Question about Samsung RB2155 Bottom Freezer Refrigerator
Refrigerator samsung srl678ev appliances
Electrical power
My samsung control on the freezer is displaying OF OFseems ice maker is off I pushed the power freeze by accident and can't get back to regular display
0F 0F on a Samsung refrigerator display indicates that your unit is in DEMO Mode. In DEMO mode, the lights work, but the refrigerator/freezer, fans, etc. will not operate (this mode is for display/retail purposes in appliance stores). Unfortunately, Samsung does not include any info re: DEMO mode in their user manuals.
To exit DEMO mode and return to operating mode, you will need to push 2 display buttons simultaneously for ~ 3 seconds (you'll hear a small chime, then the display window will display the freezer/fridge temps and will then be out of the 0F 0F DEMO mode). The 2 display buttons that you have to press simultaneously will depend on the model of Samsung refrigerator that you have.
I have a Samsung RF18HFENBSR model (french door, bottom freezer, display at top center of fridge compartment). For this model, you press the Power Freeze & Freezer buttons at the same time to enter/exit DEMO mode).
You might try googling Samsung XXXXXXXXXX Demo Mode, where XXXXXXXXX is your model number, and you may find the display button combo for your model. If not, then you can probably get the combination from Samsung support to return your unit to normal operating mode. Your appliance store may also have that information.
Sep 10, 2017 | Samsung Refrigerators
Samsung refrigerator alarm beeping continuously
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
May 15, 2016 | Samsung Refrigerators
Refrigerator plugged in but not running or cooling
Check fuse in the plug use any other working one in the house to test it .
Hope that will help
Dec 05, 2015 | Samsung RS2630SH Side by Side Refrigerator
I have a samsung fridge model rs2530bwp the fan nor compressor does not start , the board on the front door seems fine i can change temps with no problem and all the lights come on
Check out the defrost timer circuit - when that unit goes on, it disconnects power to BOTH the compressor and fans so the box will defrost. When cycle is completed or when a certain temp (via defrost thermostat) is reached power is restored to unit.
The thermostat also controls juice to the major components. If it is faulty no electricity is fed to the motors.
Jul 18, 2015 | Samsung Refrigerators
My samsung frige, french doors keeo ringing
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Mar 19, 2015 | Samsung Refrigerators
Samsung refrigerator parts diagram
Your electricity supplier is liable for any power surges that take out your appliances, contact them, it withh need new boards me thinks.
Nov 14, 2013 | Refrigerators
Samsung RL36SBMS Bottom Freezer problem
LOW HUMMING NOISE COULD BE THE COMPRESSOR CHECK CAPACITOR
Aug 19, 2009 | Samsung RB1955VQ Bottom Freezer...
Need to take the doors off to get it in the house
hi thanks for the question on the top of each door 2 end caps remove 2 3/8 screws remove lift door up and away disconnect any electrical thanks the appliance positive feed back please the appliance doc
Sep 24, 2008 | Samsung CoolTech Plus / Basic Bottom Mount...
I have a side by side refrigerator/freezer by samsung and on the digital display the fridge temp (currently set to 2 degrees) is flashing.what does this mean many thanks
If the blinking continues, you may need to “reset” the Refrigerator. Try unplugging the appliance, wait for
around 10 minutes and then plug the power cord back in.
Jul 11, 2008 | Samsung Refrigerators
Samsung RB2155 Bottom Freezer Refrigerator Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
