Allaince air ducted system error code p6
Alliance air ducted inverter system that showing a p6 error code
  • 86 Answers
SOURCE: Ducted aircon error code
1. check cirkit board.
Posted on Mar 17, 2008
  • 9 Answers
SOURCE: Lg Ducted inverter airconditoning with error
The LP code is low pressure check to see if the air filter is clean if the filter is dirty this will restrict the air flow other wise you will need a service tech to check the refrigerant charge on your unit.
Posted on Jan 30, 2010
SOURCE: I have an error code of E3 on my ducted air
i have an E3 error reading on my 12000 btu home airconditioner.Please let me know how to resolve this problem and get the aorcon up and running again .Thank you
Kind regards. Osman
Posted on Mar 22, 2010
hvac1960
  • 2133 Answers
SOURCE: the led panel on the
C6 - compressor run current high
- check [resistance of] compressor windings all equal 1 to 4 ohms
- check [resistance] to earth 50 Mohm minimum
- check run current
I'd also check the motor capacitor(s) , In maximum, it is due to weak capacitor. Replace and try.
Posted on Dec 16, 2010
hvac1960
  • 2133 Answers
SOURCE: system 3 in-door with system
CH 24-Splits and Multi Splits = High or low pressure trip. Low at 1 bar High at 35 bar check pressures. Multi V = High pressure trip.
Posted on Jan 01, 2011
Error code E1 and E4
PDF]SERVICE Manual - Quietside
https://www.quietside.com/archives/.../Service%20ACC1800C.pdf
When error occurs in air conditioner, error code is displayed on indoor unit .... Display priority order at overlapping error : E1?E4?E5?P0?P0?P5?P6?t1? ...
Midea air conditioner error codes
airmaster.net/midea-air-conditioner-error-codes/
Midea air conditioner error codes. Indoor unit error code explanation: R series: ... E1, Indoor / outdoor units communication protection. E2, Zero-crossing signal error ... E4, Outdoor unit temp. sensor or connector of temp. sensor is defective.
[PDF]Download the Fault Error Code Booklet - Samsung
Dec 05, 2015 | Heating & Cooling
Got a LG ducted air conditioner coming up with error code ch26 tested winding all reading 1.6ohms is that normal on a inverter system
Do you mean it is powered by an inverter or is it a 12VDC unit for an RV?
If it operates from 12V, the motor and compressor will measure quite low using only a resistance meter.
For one thing, your meter leads will introduce 0.4-0.6 Ohms of resistance. Short the meter leads together to see this.
Any device using a motor or transformer (as in an inverter) and 12 volts will measure low resistance since the major portion of its 'resistance' is determined by the inductance of the windings and a normal meter cannot measure this.
Nov 25, 2014 | Heating & Cooling
Indoor unit display shows F7
Code F7
Error detail Reverse phase detection circuit (p.c.board)fault. Check your neutral wire loosen or not pinned. Rectify neural connection and restart the unit.
May 11, 2011 | Heating & Cooling
System 3 in-door with system 4 out door inverter. all in door unit show error code CH24 pls help
Nov 17, 2010 | LG LS-L1210CL Mini Split Air Conditioner
AmcoireAire UCHW-H12AF2 ;the scrin show me F1
the F-1 error code is reserved for the inverter systems made by Amcor. What model do you have ?
Support@Pridiom.com
Sep 05, 2010 | AmcorAire UCHW-H12AF2 Split System Air...
Lg Ducted inverter airconditoning with error code COMPRESSOR SAFETY LP what does this mean?
Jan 27, 2010 | LG Heating & Cooling
Im not able to instalthe primavera p6 on my new hp lap windows 7
Before installing primavera p6, check whether any SQL databases with the same name exists. Uninstall the SQL if the databases created during the previous failure installation of primavera p6(go to add or remove programs to uninstall). After uninstallation of SQL express, try to run installation files for primavera p6 will solve your problem.
Revert back for more assistance.
Dec 26, 2009 | Computers & Internet
Nov 30, 2007 | Heating & Cooling
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
