Question about LG 3.7 cu. ft. Front-Load Washer - WM2240C
Wm2240c says tcl error
When I turn on my lg wm2240c washer the code tcl flashes.
2 Suggested Answers
SOURCE: LG CODE tcL. What does it mean?
I got the same code - I contacted LG. They have 24 hour customer service available at 800-243-0000 and my call was answered immediately. The code means "top clean load" and is not an error. You have run enough cycles and the washer is asking you to run a cycle with no clothes, and bleach only.
Posted on Oct 01, 2010
LG washing machine error codes I got TCL error code on LG my washing machine What does it mean?
that means you need to clean the tub. use your search engine on the net to learn how. then the error code should go off.
Jul 26, 2017 | LG Washing Machines
Quit working with CL code flashing nothing will work, Ive unplugged and waited to no avail
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 19, 2015 | Washing Machines
Lg waveforce washer makes grinding squeeking noise drum hard to trun.
The LE error or fault code indicates that the washer motor is either overheating or has lost connection to the motor control circuit board. Turn off the machine for 30 minutes to let the motor cool down. Then, restart the washer. If the code comes back immediately the motor is not likely to be at fault and so you should check the wiring from the motor to the motor control board. Also, check the wiring and condition of the rotor position sensor, also called a HALL sensor. If the code doesn't come back on immediately, but returns after the washer has run for a while, the motor stator may be defective
The tub bearing also appears to be part of the problem.
Aug 22, 2014 | LG WT5170V 4.7 cu ft High Efficiency Top...
How to wash down
Hello.. I do not recommend trying to wash a down comforter in this washer. It will not wash correctly and more than likely will not spin out. Your best bet is to take the item to a local laundromat and use a large 50lb washer if available.
Apr 28, 2014 | LG 3.7 cu. ft. Front-Load Washer - WM2240C
TE CODE
TE is thermistor error. it is located on the fill valve. recommend replace
Dec 11, 2013 | LG 3.7 cu. ft. Front-Load Washer - WM2240C
My lg washer will not spin out it keeps flashing OE no matter what i do
Here is a tip that I wrote that gives more detail about how to fix the OE code on LG washers....
LG Washing Machine OE Error Code
heatman101
Sep 02, 2010 | LG WM-1832C Front Load Washer
Apr 25, 2010 | LG WM1814CW Front Load Washer
Lg washer oe error
On LG washing machines, the OE flashing code means there is a drainage problem. hope that helped.
Please Rate Me
George
Apr 28, 2009 | LG WM-2277HW Front Load Washer
" LE " displays
lg washing machine shows an error everytime i turn it on error such as pe
Nov 05, 2008 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Code error ue lg washing machine
ue is (imbalanced error) cause. the load is to small,washer is tilted, laundry is gathered to one side, non distributed things are put into the washer
Jun 20, 2008 | LG WM-2077C Front Load Washer
LG 3.7 cu. ft. Front-Load Washer - WM2240C Logo
21 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
