I want to replace a Drayton Thermostat with a Honeywell CM707, I have a Red, live, Yellow, heat and a Blue, neutral wire. The heating operates via a diverter valve.
I want to replace a Drayton thermostat with a Honeywell CM707 thermostat. It operates via a British Gas UP2 controller, I will leave the heating permanently on so that it is controlled by the thermostat. The CH system has a diverter valve which can supply heat to the water tank, the radiators or both. The wiring to the old thermostat was red, live, yellow, live for heat, and blue, neutral. The CM707 has A, live, B, live for heat, and neutral terminals, do I connect to the neutral terminal?
elias_sgr
  • 163 Answers
SOURCE: Installing a Honeywell Programmable Thermostat with my Bryant Puron HVAC System
i hope this helps
http://www.instructionsmanuals.com/u2/pdf/termostato/Honeywell-RTH7000-fr.pdf
Posted on Aug 18, 2008
SOURCE: Hunter 44100A programmable thermostat
Sorry Iasumed you had a heat pump t-stat. You will need to exchange to a heat pump t-stat
Posted on Sep 28, 2008
  • 415 Answers
SOURCE: Upgrade Baystat 239 to a Honeywell RTH7600D controller
For Trane sytems, B is your "Common" wire. O is your reversing valve relay, G is your fan, Y is your compressor contactor, R is Hot, Brown will not be used on your electronic tstat. X2 is your backup electric heaters. Without knowing what terminals are on your new tstat, I cannot offer more information than this. The installation manual may indicate what each terminal is controlling. I strongly suggest to write down ALL of the terminals and colors from your old t-stat and be sure to turn off the power to your air handler. Put the fan switch on your tstat to ON before turning off the power. Make sure the fan is running. Then turn the power off to your Air Handler. If your fan stops running, you have turned the power off to your tstat and are ready to start replacing it with your new tstat. I hope you find this helpful. Good Luck!!!
Posted on Feb 07, 2010
SOURCE: Replaced Bryant T-stat model TSTATBBNB001 with Honeywell t-stat
Hello,You forgot to wire the O terminal w1 witch is the reversing valve.It is important to check if old stat is using O or B in witch case B terminal=w1 leaving O unused.
Posted on Apr 21, 2010
jgwhomeequip
  • 1902 Answers
SOURCE: I am replacing a white-rodgers thermostat with a
Blue just goes to B
Posted on May 18, 2010
I need to replace an old Thermostat that just has 3 wires coloured Red, Blue and Yellow. The Honeywell THR830TUK Thermostat I have bought shows 5 wires on the diagram. I'm not sure which wire goes into...
The honeywell THR830TUK thermostat does not require a neutral as shown in the instructions.Connect the LIVE to terminal "1" and your YELLOW SIGNAL wire to terminal "3".
Connect your EARTH (if you have one) to the EARTH connection on the top left hand corner of the thermostat and blank off your NEUTRAL wire with a block connector.These instructions were supplied to me by Honeywell Customer Support.Hope this helps.
Jan 08, 2011 | Heating & Cooling
I currently have a Honeywell T874C1000 and want to replace it with a programmable thermostat. It controls a cooling only air handling unit with an outdoor condensing unit. No heat.
All you have to do is note which wires are hooked to which terminals and exchange them i.e.-R(Red) to R terminal, Y(Yellow) to Y terminal, etc. The only wires you should need are the Red, Yellow, Green, and sometimes Blue if the thermostat is powered by the unit and not batteries. Here are the most common wiring procedures:
Red(R)=Power
White(W)=Heat
Green(G)=Fan
Yellow(Y)=Cooling
Blue(B/C)=Common/Ground
Hope this helps!
Jun 26, 2010 | Honeywell Programmable Thermostat Heater
Need wiring diagram for Honeywell RCT8100
The old thermostat has a second stage heat which is W2. The new one doesn't have second stage heat.
The wiring your describing on the old thermostat is telling me you have a heat pump with second stage heat and the new thermostat is for air conditioning only. You will need to get a thermostat for a heat pump.
Apr 02, 2010 | Honeywell Electronic Programmable...
How do you wire a honeywell round mechanical thermostat
What are you trying to wire up?
Typical Thermostat Wiring for 4 or 5 wire Heat/Cool Thermostat (not heat pumps)
4 Wire Termostat
R = Red One Side of 24 volt Transformer
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
with one transformer for both units
Rc One Side of 24 volt Transformer
Rh Jumper Rc to Rh
G = Green Blower
Y = Yellow Cool
W = White Heat
5 Wire Thermostat
With 2 transformers one for indoor unit
And one for outdoor unit
Rc = Red One Side of (outside) 24 volt (outside transformer)
G = Green Blower (outside transformer)
Y = Yellow Cool (outside transformer)
Rh = Blue One side of (inside) 24 volt (inside transformer)
W = White Heat (inside transformer)
COOLING ONLY Thermostat
G = Green Blower
Y = Yellow Cool
HEATING ONLY
R or Rh One Side of 24 volt Transformer
W = White Heat
Feb 09, 2010 | Honeywell CT87B ROUND HEATING&COOLING...
How do I wire a Honeywell room thermostat T6360B1028?
The red goes to R or rc and the blue would go to C or common sometimes its BK on the thermostat and the yellow would go to Y.
Jan 22, 2010 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
How do i wire a potterton programable controller
All you need to do is look at the wiring diagram on the back of the old room stat, you will have the following:
(normally wired with these colours)
OLD COLOUR CODING
Live (sometimes called common) - Red
Neutral - Blue
Switch Live - Yellow
NEW COLOUR CODING
Live - Brown
Neutral - Grey
Switch Live - Black
All you need to do is wire up the new stat with this in mind. (please note: if the wires are not colour coded like this then do not proceed and get an electrician)
Any problems or questions let me know
I hope this helps
Steve
Apr 23, 2009 | Honeywell Programmable Thermostat Heater
Replacing thermostat
What is the blue hooked up to now?
Jun 07, 2008 | Honeywell Electronic Programmable...
Changing a room thermostat a potterton to honeywell t6360
I think I've done it - but don't take this as absolute truth.
For the Honeywell T6360B the original Potterton wiring should be rewired as follows:
Brown [Live] goes to terminal 1; Blue [neutral] goes to Terminal 2 and the yellow/green [which is not an earth but a switched live - i.e. gives live to the heating system when the thermostat clicks in] goes to terminal 3.
Obviously all done with the power isolated and when it was switched back on we had heating again :o)
It's been on over two hours now and all seems fine.
Jan 13, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
