Question about Dishwashers
There are a bunch of lights blinking on the panel that I cannot cancel.
There are a bunch of blinking lights on the panel. I can't stop them.
  • 56 Answers
Dont know what make/model but try pressing two buttons together to reset,start and cycle
Posted on May 07, 2009
Blinking cancel light, that won't cancel out, and won't allow other functions to be started.
While the door is closed, try pressing and holding the cancel button for about 10 seconds to see if it will clear.
Mar 31, 2015 | Kenmore Elite Stainless Steel 24" BuiltIn...
KUDP01ILBL6
Technical sheet say you have a stuck key on the keypad
Feb 04, 2014 | KitchenAid Dishwashers
My Status light is blinking, red orange, green and It won't stop
This just happened to me! I found this fixya and it didn't help me. So I checked the status of the printer and it was trying to print some 3,000 envelopes, OOPS!!! Needless to say I cancelled the job but it still had to go through all of the pages before cancelling and finally stopped blinking!
Jul 18, 2012 | Brother HL-5370DW Duplex Wireless Laser...
Samsung ml1640 laser red light blinking
samsung ml1640 laser red and green light blinking continuously and printing not happening
Jul 02, 2010 | Samsung ML-1640 Monochrome Laser Printer
I'm getting a message that my overflow ink tank is full. How do I fix this?
You can reset the waste ink counter:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
However, you also need to blot the ink out of the waste ink absorber. The "tank" is a pair (usually) of plastic squares with a small piece of absorbant pad in the square on the sides of the carriage. For best results you need to partially disassemble the printer. Some find just drying the pads on a bunch of towels until it stops transferring ink is sufficient. (Also dry excess ink from around the plastic.) Otherwise, rinse the pads until the water runs clear. Then let the pads dry (blotting helps) completely. Without the cleaning step, you can get ink smearing on the back of the page as well as inside the printer.
I hope this helps.
(the counter is set to a number of pages that is the expected lifetime of the printer under normal use. Other failures may come up soon.)
May 19, 2010 | Canon PIXMA iP90 Mobile Printer
Unit will not run. cannot enter diagnostic mode.
i would say that you have a bad touch panel..99 percent positive
May 10, 2010 | Dishwashers
My kenmore dishwasher, model 15822, just stopped working. The quick rinse light is blinking. The only other buttons that work are the pots & pans light which blinks when pushed, and the cancel button...
These are known to develop sticky switch contact pads. They stick in the contacted position and stifle the panel. Sometimes heat can be applied with a hair dryer to release them and make the unit function again. This is more than likely a temporary fix. New panels are available for about $165 to $200.
Jul 16, 2009 | Kenmore Dishwashers
On light won't stop blinking and on the display there is an hour glass
there is a pending job queued, unless this file has been released and printed you cannot removed the light from blinking. pls cancell all doc spooled on your pc and select cancell all, press the cancel button on your printer as well then turn off and on your printer
Aug 11, 2008 | HP PSC 2410 All-In-One InkJet Printer
Kitchenaid Dishwasher Control Panel lights - some don't light up
about the only thing to try would be to remove the inner door panel to get to the control bd then you will see a mylar ribbon looks like a fat piece of scotch tape pull up on the plastic connector that holds it in and pull the ribbon out then get a clean pencil eraser and gently clean the ribbon and put it back in dont forget to push the locking tab back down then try it again and let me know
Feb 12, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
Dishwashers Logo
226 people viewed this question
Top Dishwashers Experts
Owen Barnes
