rolers get flat spots on them like tires and makes the thumping sounds its just noisey but no big deal but they do make a kit with softer rollers
Posted on May 24, 2008
  • 5 Answers
SOURCE: dryer makes a thumping noise when running.
replace drum wheels.
Posted on Jul 16, 2009
hunter19_46m
  • 7482 Answers
SOURCE: Frigidaire dryer thumping.
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Posted on Jan 03, 2010
Testimonial: "Great, thanks!"
  • 14 Answers
SOURCE: dryer makes a thumping noise while it is running
It is your belt wheels they may need to be replaced
Posted on Jan 31, 2010
freddybake
  • 32 Answers
SOURCE: Our dryer is making a thumping noise. There is
REPLACE ROLLERS ,IN THE BACK OF DRUM (2)
Posted on Feb 07, 2010
Frigidaire gallery stackable dryer with a thumping sound
POSSIBLE BAD ROLLERS, BAD DRUM GLIDES, WORN BELT, DAMAGED BELT TENSIONER? AND BAD FELTS ON THE DRUM ITSELF
Feb 25, 2015 | Frigidaire Dryers
Kenmore dryer making a thumping noise
Your dryer has rolls on the drum and they are going bad and need to be replaced
Mar 22, 2014 | LG DLG3788W Gas Dryer
My dryer makes a thump thump sound
  1. Thoroughly check the inside of the dryer for any foreign objects with hard surfaces. Sometimes items that fall out of pockets become stuck inside a dryer and make thumping noises.
  2. Check for level
  3. Make sure the dryer is level. A dryer that is out of level may not rotate properly. Banging or thumping noises from unleveled dryers are common, particularly if the dryer is resting against another metal object such as a washer.
  4. Check rollers
  5. If the thumping noises are present only for the first few minutes of the drying cycle the likely culprit is rollers. If the rollers are warped they will need to be replaced and a professional should be called in to help
Dec 17, 2010 | Frigidaire Electric Dryer
Clothes dryer makes a ''thumping'' sound
One of your rollers has a flat spot in it or something stuck to it. Every time it rolls round to that spot the drum jumps over the little speed bump in the road. The wheel needs to be replaced.
Mar 11, 2010 | Whirlpool GEW9200L Electric Dryer
Thumping/Screeching sound, MD:LDE8616ACE. Rollers? Idler Pulley?
Your description sounds like one or both of the rear drum supports (rollers) is bad. A quiet thumping is almost always present as the weld in the drum comes in contact with the drum supports. A binding support will squeal, and the thumping could be worse at that time. After running the dryer until the noises are present, once disassembled, you can tell if a support is bunding or rolling normally by spinning it by hand. The same goes for the idler pulley. Make sure power is disconnected from the unit befor attempting any repairs.
While the unit is disassembled for repair, make sure your your old cat is not inside.
Sep 11, 2009 | Maytag PYE2300AY Electric Dryer
Dryer makes a thumping sound like it is out of balance.
if it is less then 6 months old you need to call whirlpool and they will send a tech out
Dec 31, 2008 | Whirlpool GEW9250 Electric Dryer
Rythmic thumping sound
probably the rear bearing or the drum shaft
Nov 15, 2008 | Asko T701 Electric Dryer
Constant "thumping" sound when dryer is going
May 24, 2008 | Kenmore 63942 Dryer
GE DSXH47GGWW Dryer Logo
99 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
Sal DeAngelo
Are you a GE Dryer Expert? Answer questions, earn points and help others
