Question about Philips DVP5990 DVD Player
I installed a parental control code on my phillips dvp5990 dvd player and forgot the code.how do you reset it?
  • kidsal2 Jun 19, 2009
    Thank you!
    President:
  • 814 Answers
This information was found on the Phillips USA website http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=DVD_HOME_THEATER_CA&sct=DVD_PLAYERS_SU&session=200906 in the customer support section for you model dvd player. In the owners manual on page (47). I hope this information helps you with your problem. Select this to set the password for Parental control and Disc
Lock. The default password is ‘136900’.
To change the password:
1) Press OK twice to access the change password menu.
Old Password
New Password
Confirm PWD
OK
2) Use the numeric keypad 0-9 on the remote control to
enter your existing six-digit password at { Old Password }.
Note: When doing this for the first time or if you forget your
existing password, enter ‘136900’.
3) Enter the new six-digit password at { New Password }.
4) Enter the new six-digit password again at { Confirm PWD }.
5) Press OK to confirm and exit
Posted on Jun 02, 2009
    Scholar:
  • 86 Answers
One way to do it is guessing.It might take less time than you think.
the other way I can think of is to reset everything.Usually if you look on the remote or turn on the DVD somewere along the way there is a options setting or button.There will probably be a reset factory settings option,that would be your safest bet unless you have subtitles turned on or much changed.
Posted on May 07, 2009
Reset parental controls password for Vizio VBR120 DVR player
Many have a default code like all 9's but you may have to call the maker if not in the owner manual.
Oct 31, 2012 | Vizio VBR120 Player
Tip
How to up grade the software in the Phillips dvd players DVP5990 & DVP5992
Installing the latest software
Philips provides software upgrades to
make sure that this unit is compatible
with the newest formats. To check the
updates, compare the current software
version of this unit with the latest
software version available at the Philips
website.
A Press ç to open the disc tray.
B Press numeric keypad ‘55’ on the
remote control.
C Write down the file name.
D Go to www.philips.com/support to check
the latest software version available for
this unit.
E If the latest software version is higher
than the software version of this unit,
download it and store onto a CD-R.
F Load the CD-R to this unit for upgrade
operation.
Note:
Never unplug or turn off this unit
during the upgrade.
G Once complete, this unit will restart automatically
on Jun 02, 2009 | Philips DVP5990 DVD Player
Whats the factory password
The default password is 136900. Its for parental control and disk lock.
Mar 04, 2010 | Philips DVP5990 DVD Player
Forgot my parental code for my ps2 how can i
  1. Bring up a screen where the unit asks you to enter in the parental code. You can either insert a restricted disc, or enter the DVD setup menu and go to "parental control" under GA_googleFillSlot("TL-IMU-Article"); custom setup.
  2. When the screen asks for the code, press the SELECT button, then enter in the code "7444".
  3. The level adjustment under Parental Control dictates the strictness of the player. The lower the value, the more strict it will be. Either increase the value to lower the restriction, or disable the lock entirely by setting it to "off".
  4. Once you have made your adjustments, be sure that the DVD tray is empty, and press the RESET button on the front of the Playstation 2. It is imperative the tray is clear of any DVD or game for the unit to save your settings.
Nov 24, 2009 | Sony PlayStation 2 (PS2) Console
Forgot my pass code
reset code for philips dvd
Jul 08, 2009 | Televison & Video
Dont work after upgrade
This is a problem with the command and control software. You will need to contact Phillips customer support at this telephone number. 1-888-744-5477. Tell them that you have tried to upgrade the software and now the unit fails to respond to any function and turns itself off. I hope this information helps you with your problem.
Apr 17, 2009 | Philips DVP5990 DVD Player
My phillips dvd player (model DVP5990) is not reading disc at all no matter the format. any ideas?
This could be several problems. You should first try to clean the laser head with a cleaning disc. If this does not work you can try resetting the dvd player to the factory settings. This function is found in the settings section under preferences. Use you remote control to open the settings menu and use the up and down arrows to highlight the preferences section. Press ok to enter the sub-menu. Use the up and down arrows to highlight the default setting.Press ok. You have now reset the dvd player to the factory settings. Press the menu button again to escape the menu. All this information is in the owners manual on page (47). Try a dvd to see if the dvd player is working properly. If not you may have other problems that will require you to open the dvd player up to find the problem. These problems could be a laser lens that is not functioning properly or a problem with the transport that is use to set the dvd up for reading by the laser lens. For these problems it is best to have a qualified technician to troubleshoot the problem.You can call phillips customer support at this telephone number 1-800-744-5477. Tell them the model number of your dvd player and the problem you are having with disc player not reading discs. They will be able to help you get service for the dvd player.I hope this information helps you with your problem.
Apr 12, 2009 | Philips DVP5990 DVD Player
DVd audio sounds slow
Check you owners manual for the audio settings. Check these pages and note that the underline setting are the factory settings.Pages 37-41.These are the setting most likely changed. You can always reset the player to factory settings. This will most likely restore everything to normal. This procedure can be found on page 47. The reset function is call default. This is a factory reset function.The function is found in the settings menu under the preferences.If you do not have a copy of the owners manual handy, you can use this link and find a pdf copy on the philips website.http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=US&slg=AEN&cat=DVD_HOME_THEATER_CA&sct=DVD_PLAYERS_SU&session=200906 If you still cannot get the player working correctly, you can call the Phillips customer support at this telephone number 1-888-744-5477. Give them the model number of your dvd player and the problem you are having with the sound slowing down. They will be able to help you solve this problem. I hope this information help you solve your problem.
Mar 10, 2009 | Philips DVP5990 DVD Player
How to make DVP5990/37 Region Free
First I recommend that you upgrade the factory firmware to the latest version. The current version is .31 and available here. Click "I accept" to accept the license agreement and start the download. Open the zip file and burn the file named DVP5990_37.bin to a CD. Put the CD in the DVD player and it will begin the upgrade and open the DVD tray. Remove the CD but leave the DVD tray in the open position. After just under 10 minutes (6-8) the DVD player will report that the update was successful and close the DVD tray. Press the setup button, go to preferences scroll down the choices (past the bottom of the screen) and select reset to default values. The player will reboot.
Next press Setup
select the Preference menu
Press 1,3,8,9,3,1 on the remote control.
Use the up/down arrows to select region "0" which means all regions.
If you ever get a disc that won't play correctly due to a region error, just use the code above to select the correct region for the disc and you will still be able to play it.
Nov 02, 2008 | Philips DVP5990 DVD Player
Purchased new phillips DVP5990 dvd player. I have watched two DVD's on it fine. tonight I tried watching a dvd, and all the colors are reversed- IE Blue is orange, black is white, etc. I have tried...
I found a solution. Check on Phillips website to see if there is a BIOS update available. Download it, burn it to a cd. Load it in the player and it will update. After I did that, no more strange colors.
Jun 25, 2008 | Televison & Video
Philips DVP5990 DVD Player Logo
469 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
