Question about Dishwashers
F2 fault code sandstrom dishwasher - Dishwashers
3 Suggested Answers
  • 1382 Answers
SOURCE: mY DISHWASHER DON'T WORK THE FAULT CODE IS f. wHAT
The F2 problem in Asko dishwasher is due to the high water level condition.The reason is bad water pump or a defective water inlet valve. you should try replacing this and your problem will be fixed.
Posted on Sep 10, 2009
SOURCE: what is fault code f2 on fisher & paykel
Rotor is not moving. Remove the spray arm, filters and the rotor, check for debris. Rotor impeller should turn if you try to turn it manually. If it does not - replace the rotor. Here is your part: http://www.fisherpaykelparts.net/ecart/item.php?item_id=231
Posted on Nov 26, 2009
Fault code F2 on lg dishwasher what does it mean ?
dishwasher error code e2 f2, means main control board is not getting correct signal from the user interface https://www.skypesupports.com/
May 30, 2018 | LG Dishwashers
Kenwood KID60B12 Dishwasher F2 Fault code
it seems you a blockage.. can you hear the pump running?if you can you will need to unstop it I have done it with just a cloth hanger coming from the front in put side
Jan 01, 2016 | Kenwood KID60B12 595 mm Stainless Steel...
I have a sandstrom SDW60W10 and its showing a E1 fault code
Unplug it wait about a couple minutes then plug it in. It should be to rest the computer in it. Hope this helps.
Dec 12, 2014 | Dishwashers
Sandstrom S814WMB13 faults
sandstrom washing machine H6 code problem what that means???
Jul 06, 2014 | Washing Machines
Codes sandstrom
H6 fault code relates to heater problem I found cable feeding heater broken off repaired connection solved problem
Jan 03, 2014 | Washing Machines
Sandstrom dishwasher showing f9
please i have a dishwasher SDW60B12 , i live in spain and no body knows this brand here. So the error code is F9, please anybody knows what does it mean.?.. please i called an engineer buy he does`t know about it. Pleaseee.
Nov 06, 2013 | Dishwashers
Errors and restarts
will need a description of the problem. Some of the common fault codes are F1, F2 and F3.
All these fault codes stop the dishwasher and will not go away until the cause is removed. Please indicate the problem you are experiencing.
Jan 02, 2013 | Fisher Paykel Fisher & Paykel DishDrawer...
MY DISHWASHER DON'T WORK THE FAULT CODE IS f. wHAT
Sep 10, 2009 | Asko Dishwashers
F2 fault
The F2 error codes relates to high water level It could be a clogged in the drain line. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. You should remove this line and clear it form any debris in the hose or the hose connection. Be sure to reattach the hose before starting the dishwasher again. As well it could be a defective or a malfunction pump. Good luck!
Sep 05, 2007 | Asko D1876 Dishwasher
Dishwashers Logo
22 people viewed this question
Top Dishwashers Experts
