Oil tank sounds hollow. But gauge says it is half full
We tapped the tank it sounds empty. Our gauge is only 2 years old. Can it be broken?
  • 958 Answers
SOURCE: fuel gauge moves back and forth from full to empty
you have a bad sending unit inside your tank.
the resistance of the potentiometer inside is broke on the half tank part.
you have to replace it.
tnx 4 using fixya.
drcool
Posted on Oct 05, 2008
  • 840 Answers
SOURCE: 2005 Buick Rendezvous Fuel Gauge
well the gage is made of rubber it could be sticking no other way than to replace the gage itself/ please rate my response thank you very much
Posted on Feb 01, 2009
  • 497 Answers
SOURCE: 2002 Chevy Suburban: Fuel gauge reads empty, tank is half full
Youre gauge is controlled by a plunger in the fuel tank which is attached to the sensor and the fuel gauge. it sounds like when the plunger goes down half way its either getting stuck down lower then it should. Needs replacing. Any mechanic can do this install for you.
Posted on Aug 27, 2009
ddc3
  • 144 Answers
SOURCE: 2003 Impala fuel gauge used to bounce and now
most of the time this is simply just the float in the gas tank getting stuck had the same problem in my car. unfortunately you have to access the gas tank to fix, but it is an easy fix. hope this helps any questions let me know.
Posted on Jan 25, 2010
Testimonial: "Confirms what I suspected. Curious as to the cost to repair."
  • 155 Answers
SOURCE: fuel gauge stops working at half empty and will
you have 2 recalls
pcm update fuel pump replacement
fuel pump module replacement and pcm software
Posted on May 05, 2010
My fuel gauge read empty even with a full tank of gas
Probable causes:
  1. Wire from dash gauge to sending unit is broken or the connection is corroded hindering electrical connection.
  2. Resistance wire inside sending unit is broken
  3. Lack of proper grounding between sending unit and tank or between tank and chassis
Narrow the cause by testing. At the bottom on the following webpage you will find testing procedures as well as repair. (It is always helpful to mention brand and model and year).
Fuel Gauge Testing
Aug 27, 2017 | Cars & Trucks
How to adjust gas gauge to read right not reading way over filled like it does now. When 1997 chev 350 vortec truck gauge is at 1 st red mark close to empty, better not past gas station ! ! !
the fuel level sender is inside the fuel tank, part of the fuel pump assembly. did you or was the tank replaced before??they may have bent the float arm on reassembly . you can buy the sender from your parts supply store .you will have to drop the tank to do this it clips onto the side of the pump assembly. run it almost dry first as the tank is big n very heavy even 1/4 full. you can try to bend the old arm
but its very hard on the "sender" as for level indicator full to empty, think of the shape of the tank narrow at top to widest point in the middle (full to half) wide middle to narrow bottom( half to empty)
its just an overall volume thing
Mar 07, 2015 | 1997 Chevrolet C1500
Gas gauge
see the diagram attached and fix it. God bless you
Jul 24, 2013 | 1999 Dodge Stratus
1998 ford explorer fuel gauge stuck on empty-Not the typical suspects causing it?!?!?!
One of the wires to the sensor is touching a ground. It may be getting pinched
Mar 04, 2017 | 1998 Ford Explorer
I have a Volvo S40. The fuel gauge is stuck on empty despite having a full tank
Sounds as though the fuel sending unit is either stuck, or the float is broken. Try tapping the tank with a rubber hammer to see if that helps, other then that your next option would be to pull the sending unit out all together and replace.
Mar 25, 2011 | Volvo S40 Cars & Trucks
How to fix a fuel gage on a 72 ford thunderbird
Perhaps you might consider the sending unit in the gas tank.
Dec 23, 2010 | 1996 Ford Thunderbird LX
Gas guage doesnt work
It sounds like a problem with the fuel gauge sender unit in the fuel tank which has worn out and gone open circuit and needs replacing. Access to the unit is usually through a removable plate in the floor in the rear of the vehicle. Disconnect the wiring connector and any hoses and then remove the securing screws. Replacement is done by reversing procedure.
Sep 16, 2010 | 1986 Lincoln Town Car
Says gas is empty but when at the pump its stops filling.some gas exits back from the tank, I figure its my pin any way to find out if im full or not?
What Pin? Your sending unit is most likely worn out,on a 19 year old vehicle. Pull gas tank and replace complete assy,fuel pump and all,while your there.
Mar 27, 2010 | 1991 Ford F150
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
