Question about Boston Acoustics BA7900 Computer Speakers
Have 4 speakers but only one has sound - Boston Acoustics BA7900 Computer Speakers
Right speaker has no sound
Check R cable from source to speaker, No power used in L or R cable, they only receive the signal from SOURCE to speaker, You onlly have 2 ends of each cable, 1 to source other end to speaker
Mar 13, 2015 | JBL Pebbles 2.0 Speaker System 2-Piece
Creative SB X-Fi titanium rear speaker out problem
Hello.
This sound card it is well compatible and all you have to do its depending on your OS update and reset the sound properties to get the full reestored sounds of all channels.
Hope this hint helps
Carl
Apr 02, 2017 | Creative Technology Creative Labs Sb0880...
Trying to connect BA735 speakers to a MacBook? No sound? Are they compatible?
Those speakers were originally supplied with Gateway computer system that had sound cards with digital outputs. While some versions had analog and digital sound inputs, most often the speakers had digital input only. The on-board sound in the eMachines is analog output only, so the speakers are most likely not compatible with your computer. If you want to use those speakers, you will need to locate a PCI sound card with digital output.
It's a matter of the output from the computer's sound card (built-in) being incompatible with the speaker input. The card is sending out analog sound wile the speakers are expecting digital input. Downloading a driver won't help because that doesn't fix the root problem. You need to get speakers designed for analog input, or a sound card with digital output. As it stands now, your computer just can't use those speakers.
Since your using a MacBook there is no option for this Pci Digital Sound Card.
Feb 03, 2011 | Boston Acoustics BA735 Computer Speakers
Inspiron 530 sound distortion
What kind of integrated sound card do you have?? I am going to assume its realtek. Go to control panel, then open up RealTek HD Sound effect manager and make sure the drop down menu for Environment is on "none". The try your speakers.
Mar 25, 2009 | Dell Inspiron 530 Desktop Computer
BA735 no sound but sound card works in analog mode.
this should be pretty easy to diagnose. both speakers have mini jacks right? if so, and you plug one pair of speakers in on say, port "A" and you get sound then if you plug your other speakers in on port "A" and you don't get any sound, the problem is with your speakers.
Oct 19, 2008 | Boston Acoustics BA735 Computer Speakers
No sound from Creative Labs Speakers- Please help
to localised your problem, try to plug your speakers to other sound source like mp3 player ,stereo system. if still no sound coming from it,your problem is within the speaker system. perhaps the audio power amplifier ic inside, need to be replaced.
Oct 12, 2008 | Logitech X-530 Computer Speakers
DVD plays partial sound
Check your speaker connections it sounds like you have a 5.1 or higher sound system. 5.1 means left front speaker, right front speaker, center speaker, right rear speaker, left rear speaker and subwoofer.
Voices in movies all get channeled to the center speaker (you can usually hear it a bit from the right and left front speakers as well). If your center speaker is disconnected or not working, you will only hear the background sounds.
Sep 20, 2008 | Compaq Presario 5000 PC Desktop
Altec lansing acs54 installation
Hello there!! jlee432
The 4.1 speakers you has, and output sound , depend on the sound card you has on your laptop. If you has inside the laptop a sound card 5.1 you whould not have problems get it sound, BUT you have to set on multimedia and sound for 4.1 according.
you only have one output sound on your laptop, so you have to use 2 speakers or buy a splitter and get 2 speakers sound.
you also, can buy a pcmcia sound card, 5.1 from creative labs, to solve this. but check if your speakers of course sound of.
good luck
Nov 29, 2007 | Altec Lansing ACS 56 Computer Speakers
NO SOUND FROM SPEAKERS
HI Surthi
First thing came basic, check your speakers with other PC, and see if work correctly, then use the software control volume to see if not set to "mute" connect the speakers to the right slot in the sound card, sometimes according to the colors, usually green. see if you have installed the drivers for your sound card.
good luck!
Carl
Nov 05, 2007 | HP (PP036AA) Computer Speakers
26 people viewed this question
Top Boston Acoustics Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a Boston Acoustics Audio Player and Recorder Expert? Answer questions, earn points and help others
