Question about LG Studioworks 700S 17" CRT Monitor
Mad monitor my monitor start producing waves horizentaly.i tried with multiple resolution n refresh rates. i hv lg 700 E 17" monitor. i know it is not graphics card's prob. so please suggest me.
    Scholar:
  • 113 Answers
Its reaching the end of its life im afraid, the FETs are slowly giving up. however make sure it is far away from electromagnetic sources, eg: speakers etc... and in its menu there should be a "de-gauss" button! give it a whirl!
good luck!
Posted on Oct 10, 2007
Get this flsh out of my monitor.
Hi there.
If the screen flickers, make sure the display settings in Windows match the native resolution and refresh rate for the monitor. You can find the native resolution of a flat panel display in the specifications, in the printed material or on the box that came with the monitor. Some common native resolutions are 800 x 600, 1024 x 768, 1920 x 1080, and 1680 x 1050.
The most common refresh rate for LCD monitors is 60 Hz. This normally cannot be changed for flat panel displays using Plug and Play settings. However, if you are using special video software to increase or decrease the refresh rate, change the refresh rate to match the default refresh rate specification of the monitor.
STEP 1
To change the screen resolution and refresh rate settings in Windows, do the following:
- In Windows XP
See my tip on setting up the optimum screen resolution for Windows XP here.
- In Windows Vista (Same for Windows 7)
1. Click Start, and then click Control Panel .
2. Find the Appearance and Personalization area, and click Adjust Screen Resolution .
3. Move the slider bar until the screen resolution matches the native resolution.
4. Click Advanced settings, and then click the Monitor tab.
5. Select the Screen refresh rate that matches the default rate for your monitor (if it is not already selected).
6. Click OK, and then click OK again.
If you cannot select the native resolution or the native resolution is unavailable, continue to the next step to update the drivers for the graphics adapter on the computer.
You can get the latest updated video drivers from the video hardware manufacturer's Web site. Here is a list showing some of the video hardware websites:
Check for NVIDIA video driver updates at NVIDIA Home Page.
Check for ATI/AMD video driver updates at ATI/AMD Home Page.
Check for Intel video support and downloads, Intel Downloads. (If you have an Intel mainboard and are using onboard graphics).
NOTE: If you are using onboard graphics with a mainboard that is not manufactured by Intel, just give me the name and model number of your mainboard and I can try and locate the graphics drivers for you.
After updating the video drivers, go back to Step 1 and try to change the screen resolution again.
Note: If you cannot select the native resolution after updating the video drivers, the graphics adapter in the computer might not support that resolution and may need to be upgraded.
If after changing the resolution and updating video drivers the flickering persists then check the video cable connections. Unplug the cable and inspect the cable for damage. If the cable is damaged, replace it with a new cable. Try to use cables less than 3 meters (10 feet) long.
Monitors are sensitive to magnetic fields so have a look at the environment around the monitor. Speakers, florescent lights, fans, cell phones, radios, and any other electrical device can cause flickering. Temporarily move electrical items away from the monitor to see if they is producing a field that causes the flicker.
If the monitor has more than one type of connection available such as VGA, DVI, or HDMI, try a different type of connection.
To see if the video coming from the computer is causing the problem, temporarily connect the monitor to another computer. If the flicker is gone when the monitor is connected to another computer, then this means that the graphics adapter hardware on the first computer is damaged or might need to be upgraded to use the monitor. On the bright side at least it's not your monitor.
If however the flicker remains then the problem lies within the hardware of the monitor itself and is not a software problem. If you have bought this monitor fairly recently then I suggest you take it back to the place of purchase and have them test it. Some monitors carry 3 year warranty support so if you bought it within the warranty period specified by the reseller I suggest you see if you can get refunded or have them swop it out.
~Slasher_X
Oct 30, 2011 | Philips 190B6CB/27 19" LCD
Hello, I have been using my asus vw222u monitor for a while now, connected to my dell dimension 4600 pc. I have been running the resolution at 1024x768, and been getting relatively clear pictures, but...
