Home heatpump not heating but a/c works fine - Heating & Cooling
  • David Rhone May 11, 2010
    Have you installed a new thermostat?
  • 400 Answers
Sounds like the reverse valve is bad. This would have to be replaced by a technician.
Posted on May 08, 2009
Pressure gauge keeps going down when the central heating goes off ,it is fine when it is on the pressure stays high
Is your central heating unit a heatpump w/ electric heat or natural /propane gas ? And what is the water heater, gas or electric ?
Dec 07, 2015 | Water Heaters
WIREIN HEAT PUMP FOR COOLING ONLY
You must wire Orange from heatpump low voltage wire to gether with your yellow s and you must have a common wire usealy common comeing out of heatpump should be black color than what ever color wire you have connected to common at t-stat and airhandler connect that to black wire at heatpump. To make sure blablack I s common follow wire up to board and it will be connected to C terminal now you will have ac all time. If you want heat remve Orange wire from reds at heatpump and you will get heat only.note when doing your wireing make sure high voltage is off to heatpump and airhandler hope this helps
Feb 27, 2015 | Carrier 52CQ-312-4 Comfort Series Heat...
Heat Pump comes on, fans slow down, switches off?
Sounds like a bad temp sensor or switch. Like in cars my guess is that the switch is failing to work causing the fans to stop despite the pump getting hot.
Jun 23, 2014 | Aquacal ICEBRKR HEAT/COOL 110K TITANIUM...
I have a Select Comfort 2000 thermostat. I just replaced new batteries couple days ago. The past week my heat will be working fine all day and/or night then suddenly it will not kick in and the aux light...
Sounds like you have a heatpump. Is that correct? When it gets under 35F or so the heatpump just isn't able to keep up with the heat demand and will require help from a backup source such as electric strip heaters. The way the thermostat works is that the heatpump will work until room temperature gets 2F to 4F below what you have the thermostat set for, the Auxillary heat will kick in to help out. I think I am answering your question, please let me know if I have misread your problem and I'll try to come up with something else.
Dec 05, 2010 | Heating & Cooling
Heatpump A/C not working
First,Turn on the heat cycle (Not Emergency)and see if the outside unit come on,If not,and you don't have low voltage outside,Go to the inside unit and test the transformer,If you have low voltage from the transformer but not outside,It is the low voltage wires,If you don't have low voltage from the transformer,It's the transformer.If you have low voltage outside when in heat mode,but the unit won't come on,It's the contactor.Let me know if you need more help.
Please take time to rate this fixya
May 13, 2009 | Goodman CLQ36AR49 Air Conditioner
Thermostat show AUX HEAT
A heatpump has two sources of heat. One is when the heatpump is operating in normal heat mode, and the other is typically electric heat strips.
The strips come on when the unit is going into defrost, when the unit is not able to keep up with the demand for heat (really cold temps) and when the unit is not working properly.
Whne the strips are on, the T-stat displays "aux-heat" to indicate the strips are in operation.
If the strips are working properly you should have warmer air than with the HP alone. Try switchin it from "heat" to "emergency heat" and see what it will do.
When the HP is not able to keep up with the demand for heat then the heat strips come on, but they typically come on only when the room temp has gotten well below the thermostat setting.
In that situation it would be normal to see indoor temps at 63 degrees when the T-stat is set on 70.
But when you set it to E-heat it bypasses the heatpump operation and goes directly to the heat strips. If they are working properly it should maintain an accurate temp in the home.
Jan 23, 2009 | GE Zoneline AZ55H09D Air Conditioner
Smell when unit comes on with heat
Hi!!!remember everytime you turn on yout furnace you will have a strange odor thats all the dirt that is burning from the heating element if your using the emergency heta if not the what you are smelling is your fan motor replace it and you should be fine..Good luck..
Jan 19, 2009 | Ruud Matching Split Air Conditioner
Goodman heatpump. Crazy pressure in heat mode
Check the TXV valve on the outdoor unit, it could be stuck closed. We have been experiencing the same problems with the 410 systems and the TXV was the culprit. Good Luck
Dec 19, 2008 | Goodman CLQ36AR49 Air Conditioner
I'm having a problem with my heating and air system, my heat only works on emergency heat ( and run 24/7) if i turn it to regular heat it only blows cold air. i dont think my outside unit fan is turning( i...
If your Heatpump's fan isn't running but your compressor is, your fan motor is out. If nothings happening at all ensure your getting power to heatpump (ex: breaker tripped, fuses blown on outside power switch, or fuses blown in breaker box?)
Dec 04, 2008 | Heating & Cooling
Low heat
if this is a heat pump it should either be low on freon or problem with airflow over outdoorcoil. (like a fan that failed or really dirty coil) PLEASE keep in mind if this is your first year with a heatpump instead of a furnace it does blow air out MUCH colder than a gas furnace or boiler.
Thanks ,
Brian
Nov 24, 2008 | Intertherm P3RA-048K Air Conditioner
Heating & Cooling Logo
23 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
