Question about Frigidaire Electric Dryer
I have a Frigidaire Electric Dryer Model #LEQ1442ES0 which started beeping "out of the blue" around 2 or 3am one morning while I was asleep. Nothing was touching it and nobody was around. Since then, it would start beeping randomly with no apparent pattern. I have tried rebooting it by unplugging and plugging it back in. This did not help. I have had to leave it unplugged because of the constant beeping. I have managed to get to the back of the controls and would like to try to repair it myself, if possible. Thank you for your assistance! Tara
  • Mark Nichols May 11, 2010
    it just beeps no error code or anything,
A FixYa tech helped in troubleshooting the problem and helped me find the replacement part, the control board. I replaced it myself and my dryer is no longer driving me crazy. Thanks!
Posted on Jun 10, 2009
    New Friend:
How did you diagnose the problem? Your answer was vague and did not help anyone else.
Posted on Apr 23, 2013
LEQ1442ES0 signal constantly beeps and dryer stop mid cycle, it's approximately 10 yrs old. We have to unplug it to stop the signal. Is it time to buy a new dryer?
that is the computer board,not a big frigidaire fan,they have had big problems with the affinity computer boards
Oct 04, 2017 | Dryers
Frigidaire Dryer model # LEQ1442ES0. The lights come on and beep at us like normal when I change settings but when I press start, they just blink and beep but wont turn on.
Thank you for your post, friend!
From my understanding your Frigidaire dryer is not starting and the lights just blink. It sounds like a faulty door switch or control panel. I would check to make sure the latch or door strike is not cracked or broken if the door is not closing properly that could be the cause of your dryer not starting.
You could also perform a reset on your dryer and that could help clear any faulty error codes within your dryer. To reset your dryer you would unplug the power cord for ten minutes. I hope this has been beneficial. -Matt
Oct 17, 2014 | Frigidaire Dryers
I have a Fridgidaire Model LEQ144ZES0. Dryer will run for about a minute, shut off, then the display lights on far right Drying,Cool down,Prees Saver, Clean lint filter flsah 6 times and then thr Start...
Good Morning Friend,
I understand that you are having trouble with your Frigidaire dryer, model# LEQ1442ES0, shutting itself off after about a minute. I see that the lights to the far right flash 6 times and then the start and cancel button flash 2 times. This also, only seems to occur when the weather is warm and humid. I suggest putting a dehumidifier near your dryer during the warmer months to see if this helps to draw the humidity away from the dryer. The humidity can cause your appliance to not run as it should. The other suggestion I have, would be to reset your dryer. You will do this by either unplugging it or shutting the power off at your home's circuit breaker for 3-5 minutes. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your refrigerator status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 27, 2014 | Frigidaire FASE7073LW Affinity 7.0 cu ft...
Dryer runs but beeps intermitenly and doesn't stop beeping
you most likely have a bad computer board located in the top console.i haven't changed any of these boards out but on the frigidaire affinity dryer this happens alot and it's the computer board.the dryer would just start beeping on it's own,like 3 beeps at a time beep beep beep,then beep beep beep,was the board,you have to give the full model number to whoever you order the board from,open the dryer door,look around the opening where you put the clothes in and you'll see a tag with the full model number.good luck.
Feb 25, 2014 | Whirlpool GEW9868K Electric Dryer
Kenmore model 84152/94152, 8 years old, started out with3 beeps over and over while running just fine otherwise. Now, 12 hours later, stupid thing started, while not running as in not in use, beeping once...
that isn't a model number and kenmore doesn't make anything so you have to send the full model number off of the dryer,open the door look around the opening where you put the clothes in and send the model number,if it's beeping and starting on it's own it sounds like you have a computer board problem with it but can't help you without the model number.
Dec 31, 2017 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire dryer model LEQ1442ES0 beeps then shuts off after about 10 seconds. Four lights blink 3 times. Error code for?
Hi Robert, thank you for allowing me to assist you!
Constant beeping is often an indication of a possible malfunction. Let's try reprogramming the dryer by either flipping the household circuit breaker off or unplugging it. It is important to wait approximately ten minutes and then turn the dryer on. If resetting the power does not correct the issue, your appliance could be experiencing a communication error from the main control board, a potential wiring failure, faulty door lock assembly or the timer itself may not be operating correctly. This is not a normal DIY job so you may want to connect with a local servicer to determine the exact diagnosis.
Sep 01, 2013 | Electrolux EW1209i Front Load Washer /...
Touch Panel Control Shorting Keys
I would check out the UK WHICH website.
Aug 28, 2012 | Frigidaire GLEQ2152ES Electric Dryer
Replacing Control Board on Frigidaire model LEQ1442ES0 Dryer
There should be screws on the back side of the top panel that come out. Then the panel will slide out so that you can access the front controls.
Aug 18, 2009 | Frigidaire FEQ1442ES Electric Dryer
Frigidaire electric dryer
I was unable to locate a similar complaint through my service database, so this is going to be a hit or a miss answer.
This model has an electronic control board in it and it is possibly picking up a static discharge from your body and powering up the start relay. This may be due to improper grounding or a recent power issue. This type of failure apparently does not happen with a 240 volt appliance often enough to be in the books. I might suggest that you unplug the dryer for 10 minutes, then plug it back in to see if it corrects the problem. If not, you will want to have your outlet inspected by an electrician. You may also have to replace the control board, if the electrician finds the outlet satisfactory. You may also just want to consult a factory authorized servicer that would be capable of checking the outlet AND testing the board before replacing it.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jun 20, 2008 | Frigidaire GLEQ2152ES Electric Dryer
Frigidaire  Electric Dryer Logo
471 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