Your graphics card will not support that refresh rate @ 1680x1050. you may need to upgrade your graphics card.
Here is the best price/performance card for your machine. and will support upto 2048x1536 @ 85Hz
Hope this helps.
http://www.scan.co.uk/products/512mb-pny-nvidia-geforce-6200-graphics-card-agp-8x-4-cores-d-sub-dvi-i-s-video-passive-cooling
Apr 22, 2011 | ASUS VW222U 22 inch LCD Monitor
I just changed my monitor and my new monitor is not coming on, it works with other pcs but when i insert it in my pc which has an Nvidia pcx 5750 graphic card de monitor gets a signal but the screen is...
Have you checked the bios to see if onboard graphics have been disabled.
You may also have your resolution/refresh rate set to high for the new monitor.
Boot into safe mode (F8 on boot)
This will boot with minimal drivers, your monitor should now come on, if it does then go to you display settings and lower the resolution and refresh rates.
If it does not come on in safe mode, try hook up the old monitor, or another monitor to reduce the resolution
Sep 21, 2010 | MSI PCX5750-TD128, PCX5750, 602-8969-010,...
I cannt find driver for monitor LG L1953S
Actually, you should be able to use the monitor without installing a driver. If it isn't recognized automatically, just set the resolution to 1280*1024 pixel and set the screen refresh rate to 60Hz:
In Windows XP right-click on the desktop, open the Properties dialog, select Settings and set the screen resolution. Click Advanced, select the Monitor tab and set the screen refresh rate. If the proper resolution was not available in the first dialog, uncheck "Hide modes that this monitor cannot display" and try again.
That being said, there is a "driver" package, also containing a color profile, available from LG here.
If this doesn't help, describe your problem in detail, let us know your operating system and which which monitor you are currently using.
Mar 20, 2010 | LG L1953S - flat panel display - TFT - 19"...
When I open game the monitor become black and show: Analogique shortcut 53.6 Khz/85 hz
Your resolution or screen refresh rate sounds like it is too high.
Try dropping your resolution to 1024 x 768 and see if the issue persists.
If it does then perhaps your game is trying to force you into a higher resolution output and faster screen refresh rate than your graphics card or your screen can handle.
Assuming that the graphic output is fine when your not playing this game and just using windows?
Thanks
Pete McDowell
Geek2Door Ltd
http://www.geek2door.com
Feb 15, 2010 | LG Flatron L1752TX 17" LCD Monitor
Monitor say Input not supported. What does this
Your graphics card is set to a resolution of refresh rate that your monitor cannot handle, This can sometimes be one of the normal settings - there is not much you can do. Each monitor has a native resolution which the monitor should always be set at yours is:- 1280X1024
Nov 03, 2009 | Planar PL1910M (Black) 19 in. Flat Panel...
My hp dv 9000 nvidia graphic is making the screen
Make sure you have set your screen resolution to the resolution that your monitor can display and the refresh rate is not too high. Try using default refresh rate and see if you will have the same problem, it fails try 60Hz.
This one works well on most monitors, CRT and LCD's.
Aug 24, 2009 | Computers & Internet
On my monitor it is showing some waves... picture is not clear.. showing some lines(less darken)
If it is a flat screen monitor: you should try different monitor resolutions and refresh rates. Specifically, you should set your resolution and refresh rate to the specifications set by Sony. You can also use the "detect displays" button in the "display" system preferences.
If it is a CRT: Try the above, but also try "degaussing" your monitor. This is a command on the monitor itself, and it's location depends on the brand / model. turn on the On Screen Display menu and look around for it.
Jul 12, 2009 | Computers & Internet
Problem with my LG monitor L194WT
You will have to increase the referesh rate first and then go into the game and reset the resolution. The resolution bit is secondary. If increasing the refresh rate works, then you dont have to change the resolution :)
May 27, 2008 | Computers & Internet
Monitor shape correction
What resolution and refresh rate are you using?
Have you tried degaussing the monitor?
Mar 24, 2006 | LG Flatron 776FM 17" CRT Monitor
LG Studioworks 700S 17" CRT Monitor Logo
77 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
