Question about Stanley Tools TRE550 Electric Staple/Brad Nail Gun
The staple gun will not operate
It just wont staple
2 Suggested Answers
SOURCE: staple gun
Open the chamber and drop the staples upright in to the chamber do not try to load the staples by placing them on the strip that pulls out as you do with most staple guns.
Posted on Nov 25, 2008
My Pro 8000 stapler has about 20 staples jamed I need to how to unjam thew booklet does not show this
Clearing the Nail and
Staple Chamber
If, while using your Cobra
staple
and nail gun, it becomes necessary to
clear a jam from the staple chamber or
track, follow these instructions:
With the bottom of the gun
facing away from your face and
body, open the staple chamber by
squeezing and pulling the plastic
track release straight down away
from the base of the gun and
sliding the track back.(Fig 1)
(Note: the jammed staple or nail
may cause the track to be harder
to slide out than usual. Once the
staple or nail has been cleared,
the track will resume its normal,
free operation) Loose staples or
nails will be expelled from the
chamber.
Clear any remaining staples or
nails from the track and chamber
area.
Reload the Cobra staple and nail
gun and continue using.
May 17, 2017 | Staples Tools & Hardware - Others
Cant open jt27 staple gun to load staples
Hi Maria, I'm sorry you are not having luck with your JT27 stapler. Unfortunately you did not purchase the correct staples for this tool. The JT27 Stapler uses the JT21 staples in a green box. The staples come in 3 different sizes (1/4", 5/16", 3/8"). You can purchase these staples online or at your local Home Depot or Lowe's Store.
As for opening the tool - please see the attached picture for assistance.
May 07, 2015 | Arrow Tools & Hardware - Others
I have a staple gun and when I pushed the trigger the staple it metal so now it's bent in the gun and part of the way out. How do I get it out?
When this happens, you have to release spring pressure against the staple strip then invert the staple gun and BEING ABSOLUTELY SURE THAT THE STAPLE OPENING IS NOT POINTED TOWARD YOU use pliers or a similar tool to remove all of the damaged staple. Reinsert the staple strip, point the gun away from you and test operation.
Jun 05, 2014 | Tools & Hardware - Others
Arrow staple gun ET2025
Open the device. Perhaps he broke into a bow, or any other component. After you unzip, you will see the problem. Then you can take the decision to take.
Jun 21, 2013 | Tools & Hardware - Others
T50 elite wont staple
I just bought a T50 elite, and it will NOT staple too.
Simple 3/8" staples loaded and nothing comes out.
Jan 31, 2012 | Arrow T50P ARROW STAPLE GUN
How do I load nails into the 5700
Here is the link but I copied the instructions here too
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000035709.pdf
Loading Staples or Nails
Make sure there are no staples or nails jammed from previous usage by checking the handle operation.
CAUTION: IF A STAPLE OR NAIL IS JAMMED, POINT THE GUN AWAY FROM
YOURSELF AND OTHERS BEFORE OPENING THE TRACK AS THE JAMMED
STAPLE OR NAIL MAY BE FIRED OUT UPON OPENING
i) Point the bottom of the gun away from you and turn gun sideways.
ii) Turn gun up, grip track release buttons and push away to release, then slide the track out, as shown (fig. 1).
iii) Insert a strip of staples in the chamber with the legs pointing up (fig.1a). If nails are required, turn gun upside
down and tilt the gun away from yourself and load on the right hand side (as indicated on graphics at the
staple and nail exit) with point facing upwards (fig.1b) THE GUN MAY JAM IF NAILS ARE INSERTED IN THE
WRONG SIDE.
*Arrow
iv) Slide staple or nail track back into closed position - a click indicates that it is locked in position.
Your staple and nail gun is now ready for use.
May 20, 2011 | Garden
Directions for Arrow JT-21 staple gun
The jt 21 is that little red one, I have one in my shooting box, only takes the jt staples, and operates just like any staple gun. Feed it from the back.
Feb 20, 2010 | Hand Tools
Staple gun support
Know the types of staple guns available. They can be manual, electric, battery operated or run by compressed air with an air compressor. Some staple guns have guide wires because they’re used by electricians that can’t pierce wires. Others have long noses to work well in corners and tight spaces. There’s also a reverse built ergonomic staple gun called a "forward action" because the handle and the staple’s exit point are on the same end of the staple gun. Some staple guns can shoot brads instead of staples. Know how each type of staple gun works. This one is so simple because it works just like a stapler. You press and hold the silver latch on the back of the stapler to open the body. Take the tray out and fill it with staples. Then it’s ready to use. Just put the staple ejecting end on your piece to be stapled and squeeze it. There is also the forward action manual gun which is used by pushing the handle down, too. The handle is just located near the staple ejection site. Use an electric staple gun for effortless stapling. There’s no need to squeeze or apply any pressure on these guns. They come with a very short cord so you will always need to have an extension cord with your staple gun. You can also go with a rechargeable battery operated cordless staple gun. They are great but they do run out of steam so for long use one with a cord is better. They’re also pretty easy on the wallet these days, so there’s no reason to go without this in your home tool kit as it’s something that does a lot of jobs. Know the versatility of the staple gun. Whether you have a manual or an electric model, these are some of the most versatile tools out there. You can use them to recover furniture, to build a birdhouse, to staple lattice to a patio, to build lightweight projects like a small knick knack shelf and to do wiring work.
Aug 27, 2008 | Black & Decker 5700 Powershot Forward...
Stanley Tools TRE550 Electric Staple/Brad Nail Gun Logo
24 people viewed this question
Top Stanley Tools & Hardware - Others Experts
John Trevino
yoopertech
Are you a Stanley Tool and Hardware - Other Expert? Answer questions, earn points and help others
