Question about Dell Dimension 4600 PC Desktop
My dell desktop doesn't start or boot from cd rom
Due to the recent update from microsoft, the window vista seems crashed out.  It has not been booting up and looping to restart since the recent update.  I've even tried to reinstall the window by booting up the window cd from cd rom drive, however it has failed as well.  The screen went completely black and I do not hear any cd rom running sounds at all.
Why would be the best alternative solution to fix booting my window when CD rom is not available?
  • Anonymous May 08, 2009
    thanks for your response. Ya i did what you told me, but still black out. The cd rom doesn't run either. What should be the next option? Thanks in advance.
  • machadojr_fe May 11, 2010
    Have you tried the last know good configuration?
    If not tap F8 as the machine is starting
    When it gives you a menu choose that option
    Then see if you can log in normally.
  • 31 Answers
Try to boot from safe mode it will work definately.and then try system restore to take your system to the previous state when it was worked fine.(select the date when the system works fine in the system restore).
Posted on May 14, 2009
  • 54 Answers
First, power up your computer. next, press f12 on the keyboard. finally, press cd-rom device.
Posted on May 09, 2009
  • 33 Answers
Basically you need to go to Bios to change your "Boot device pripority". Please follow these steps to do this.
Please follow these steps to install XP on your PC.
1. Please start your PC with power button. At the very first screen, at the left down corner, you will see the button to be pressed to go to Setup i.e. Bios of the PC. For most of the PCs , it is delete button. For some of them, it is F2 also. So, after starting the PC press Del to go into setup.
2. After you enter setup of the PC, please go to Advance bios setup.
3. There you select Boot device priority.
4. here the first boot device priority should be CD ROM, then the HDD. Please see the instructions given at right down corner and select this priority.
5. After you rightly selected boot device priority as given above, Press F10 to save the changes and then press F12 to exit.
6. Now the PC will restart again, but be sure that you put win XP cd in the drive before it restarts.
7. Now you will see a note that : press any key to boot from CD ROM, so please press any key.
8. The PC will boot from the CD ROM now , now you can follow the instructions given on the screen.
Posted on May 08, 2009
Dell Inspiron 1720- trying to turn it in but it keeps hanging at the windows vista welcome page and eventually says that it failed to logon due to security options failure. When I turn it on in safe mode...
You might have some 3 party programs running in the background that's crashing your system. Let's try clean booting the system to remove 3rd party software and see if that clears up the problem. In safe mode: Follow the steps below to place your computer in "clean boot" · Click the Start orb on your Desktop · Type msconfig in the Start Search box, and then press ENTER. If you are prompted for an administrator password or for a confirmation, type the password, or click Continue. · On the General tab, click Selective Startup. · Under Selective Startup, click to clear the Load Startup Items check box. · Click the Services tab, click to select the Hide All Microsoft Services check box, and then click Disable All. · Click OK. When you are prompted, click Restart. Did you get the same error message? If this does resolve the issue, then see the following Microsoft Article on "Clean boot" and the section "How to determine what is causing the problem" to determine which program or service maybe causing the issue. http://support.microsoft.com/kb/331796 How to set your computer back, to boot normal: · Click the Start orb on your Desktop · In the Start Search box. Type msconfig, and then press ENTER. If you are prompted for an administrator password or for a confirmation, type the password, or click Continue. Click the General tab. · Click Normal Startup - load all device drivers and services, and then click OK. · When you are prompted, click Restart to restart the computer.
Oct 16, 2013 | Computers & Internet
How to restore dell latitude E6510 to factory settings
Restoring A Dell computer/laptop back to the Factory setup
If you do not have a RECOVERY CD then contact Dell to purchase this Recovery CD for your model Dell laptop. Boot up using the Recovery CD and follow the instructions.
The other way is to re- install Windows using a Windows installation CD; it must match the Windows version on the Windows Product Code label on the bottom of your laptop. Boot up using the Windows installation CD and follow the instructions. Next install all of the Dell's computer/laptop device drives. Next install the Windows service packs (SP2 & SP3 for XP, SP1 & SP2 for Vista) Next Activate Windows via the Internet or by phone. Next install your programs - Microsoft Office etc. Next click on Start - Programs - Windows Update (for the latest updates).
