Question about Adjust n Draw Kids Activity Table Set in Yellow and Blue
How do you adjust a two barrel corroborator for a ford 1969 ranger truck?
Motor craft corroborator two barrel for a 360 v8 ford ranger 1969 truck?
    Sergeant:
    Champion:
  • 293 Answers
If you have changed the carby, that can be complicated when you go into jetting but just a tuneup, in neutral or park, turn your idle screw to as low a speed while idling smooth, adjust mixture, normal starting position is approximately 1 1/4 turns out. when the idle picks up over 600 rpm reduce the idle (this is a guide only because a modified cam will not idle this low) then adjust again until you achieve the lowest smooth idle, the final step is to increase the idle speed to manufactures specification
Posted on Nov 25, 2013
Carb adjustment on 83 Ranger
yes but it will be blocked off by a small welsh plug
The manufacturer has the funny idea that mixtures do not need adjusting after installation so they blank off the adjustment to stop DIY from fiddling as you are meant to take it into a dealer and pay for it
Jan 29, 2018 | Cars & Trucks
Where can I get a diagram for vacuum hose routing for Motor Craft 2 barrel carburetor?
google` 1985 ford F150 2 barrel vacuum diagram
then click on images across the top and you will get lots of them. it's EZ
mike
Feb 25, 2016 | 1985 Ford F150
Can i put a 98 5.0 explorer motor in my 2001 ranger using engine wiring and computer out of the 5.0 explorer
Yes as long that it's a v8 because you computer is for an 8 cylinder one problem I see you might run in to if you have if it s an 6 cylinder it won't work you have 6 injector on the compute the 8 cylinder has 8injector on the computor
Oct 03, 2015 | 2001 Ford Ranger
The duration and lift for 1971 Lincoln 460 CI engine camshaft
COMP Cams® - Ford Engine Technical Specs and Information
www.compcams.com/Pages/411/ford-technical-info.aspxBig Block, 426 Hemi, 1966-1971 .... With the V8 engine sizes ranging from 221-460, there is an engine size and configuration to cover just about any need or application. ...The 4.6L version of this engine first came out in the 1991 Lincoln Town Car ... All of the factory valve springs are designed to work with a certain lift cam, ...
1969 460 Cam Profile? Please Help - Ford Truck Enthusiasts Forums
www.ford-trucks.com/.../284830-1969-460-cam-profile-please-help.htm...
Sep 18, 2004 - I have searched enough to know that a 1969 460 from a Lincoln had 365 hp and about ... to look at the stock engine blueprints they have but they do not list a 460 until 1971. ... lobe lift .253/.253, valve lift, .443/.443 dur 276/276 ..... Diesel Engine Fuels, Competition, Performance, Engines & Troubleshooting ...
Oct 03, 2015 | Lincoln Cars & Trucks
I have a 1968 F100 Ranger Longbed with a V8 360 and I seem to be missing power in 2nd gear and 2nd gear only. What could be my problem(s)?
if automatic shift 2-3 solenoid is stuck in third gear take od off if you can see if the truck shifts to third should be around 40 - 60 kph
Jan 10, 2011 | Ford Ranger Cars & Trucks
I have a 1990 Ford Ranger Extended Cab with a M5OD V6 manual Transmission. I really like to know if there is a V8 that will bolt right up with out changing up the motor mounts.
There are no V8s that will bolt right up to your existing drivetrain. The swap would require modification of motor mounts, heater fan box or firewall depending on your motor of choice, a larger capacity radiator, splicing into your existing wiring, a v8 transmission (ie C4 if automatic) and a v8 transfer case if 4x4, and a minimum of a 8.8" ford rear end (preferably a 9" ford rear end)/dana 44 front end to handle the power.
There are many books out there specifically detailing how to swap a v8 into a Ford Ranger. Refer to this site if you are really interested in undertaking this project: http://www.jamesduff.com/broncoII/v8conversion.html
Dec 23, 2009 | 1990 Ford Ranger SuperCab
Wiring the ignitions system on my 360 V8 Ford truck.
positive coil to ignition positive, negitive coil to the distributer.
Sep 19, 2009 | 1981 Ford F 100
Will a 73 dodge 360 motor replace my 78 360 motor in my magnum
do hope this is only a sunday car,and your not polluting the air we all have to breathe by using it every day of the week.best of british with it cant help much as never seen one of these beasts,now putting a jaguar engine in a mini or an alfa engine in a ford anglia ??
Jan 15, 2009 | 1978 Dodge Magnum
Adjust n Draw Kids Activity Table Set in Yellow and Blue Logo
80 people viewed this question
Top Little Tikes Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Little Tikes Vehicle Part and Accessory Expert? Answer questions, earn points and help others