The device drivers for your model computer/laptop can be downloaded from the Dell WEB support site. To download the drivers from Dell WEB site, select your model desktop or laptop, or a better option, type in the Service Tag number, this is printed on the label on the bottom of the laptop and on the back or sides of a desktop. (If the Service Tag label is missing then go the BIOS setting and on one of the BIOS pages, the Service Tag number will be displayed). The Service Tag will open the page where the drivers specific for your model computer/laptop are located. Also make sure you select the Windows XP or Vista version of the drivers for your Windows operating system. Click on this link to download the drivers: - http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Sep 01, 2012 | Dell Latitude E6510 Laptop
Cannot boot from cd on OptiPlex gx260
you might have to get rid of the virus or melware first
it sounds like you are on the path if the cd rom is being detected but not booting maybe it needs a clean place a couple of drops of liquid cd cleaner on top of a cd and run it
if still no luck
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Reboot the computer As the computer is booting repeatadly press the F8 key as the computer is booting
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select the safe mode option
then run your antivirus if still cant get rid of the virus restart again
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with networking download anti malware and microsoft security essentials
http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus
anti virus and malware
http://windows.microsoft.com/en-US/windows/products/security-essentials
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or the F2 key
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
hope this helps
Aug 26, 2012 | Dell OptiPlex GX260 PC Desktop
NTLDR missing on XP desktop
NTLDR is the boot loader for windows XP. This is the part the kick starts the entire process of XP loading. It is located at C:\NTLDR One of the easier ways to fix this is Either boot in to the recover console from a Windows XP disc, or download Hiren Boot CD, burn it to a disc. Insert the CD into your Dell and reboot the computer. Note you may need to enter BIOS and enable boot to CD/DVD. Once at the Hiren menu, select Boot Mini XP. Once the Mini XP loads you can copy NTLDR loader from the mini xp to your C:\ drive. Then remove the disc and reboot the computer.
Jun 11, 2012 | Computers & Internet
Hi, I have a Dell Inspiron One 2310 since Xmas 2010 and suddenly it isn't working anymore: it started last week-end with startup then shut down. Now it is even not started at all ! Dell is not...
There are many reasons for Dell Inspiron 2310 not starting up. These issues include the overheating of the processor and an unresponsive hard disk. Another reason is corrupted operating system files. Apart from these issues, you could also face startup problem due to a power failure in the middle of BIOS update or any other form of update in the system. Sometimes the laptop just stops working, it will not start up or boot up. get more help to fix this problem Click Here. Hope this helps you.
Jun 02, 2011 | Dell Inspiron One 2305 Desktop Computer...
Hello, I have an Hp pavillion dv6000. It used to have windows vista on it, and one day it downloaded and installed updates from windows atomatically. this crashed it. i would keep trying to start it...
i said this in my previous postings on this section i think microsoft maliciously and intentionaly design software that crashes and "bricks"Linux systems
Aug 21, 2010 | HP Pavilion dv6000z Notebook
Blue Screen of Death
yeah unfortunitly you might have to reformat the entire hard drive and start from scratch
May 05, 2010 | Dell Dimension 3000 PC Desktop
Can't reboot dell 4100 dimension desktop
First put the hdd installation cd into the cd drive and try to boot. This should install the hdd driver as well as start formatting the new hdd. After the drive is formatted take out the hdd cd & insert the Windows installation cd into the drive. Boot. Windows should start installing on your new drive. After Windows is installed check the Dell support site for updated drivers for your system. Install drivers as needed. Any other software you had on your old drive will need to be reinstalled to the new drive. Hope this helps & please rate my answer. Thanks.
Dec 27, 2008 | Dell Dimension 4100 (-JM0TB01) PC Desktop
Contents of CD-ROM not displaying
actually some new laptops dont identify these pirated cd types so you try and update ur vista from microsoft and see if any update for your rom driver is available!!otherwise contact your laptop vendor!!
Jan 31, 2008 | Microsoft Windows Vista Ultimate Edition
Dell Dimension 4600 PC Desktop Logo
904 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
